rwiederrich
  1. Very impressive....nice and clean. Your experiences are producing great results. Nicely done. Rob
  2. Thanks Pat. The bow mods were probably the hardest....getting the hull curves...took some doing. Now its time to lay the trim along the monkey rail and along the forecastle deck. I'll begin the poop decking and all that's aft....as another project....tying them in amidships. The decks and hull will also get a dusting of weathering to bring out the plank details. Rob
  3. Finished off the plankshear and am test fitting some trim. Rob
  4. Next……I stained the decking and will wait to dry before I add any trim work…..such as the monkey rail cap and the weather deck(forecastle) rail head. Rob
  5. Did a bit of work today……. beginning with the remodel of the bow and concave section up to the forecastle. This had to be meticulously had created. Blending the sharp below water angles to the more blunt concaved angle beneath the forecastle deck. Here are some images of each side after I made the mod………a bow shot and a few others. Rob
  6. The next bit of fun will be some hull modifications. I need to fill in the concave portion of the hull up from the sheer line to the forecastle decking. The CS hull if far too extreme to pass off as a fuller bowed Donald McKay. So….. when the forecastle/main house decking is dry(from gluing). I will tackle the bow mods. Another reason why I removed all the head gear. Rob
  7. Spent some time working the forward deck house and plotting out the forecastle deck and the house roof The trick was getting it around the fore mast. No problem. Just did a bit of measuring , cut out along the masts width and simply slid it in from the front and used the piece I removed and put it back. Cut right along the deck strakes……no seams across any strakes. Rob
  8. Yep……the benefits of the Howes design. Great picture. Rob
  9. Actually, this model was my first attempt at Glory……. but the model originally set in the water was the clipper Donald McKay I decided to remodel the Cutty Sark modified to the Glory hull into the McKay and set aside the modified McKay hull. The Glory model was further along in construction and all it needed was to be transformed into the McKay. It sounds complicated, but it’s simply modifying an already modified model………. Still lots to do…….heeheehee The scale is 1/128 Rob
  10. We’ll Pat, my options were limited if I wanted to make it work for me. Thanks for the kudos. Im so excited to create this version of the Donald McKay. Her comparison will be hard to find. I don’t know any current models of her. Thanks for the fine compliments. Rob
  11. I added the framing for the forecastle decking and I began more work on the main forward cabin, and off bench I’m working on the 6 capstans and deck vents. Rob
  12. Worked a bit tonight. I finished adding the port pin rail and pins. Rob
  13. Lastly, I began the addition of the new forecastle deck beams. They’re just test fitted for now. I removed the rest of the head gear and the old figurehead. I refashioned the McKay clan figurehead and will add it after the new forecastle deck and new hull strakes are installed. Rob
  14. I added additional mast bands to correct a previous oversight ……as I was fixin stuff. Easy to do with less stuff in the way. Rob
  15. Spent some time working the McKay today. I finished adding the pin rail and pins and I flipped her and added the blue waterways to her port side. Rob
  16. Rick....it has been fun...and I haven't installed the new pin rails yet, either. I'm working one side at a time currently...before I install the forward forecastle bulkhead and the forecastle decking. The real trick will come when I then install the decking over the forward cabin and the poop deck aft...... Both need to be split and cut away to pass around the masts...then reassembled. I've chosen to stain the decks a grey...because the McKay was built for the Australian passenger trade, where she saw lower latitudes where her decks would become greyed by the boiling sun and airy weather...not to mention the hundreds of passengers traversing her decks. Rob
  17. There is another on the starboard side too..... Thanks Javelin. As it is my habit.....I like to display my models in unique ways. Rob
  18. Drux....I expect nothing less then the highest forms of criticism, sarcasm, tomfoolery, blovinating, and every other form of flattery, while I run amok. It is a right, one must endure while passing through these waters. Rob (aka...Runamoker)
  19. I’m reworking her forecastle. She was fuller forward then extreme clippers. Cutting the pattern and resting it, taking measurements. Lots of reworking. Im going to be removing and replacing all the head gear as well…….. The new decking will be a dark grey… weathered like the main deck at her waist. Rob
  20. Several accounts claim she had Forbes rig, and others claim she had Howes. Anyway… I’m not changing the rig. I worked on several things today. I had to add the blue waterway that was missing I began the forward cabin and the new forecastle. Here are some pics.
  21. Yep, six of -em. Yes, again......the helm was in the helm house aft. She had 5 main deck sky lights...and (not depicted)...she also had flush deck plate glass skylights...all along her deck...both on the port and starboard(Along the gunwales'). One, item I'm wrestling with, is that Crothers does not indicate the large aft cabin on the full poop deck...that the mizzen mast runs through(Like Glory of the Seas)....with skylights on its roof. I agree with most of Crothers interpretation, but, written first hand accounts vary slightly...especially when describing the waist house abaft of the main mast as a full house extending off the flush poop deck....and the catwalk extends to the main cabin/forecastle from that. I'm doing more research and triple checking....but I think my version may vary from Crothers(we'll see) He's rarely wrong.... She had similar structures as Lightning....so I am gleaning from her structures to aid me. Rob
  22. Here is the deck plan of the Donald McKay. From Crothers. Rob
  23. Sorry for the lack of work , but I’m on holiday in Las Vegas and Arizona this week. I’ll begin posting next Monday. Thanks everyone Rob
  24. Yeah …… that’s like pouring the foundation after the house is built. Wait…….I’ve actually done that to an old house my brother in law owned. I’ve redrawn the deck plan based on this new data and it will be fun to construct. This clipper was designed and built for passenger service, so she will have lots of conveniences. Plus, she had 6 boats. Rob
