So for one lower mast...I had to: Cut 4 lengthwise grooves to represent the outer 4 beams. Build and apply the 36 ring wedges under each ring and in each groove. Cut and apply copper banding and glue secure. Paint banding black. Add chain lift. Stain/varnish/weather. Build, apply cheek supports and tops and paint white/weather. Lots of work...then required for simple dowel or straight stick masts. But the effect is much more attractive and accurate. Rob
Today I worked on the lower masts. The mast for the Glory of the Seas were made on the mill and were quite laborious....I didn't want to go that route this time...So I tried gluing the 5 pieces to together adding the blocking of the straps.....I turned on the lathe. Not so good....the extreme edges kept getting knocked off and ruining the mast as I began to apply the cutting tool....I then opted to sand on the lathe instead....same result. So I opted to build a table saw for the job....Using some ingenuity, I adapted the table saw to one end of a dental Baldor bench lathe. This meant I needed to mill the housing and attachment bracket.....get some good blades...make the keepers and secure stock and table. Walla! done. It works beautifully and made the cuts in the masts exactly as needed. So first is an image of the defunct lathe attempt mast. Strapping had not been done...just the tuned mast. It's the dark brown one. Rob
Cutty Sark by NenadM
rwiederrich replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
Coming along nicely Nenad.......you have made some very good progress......I bet you have leaned lots too as you have made the changes you have. I see you added the plankshear........ I steam out in the shop...not to get into my wife's space..... Great progress. Rob- 4,152 replies
- cutty sark
- tehnodidakta
It's tough staying out of the shipyard......isn't it. I steal away 20 minutes here and there myself. Merry Christmas. And many sneak aways......... Rob
- 3,618 replies
- young america
- clipper
The lower masts will be made, then strapped..this takes a bit of time. I will use raw dummy masts so I can properly locate the fife rails. The McKay didn't carry stun sails so those can be omitted. I have lots of railing to add and unlike the Lightning the McKay had turned wood stanchions instead of iron ones...so I have that to work on as well. I think the effect will be convincing and dramatic...you have the model...then you have her in her element......in a big way. Thanks for looking in. Rob
I concur Sailor. Sometimes I wonder if I'm even on the same subject as Ed and others. His attention to detail and process is amazing to say the least...I feel I'm a near beginner compared to his ability.....or maybe I'm just lazier. Merry Christmas. Rob
- 3,618 replies
- young america
- clipper
Great production Ed and beautiful lines....top notch modeling...for sure. Merry Christmas to you as well..... Rob
- 3,618 replies
- young america
- clipper
It happens with friends who are not into your stuff......it's happened to me too. Glad things are well... Rob
- 525 replies
- cutty sark
- mantua
