Kauz
Everything posted by Kauz
  1. Perhaps look into cable ducts. Different sizes with removable tops, so may be exactly what you need.
  2. Using a stop block, you could do it in different settings to get a gradual taper, i.e. first setting with slightest taper, second with a steeper angle farther out on the yard/mast and so on. You'd only have to hand sand the transitions.
  3. Hello, don't know if you are aware that there are different brass alloys. Gross categories are hard, semi hard, soft. You might look for a material suitable for deep drawing, this should be quite malleable and soft. Not as soft as copper, however. Silver would be another option, but with price nowadays ... , and you'd have to cope with the colour 😎.
  4. Sorry for being too late, here is a video: https://youtu.be/81OJdv73thQ?feature=shared
  5. Hello, you might try a mouth atomiser. I used one in my youth for application of fixative to pastels. No airbrush then🦣.
  6. Sorry, but I have to contradict. Being a master goldsmith, I know a bit of the trade. Solders for gold alloys have the same amount of fine gold as the alloys that are soldered, otherwise the fineness of the completed jewellery item could fall below the legally allowed amount. So, for 14k gold, 14k solder is used. With silver, it's another case for metallurgical issues. Silver soldiers for jewellery contain 67.5% to 60% silver. To lower melting temperatures of solders used in jewellery work below those of the gold and silver alloys , usually zinc is added (in the past, cadmium also was used).
  7. Sorry, sequence got muddled. Please read 3 - 1 - 2. 14th of April is the newest date I can see.
  8. It's quite strange, the tracking I get shows totally different data. Quantum mechanics?
  9. Hello, finally, the second copy I ordered arrived here yesterday. A little battered having taken the long run via Australia, so I second the idea of adding a cardboard sleeve. Of the first order, I've got no news yet.
  10. I think USPS cooperates with DHL. When customs were cleared the package was transferred to DHL for delivery within Germany. I was able to track the package with the DHL app, and it is in their system. Usually it's a matter of 2 days maximum until I get a consignment after it was processed in the letter processing centre. Not so this time. Meanwhile I have re-ordered the book, as from similar experiences I have little hope that the package surfaces again. Of course it's not the fault of NRG, and I'd never blame our guild. Just had to let off some steam 😉 Sorry
  11. Hello, DHL messed up the package. It cleared customs on Tuesday, 25th of March, and since then no further progress. "consignment was processed in letter mail centre". I called, but was told to wait until Friday and then have a research started. When I try to do that, I get the notice that it is not possible to have it researched, as it is a letter, no package. You might imagine my frustration.
  12. There are some versions for 3d-printing. Would be plastics, however: https://www.thingiverse.com/search?q=Fractal+vise&page=1
  13. Hello, jewellery (wire) draw plates usually have a chamfer on the small side of the holes, so wood is not shaved when trying to draw through. One could try to grind the plates till the chamfer is away, but it's a lot of work the plates being hardened steel, and you'd have to go through all the grits like in knife sharpening, otherwise there'd be scratches in the dowels. Also I've got cheap plates that are awfully warped, so grinding would be out of question.
  14. Plans Flying Dutchman by mellpapa Plans Black Pearl by mellpapa These might be of help. Sites are in Japanese, just click "translate" in your browser menu
  15. Hello, just found this thread on the SNR forum: https://snr.org.uk/snr-forum/topic/clipper-thermopylae-bowsprit-support/ Perhaps of interest 🤔.
  16. Hello, be aware that there are different kinds of brass alloys. Hard alloys are made for machining, you won't have much success annealing them. For bending, use the soft alloys.
  17. Hello, I did a search for "laser cut model workstation pattern". If you know somebody who'd do the cutting for you, this might be a way: Eg.: https://www.etsy.com/de/market/workstation_laser_cut
  18. Hello, there are deck plans, sail plans, belaying plans: Alex-2
  19. With desktop Chrome (Win), you can print a website using "print to pdf" option. On smartphone, there is the option "share > print", which also saves the website as pdf (Chrome, too). There might be similar options with other browsers.
  20. Hello, being a master goldsmith and working with these drawplates on a day to day basis, please take into consideration that jewellers' drawplates are not designed to scrape away material. On one side the holes have a deep taper to facilitate wire to be reduced in diameter by compressing the metal (and lengthening in consequence, volume of wire remains the same), on the other side, the holes are chamfered. You'd have to grind away a considerable amount of metal from the side where the diameters of the holes are smaller to get to the point of the nominal size of the hole, their smallest diameters. Otherwise, these drawplates don't cut.
  21. Not mine, I just gave links 😉. Others did the work.
  22. You could easily make one yourself: Take a strip of wood, say about 5" long for the dimensions you are talking of, drill a hole for a pencil into the middle of it (length- and widthwise). Drill 2 more holes with exactly the same distance ( about 1/2") from the middle hole for 2 pins that protrude on one side of the wood strip farther than the pencil tip. To use, put the gauge over the wood strip you want to mark so the pencil tip touches the wood, let the pins slide along the edges of the strip and draw along the strip. There will be a short length at each end that is not marked as there is nothing the foremost pin can contact there. https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://m.youtube.com/watch%3Fv%3DpXG2vYt_0Vk&ved=2ahUKEwjWqYuP-NiEAxU9gv0HHV4JAb44FBC3AnoECBAQAQ&usg=AOvVaw3Ek9IhL7iSkQCpkaSGAWFe https://www.bosch-diy.com/de/de/all-about-diy/community/4015448 Deluxe version: Centre line gadget
