Chariots of Fire
About Chariots of Fire
  • Birthday 05/25/1940
  • Gender
  • Location
    Wareham, MA
  • Interests
    Scratch building model fire apparatus and old trucks. Also 1/72 scale USN aircraft of WW2. Sailing ship model building
1,219 profile views
  1. Thanks, Roger. I will keep that in mind. I have some of the brass sheet you are talking about. Any limits on thickness of the sheet that you know of?
  2. Looks like others are having the same issue I am. KS was a good supplier but not any more. I think I will try the paper cutter option and see what happens. I'm looking to get some 1/64" x 1/8" strips. They don't have to be long as I am making some truck springs out of them and the longest is about 3".
  3. Wondering what you are finding (if there is any such thing) as a substitute for KS strip stock now that they have stopped making it. I'm in need of some 1/64" thick by 1/8" wide stock for making some truck springs. I know this is not a nautical theme but brass is such a useful material in ship model construction, I thought of this forum. Any help you can give would be greatly appreciated.
  4. Thanks for the responses everybody. Guess the search goes on. The hinges I mention used to be available in the US but no more. They came from the UK but when I tried a re-order I was informed the person who was making them no longer was. Here was my solution. Non-ship model related but the idea is there. I ended up using several Micro-Mark H style hinges with small brass rod spacers in between. Once painted It won't be that noticeable I hope.
  5. I'm looking for some brass piano hinges that when open would be 5 mm wide. I used to be able to get them from the UK but no longer. Does anyone know if there any out there of that size? I use them for vehicle door and hood hinges. I'm grasping at straws trying to find some.
  6. What great craftsmanship! I built the Billings #600 Bluenose (1:100 scale). Not nearly as detailed as yours.
  7. Last summer I got a Billings 100 scale kit of the Bluenose. My wife expressed an interest in having a model of a schooner so we did some on-line shopping and ordered the kit. It took some time but finally came last June. Laser cut parts were excellent and easy to remove from the wood. Plastic parts remind me of car kits of the '60's. So much more detail in today's extrusions. Nevertheless I used most of them. Planking the hull was a lengthy process as it is impossible to pin the wood to the bulkheads without pre-drilling the holes. Not being an expert at this kind of building I followed the general method of planking the hull but with the pieces being so small (1/8" x 1/16" roughly) it was difficult to taper them. So in some areas a separate filler piece was shaped and inserted. Then as the hull was sanded smooth I used ACC in some of the gaps and let the sanding dust fill them in. It worked quite well. The kit instructions were less than desirable. Numbers in some of the drawings indicated what some of the standing and running rigging were but there were no corresponding numbers for some lines in other views making it difficult to determine where the lines should go. But with some on-line investigation Most of the work was able to get done. We decided that the sails would be furled. Kit material was way to heavy and thick for the scale of the model unless it was to be built in full sail. Even then, doing the necessary folding of the edges, etc would have been very burdensome and time consuming. Probably not the way most furled sails would be done but the effect was good for this build was to use single ply facial tissue. I superglued the edges of the material sufficient to allow a pin hole to be punched through about every half inch for tying the sails to the booms. For the jib sails, I made small brass wire loops, ran them through the holes and closed them up. Thread was then run through each loop. This allowed the sail to be bunched up in front. The rest was tied off. Here are a couple of photos of the work in progress and the final result which we are generally pleased with. The deck pieces were also laser cut but had no lines for planking. I drew lines with a fine drawing pen and then coated the deck with clear polyethylene. I made a jig out of sheet plastic and cut two holes the size of the deadeyes. In between I cut a slot. The deadeyes were put in the holes with the pre-drilled thread holes aligned and then threaded them. Using a jig assured that all of them would be the same. Two jigs were made because the deadeyes were of two sizes. The shrouds were put in place first and ratlines were individually tied with clove hitches and secured with ACC. Then the ends were cut off. In the photo above the booms were raised but were lowered in the final build with furled sails. I'm sure there is plenty to pick apart by those of you who are a lot more expert at model boat building than I am. So go easy on the criticism, although it will be graciously accepted. Here's a 1/25 scale model of a piece of fire apparatus that is more my type of building. It is a combination of sheet plastic, sheet brass, resin castings and is scratch built except for the tires and wheels. It represents a 1954 Maxim 750 gpm pumper. The real one is still around and was photographed and measured for the build.
  8. Thanks, Guys. I will try the silk span and see how it goes. Saw the video above and it helped out a lot.
  9. I'm in the process of building Bluenose II from a Billings kit. The sail material they included is very stiff and would be impossible to create furled sails with. Anyone got any suggestions on what kind of substitute material might be best?
  10. What I was looking for was some insight on planking the Bluenose from this kit. The instructions are the bare minimum and for a novice ship builder it's not nearly adequate for my skill level. But thanks to John for his sending my a link to his tutorial on planking.
  11. Although I am relatively accomplished as a 1/25 scale truck builder, building a model boat is new to me. So far I have set up the bulkheads and decking on the model and am about ready to attempt the planking. The kit has multiple sections of strip wood 3mm x 1/5mm that will be used for planking. Using such small pieces does not seem to fit the methods described in many places on the forum but I need to start somewhere. Can anyone suggest some hints on this? Perhaps this kit was not a good starter but someone other than me wants it built and I want to do it right.
  12. Hello Fireman,
    My name is Michael, alias 10thumbs on the ModelCarsMagazineForum.
    Are you the gentleman who fabricates scratch built brass fire engine models, especially old timers and those that go deep into the woods which most of us don't ever see?
    Anyways, I just ran across your query on brass piano hinges, can't help you there, just curious if you are whom I assume.
    Greetings to Maine, and hope you can find a hinge source.
    Michael
  13. Does anyone know of a supplier of small brass piano hinges. I'm talking 1/8" width by roughly 7" long? There was a supplier in England (Phoenix Models) but they do not carry them anymore. I've looked on line but most that I have found are way too big.
  14. I saw recently a post from someone who was willing to provide small pieces of Renshape material at reasonable cost. Is that still a possibility? If so I'd like to make contact about a purchase.
