rwiederrich
  1. If you look closely, you can see a metal stanchioned rail on the forecastle in the boy image. Rob
  2. Thank Vlad. Just a few more details to add, like the long house boat straps, the bell, the addition of the third small green dingy on the boys house. Then I’ll focus on the lower masts. Rob
  3. Finished up more details, like adding the steam donkey stack and the heating pot chimney. Plus I added the bits for the howser mooring holes. Rob
  4. Remembering my first build of her as she was originally built causes me to marvel at how busy her decks have become since she became experienced and a full fledged working cargo carrier. Thanks for the fine comment. Rob
  5. Now onto the forward hatchway and adding more detail to the forecastle, namely the iron rail. Rob
  6. Worked on finishing up the boat tie downs and adding the 3 boat skids on the long cabin. Had to cut out the spacing for the edging to make it like the prototype. Rob
  7. For the inquisitive. Here is a crude drawing of the technique I will employ in making my composite masts. I'll begin with square stock...prep the ends to be received by the lathe. Then run through the table saw to cut out the corners as indicated... Glue back into those cutouts the spacers for each band cut to scale width. Then placing the entire thing into the lathe and turning to scale diameter for the particular mast. Repeat for each mast. Once turned....I will paint the recesses white...(replace in lathe to sand and clean up), varnish(tung oil) the rest and apply the bands, which will be painted red. I think this will produce convincing lower masts
  8. I salvaged them from another parts kit. I fashioned the pumps and mechanical items. I try to use whatever and from wherever I can to achieve my goals. It's the end product that counts. I didn't make the boats(though I covered them), I didn't scribe the decking or house material, I didn't cast or solder the anchors. I believe everything and anything(Preferably if it is already engineered), can be repurposed and will be utilized....because when all is said and done, it is the end product...a fine scaled, detailed model that is the goal. How I got there, is not part of the judging criteria. Rob
  9. It'll be fun...I have 2 approaches, so we'll see which one I go for. Still working out the processes for each to determine which will take up my time. Rob
  10. For me, it is not the time spent...I enjoy every minute making it and I did with all my other builds. It is, the significance of her reproduction, so history can at least have a model example of what she most likely appeared like. It would be for historical significance that I would donate her to a qualified deserving museum. Rob
  11. If the Logistics could be worked out, I might consider such an adventure. Lots of logistics would need to be worked out for such an endeavor. It would be nice to have a small gallery of images and artifacts and her scale model. A wonderful thing to think about. Rob
  12. I might even consider that. Donating her to a deserving honoring museum. Interesting notion. Rob
  13. I try to have as much convincing detail this scale can provide. Here are a few more pics.
  14. Started to finish up the boats. Still have to finish up the rail and glue things down. Rob
  15. During her 1877 image she had all composite masts.....so composite it will be. Rob
  16. That was precisely my own conclusion. Composite mast were not actually more expensive then good, clean, straight logs for a good quality mast. Composite masts were built to accommodate for the lack of good, clean, straight logs of this size. You brought up the very point I was going to bring up. Good call. Rob
