RobinB87
Members-
Stavanger reacted to a post in a topic:
Le Fleuron 1729 by RobinB87 - Scale 1:48 - POB - Body method M. Bezverhny
RobinB87 reacted to a post in a topic:
MONTAÑES by Amalio
Archi reacted to a post in a topic:
marsalv reacted to a post in a topic:
Siggi52 reacted to a post in a topic:
HMS Tiger 1747 by Siggi52 - 1:48 - 60 gun ship from NMM plans
md1400cs reacted to a post in a topic:
Hello Siggi, what a truly astonishing build you have here. I've read your thread with joy! Keep up the good work!
Le Fleuron 1729 by Chris. - scale 1/72 - French warship from Delacroix monograph
albert reacted to a post in a topic:
Mike Y reacted to a post in a topic:
davyboy reacted to a post in a topic:
Hello my friends, long time i now. Finally i've started again with this beauty, after i recieved new plans from Ancre. (They updated de page of Le Fleuron with new drawing in 48th scale🤩 ) Instead of plain pine i have chosen for plywood. Last 6 weeks i have started with making the hull, is not finished yet. Lots of things to do like sanding😅 but i thought maybe it is an good idea to post the current status of Le Fleuron!
Hello! Long time i now...😅..but this year im finally ready to go for it again. We had a few years ago some damage on the roof of my house and almost done renovating my whole house... BUT.. most of my drawings are lost due to waterdamage that few years ago!😣 I contacted Ancre but they wil not send new plans 48 scale only 36 scale. But i dont want to recalculate every measurment🙈 Is there somebody who will sell these to me so i can start again/continue? Or is there somebody who can tell me where i can get the set in 1/48? Fingers crossed!!! Greetings Robin.
I think amateur is correct, its also a nice ship to see and it has a big package of different modelling skills. There is a good amount of info to find on the internet, and the author of the monograph is also on a few forums to help where necessary. I think all that info is the reason you see that many online.
Le Fleuron?
Houston here!
Welcome Adam, i like the Bounty and i am very curious to see you're new challenge. I think when you take you're time to do everything right it will be fine. Be patient, especially in the beginning (drawing and making hull) doesn't matter its a kit or scratch, it will give you a lot of pleasure with the rest of the build..😉 Do you already now how you gonna start building the hull? Admiralty style, or?? I wish you luck with you're new build, ill track it!👍
Hello, today i started with making my building-boards. After the drawing part i made two corresponding long "ribs", Those are the backbone of the ship and hopefully they hold my ship straight and square🤞😁 Also i made a false keel to mount everything straight and i made it 2,5 mm thick (half keel minus rabbit). After that i start mounting every 5 or 6th rib, i glued them in place and those are my markers, i'll fit the rest between those. Those i will not glue at first, but later when all the sanding is done.....you'll see when i am on that point in the future. That's all for now! 👍
Hi, its a very interesting, and i find it also a easy way of making my hull contours. It was a little bit of a struggle at first to discover how everything was done with the drawing part but after some small tests i think i am on the right track now😄 If there is some interest i can make a "how to" build log from the beginning. The drawing part is the most difficult part i think to understand. I am to far now and didn't make more pictures than these, but if i order some new drawings in the nearby future i can create a small part of a hull from start to finish. Just let me now, then i collect how much interest there is.😉 Best regards, Robin.
Thank you all for your warm welcome! I'm exited to join in the conversations and logs on this forum 😀 Best regards, Robin
ancre Le Fleuron 1729 by rekon54 - 1:24
RobinB87 replied to rekon54's topic in - Build logs for subjects built 1501 - 1750
Stunning job! Love your build😃 Bets regards, Robin -
HMS VICTORY 1759 by isalbert
HMS Kingfisher 1770 by Remcohe - 1/48 - English 14-Gun Sloop - POF
Le Soleil Royal by Nek0 - 1/72 - Marc Yeu
RobinB87 replied to Nek0's topic in - Build logs for subjects built 1501 - 1750
Just discovered your build log. What a stunning build! Chapeau!🙌 Are you also rigging this beauty? Best regards, Robin- 208 replies
- le soleil royal
- 104 guns
