Everything posted by mtbediz
While I was waiting for the hornbeam strips I ordered for the deck planking I painted below the waterline white. I am not very knowledgeable in painting, nor I am good at it. I don't like putty and sandpaper job at all, so I always chose unpainted models before. There are a few points that I need to touch up.
I making the bolt effects with 0.7mm diameter black nails. The visible bolt head is spherical and approximately 1.25 mm in diameter. (When we move it to 1:1 scale, the bolt nut size becomes approximately 45 mm, which I think is not too inappropriate in terms of scale). It looks more like a rivet than a bolt nut, but I couldn't find a more suitable material. In the original, the bolts are closer together. I bought all the nails in the store and for now I am doing them widely spaced as the number is limited. Depending on the remaining number of nails, I can make one more row in between.
The second layer of planking is complete.. In real life, these planks were fixed to each other and to the frames with bolts + treenails in a certain configuration. I want to reflect this on the model, otherwise it will be a very raw look. I know some methods to give a treenail effect, but what can be done to give a 1:36 scale bolt effect or to represent the bolt? I would be glad if friends with ideas can guide me.
HM Cutter Alert 1777 by muratx - scale 1:48
mtbediz replied to muratx's topic in - Build logs for subjects built 1751 - 1800
Murat Bey, great job on the hatches, coamings, windlass and other deck stuffs. Everything looks so beautiful. Do you keep building the Alert, any progress on the model? -
I finished the first layer of planking on the port side and started the second layer. Since the original planking of the ship was clinker type, I started it from the keel upwards. This is the first time I'm making a clinkered hull. In case I fail and get stuck, I decided to complete one side first so that I wouldn't have to deal with the other side in vain. Normally I do it on both sides.
Hello guys, I just finished Essex. I couldn't share the finished version because I haven't photographed it yet. I will share as soon as possible. I have started my new project, HM Cutter Alert 1777. I used Vanguard's kit plan for cutting the bulkhead former and bulkheads. Since I chose a slightly larger scale (1:36), I cut the bulkhead former and bulkheads out of 6 mm plywood accordingly. As such, because of relatively stronger structure I eliminated the bulkheads securing patterns and lower deck pattern in the plan so the cutting work was considerably reduced. Since I will make the rabbet where the ends of the planks will enter in the bow part with my own method I cut the bulkhead former accordingly. I made the bulkhead former in 2 pieces in case it was warped because it was a little long. I cut the deck from 2 mm of plywood and glued it in place. I filled the bow with balsa. I will mostly use the drawings in the Anatomy of the Ship book during my build.
USF Essex by mtbediz - FINISHED - 1:50
mtbediz replied to mtbediz's topic in - Build logs for subjects built 1801 - 1850
Thank you so much Julian -
I have completed the boat and hung on the hooks through the inboard eyelets. I attached those clamps as weights to stretch the lines and applied dilute PVA on the lines. I will remove the weights after the glue dries. -
