Thanks Tom. I’m surely tentative to details, but my use of material to create said is crude at best. I’ll use any thing to get-er done. Again, thanks Rob
- 3,560 replies
- clipper
- hull model
Indeed……. McKay envisioned large cargo carriers. Designed to endure the brutal lower latitudes and their huge waves. That is the one real reason he built the leviathan Great Republic. The roaring 40’s were the most brutal of passages and the trip from there to Australia was the worst. His ships were designed for such passages. Hence their strength and size. Rob
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
Apparently the jibboom not only tapers down from its junction point at the bowsprit But apparently Narrows on either side as well and turns into more of an oblong square shape than round. I did make that slight adjustment but apparently I didn’t make it strong enough I’m not sure if it’s worth tearing everything up to do that replacement I’ll have to think about it. Rob
- 3,560 replies
- clipper
- hull model
Now all I need to do is add the Martingale mounting’s and all the rings to support the stays and the jacks stays and all the headgear.
- 3,560 replies
- clipper
- hull model
Well I worked on the bowsprit this morning and did some finalizing and repairing and I think I’m pretty close the attachment needs to be modified a bit but I think it’s looking pretty good.
- 3,560 replies
- clipper
- hull model
Thanks Pat…….but your build outclasses mine by miles. Your fit and finish is stellar
- 3,560 replies
- clipper
- hull model
Rich……sorry, but you’re seeing the sprit while it was just resting there, it dropped and was not in the right place. I’ve since made some adjustments. Thanks bro
- 3,560 replies
- clipper
- hull model
Working on the bowsprit cap I my cut it from one piece of wood , these iron straps are self adhesive aluminum foil.
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
Here is my problem I am one 6 inch scale off in my diameter of the bow spread. A total of 6 inches at scale that is significant. I think I took my measurements before I had laid the final top rail trim. No wonder. Plus, I’m going to upscale my banding material as well. It will be a far better end result. Thanks for the advice and refresher data input. Notice the difference in this pic. Rob
- 3,560 replies
- clipper
- hull model
Well I decided to remake the bowsprit the jibboom is not in question. What I want to do is make the entire D slightly larger the bowsprit is in my view too small based on the current data. The jibboom is proper in relation to the bowsprit but the bowsprit needs to be re-engineered that’s what I’m going to do thanks.
- 3,560 replies
- clipper
- hull model
Upon further investigation and, just looking her over...I think I'm going to remake her bowsprit. I think I miscalculated the size of her bowsprits dimensions. Not in her length or in her details....but in her diameter. She just doesn't look right to me...what does everyone think? The main rail trim is lined up correctly, but I think I removed too much material when I turned the bowsprit down. It just doesn't feel right. No prob. I can remake the entire rig..bowsprit/jibbom an all. Rob
- 3,560 replies
- clipper
- hull model
Very good observation. It can't be erroneously assumed her bowsprit had any real distance between it and the naval hood...solely based off of her images with no jibboom. Stresses of her tightened bobstays and martingale tension and the stays stresses would have surely applied forces not seen in her *SPRUNG* state without any jibboom and head gear stresses. Rigging and sparring designs took into consideration the stress loads and flexure that would be attained...thus requiring the nautical engineer to calculate that into his design. both hull and rigging. Bob Cleek would know exactly what I was talking about and could probably explain it far better. He's a professional....I'm not even an amateur. It is true what Vlad says...it's nice to have your eyes and opinion at our beckon call....heeheehee Rob
I'm an energizer bunny.......I need progress or I get anxious....plus the research is done...work is now upon me. I need now to think of the means by which I will display her. What will be her pedestal. Rob
- 3,560 replies
- clipper
- hull model
Well Rich...I appreciate that very much....however, I still think I could have done better on some details. I think the transfer was lost in my own inability to replicate accurately. Even in the most discriminating replica...there will be details lost in the translation. Namely in the skills of the modeler in being able to make those translations accurately. I have made a plethora of mistakes and shortcomings, that I have identified. But for the sake of not distracting from the end goal...I will not divulge them here. And I fully agree...without that very clear image of Glory's bow provided by Mike, we could not have been able to make accurate measurements....measurements we can use to reverse engineer the entire vessel. The only true issue is some of the finer details....details that conflict with photographic evidence and those of Mike's original drawings.....and those details omitted from paintings or just not visible due to angle and distance. There is still some wiggle room for artistic license. Some of these items I will detail when I get to that install stage of the model. Cheers. Rob
- 3,560 replies
- clipper
- hull model
A few more images. I won’t attach it till I finish adding all the head gear attachments and the martingale point. And fixing all the guy and jib points It’s so much easier to do all that off model. Rob
- 3,560 replies
- clipper
- hull model
Thanks so much Rich, I’m truly honored by your comments. I worked the bowsprit, it is still wet. I even made the iron strap with a bolt. I’ll take a better image when things dry Rob
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
