Everything posted by Beckmann
Hi Empathry, thank you for your kind comment. ebony is too unflexibel and difficult to bend. What do you mean with "Laufbohle"? Here is my first attempt with these difficult planks below the wales. It is actually my third attempt, I broke all the others. If I keep going like this, I will soon run out of planks. I have a question concerning the joints. They jump every second bulkhead from one row of planks to another. And after 4 rows, it goes back to the first bulkhead. Is that right? That produces a regular pattern of joints. And it means, that one plank goes over 8 bulkheads.
Hi Chuck, I know, what you mean. In my case, it is now 7 or 8 weeks, that I started the planking. And there are definitely more than one planks, which I should not have glued in position, because with a little more effort, it could have been better. It is a matter of habit and willpower and Patience. At my work as civil engineer, things are never fast enough. You are actually always behind, trying to not loose connection. So shipmodeling is a bit like a therapy to slow down. The other thing is, that this model is so much fun. And I think it is a level, which is new for ordinary shipmodelbuilder like me. You just can‘t resist sitting down, doing the next plank. Today for example I spent all morning fairing inbord - and enjoyed it. I will take my time for the planking below the wales. Matthias
As usual, things didn't quite work as I thought. I had to do some sanding and following that, some more dying. I would not recommend doing this my way. You have to be extremely careful with the rest of the model. The advantage is, that the planking structure remains very visible. Painting it might cover the seams and joints, so you have one black belt without any visible planks. In the end it is a matter of taste. The best thing to do is propably using the black hornbeam, wich JpR62 mentioned above. This is the finished starboard side of the model. Matthias
The next thing to do are the black whales. I dyed the strips in advance, so I don't have to paint them. We will see, if that was a good idea or not. The disadvantage is, that you have to glue them very careful into position, because you can not sand the surface later. And no glue on top of the surface. And if you moisten the strips fot bending, you will dissolve the mordant. But I prefer the look.
Okay, if that is the colour, I am fine with it. I thought you changed into a lighter blue.
- 1,784 replies
- winchelsea
- Syren Ship Model Company
Hello Chuck, I personally prefer the colours, you used above. Is it possible to get the freeze with this green-blue background? I am still thinking about the old masters gel stain. It would match better, using the darker Colours. Thanks Matthias
- 1,784 replies
- winchelsea
Slate was propably used to cover a qgallery in those days. Here is an old shingle together with the Winnie. The qgallery of HMS Surprise has a comparable construction. My daughter visited the ship in San Diego in 2017. Here is a picture. HMS Victory and HMS Trincomalee have both Black roofs over the qgallery.
- 1,784 replies
- winchelsea
I prefer the dark roof. This is a peace of architecture. The focus is on the columns and the moldings and windows. The upper and lower framing ( roof and frieze) have to be darker in order to make a contrast. Otherwise it might look a bit out of balance in my opinion.
- 1,784 replies
- winchelsea
The Photo of Minerva is excellent. Would you mind putting some more photos from that CD into the gallery of contemporary models?
- 1,784 replies
- winchelsea
The model of HMS Amzon, you mentioned above in your post of July 4th, has a white (or light grey) painted great cabin and even a white painted ceiling in that cabin.
- 1,784 replies
- winchelsea
Chuck, your Quartergallery is very impressive. As the gunports are painted red, and the painted freezes are added as well, my question is: will the captains cabin from inside be painted in any kind of color, white for example? That would mean, that the inside of the quarter gallery could be painted white, or light grey, or even red as well. My other Question is: are you going to install toilets in both quarter-galleries? That would be a bit funny for just one person. But on the other Hand, it might make sense, regarding luv and lee. Matthias
- 1,784 replies
- winchelsea
