Waitoa
Posts posted by Waitoa
Hi,
making a a bit more progress, glad of the advice and feedback from Mayohoo and SColeman as the other fender - rubbing strake was a better fit. Decided a while ago to paint the hull and glad as some of the bow is a bit messy. Will sort the upper deck planking out once that deck is down as this is the area that I have kit-bashed as this model is not really based on the Surprise but is a re-box of another kit la Glorie.
Waitoa
- S.Coleman, John Allen and coxswain
- 3
On 18/06/2017 at 3:24 AM, Mayohoo said:
I usually soak them in a tub overnight and then use a soldering iron to get a partial bend then use clamps to hold it in place after gluing. I use plastic push pins to hold them if clamps can't be maneuvered into place to hold the wood in place.
Thanks Mayohoo, very jealous of your build and trying to use some of your ideas on mine even though different kits, tried the soldering iron trick tonight and got a better result than just soaking and clamping so appreciate the tip
On 18/06/2017 at 3:03 AM, S.Coleman said:
Have a look at my build, The Mamoli 1:75 Friesland. On Page 2 it shows me putting the second planking on. Just buy using drawing pins next to the plank. No holes
Your build looks fantastic. Good work
Thanks, I have been enjoying your build and impressed at the finish you have achieved, next build is the Santa Maria so I can not hide my mistakes with a coat of paint so trying to get some practice on this one
Ermmmn, putting on the rubbing strakes - fenders and open to ideas, I have steamed them as I have seen other do but they still spring out a bit. I have had to pin to get them to lie flat while the glue dries but that leaves me with holes the will need touching up. Any suggestions on how to do these better, thanks in advance.
- coxswain and zoly99sask
- 2
Hi,
The metal pieces that were provided with the kit did not fit so will need a lot of scratch building. Not something I am very good at, built the basic outlines of the stern galleries from balsa. Still will need some more sanding and my best friend putty. Will get the rubbing strakes fitted and the hull painted before I try to make the windows etc.
Waitoa
Thanks Captain 71, progress is grinding to a halt as work is getting a lot busier and my efforts to scratch build the stern area are proving challenging. Seeing how you are getting on my spur me to action
Hi,
Being able to view other people's builds always provides new inspiration to push further. This also includes trying to emulate the tidy build spaces you get to see. Spent the weekend building the Occre model boat building station. Came together very well after my 8 year old read the instructions and pointed out some of the pieces were around the wrong way. Instructions are not my strong point. Now run out of steam to transfer my accumulate treasures to it and clear out some of the clutter but at least I have made a start....
Waitoa
18 hours ago, Mayohoo said:
Have visited the HMS Rose/Surprise in San Diego. It is a little run down now and needs some TLC. I had some pictures of it in my build log that are helpful. You might want to see the USS Constitution in Boston for a better preserved ship. And of course the HMS Victory is outstanding in Portsmouth.
I have found the Lavery book on HMS Surprise very helpful for diagrams if you want to bash your kit in that direction. You can likely get one at the library and photocopy some of the pages. Otherwise it is $$$.
https://www.amazon.com/Frigate-Surprise-Complete-slipcased-hardcover/dp/039307062X
Good to see you making progress.
Thanks, managed to get a copy of this from a discount bookshop a few years back and counting myself lucky as it was very cheap. Been drawing some ideas from this and peaking at other more talented peoples' blogs like yours for ideas and inspiration. Thanks for the photos and will have a look. I think I am taking the "bash" concept a bit too far as the photo attached shows. Ending up having to scratch build a lot more than I intended but hoping I end up with a better outcome as a result.
17 hours ago, captain71 said:
Thanks Waitoa. Very helpful. Since I have a frame around each metal gunport anyway, I might just go with wood as well. I"ll do some experimenting. The plans and parts are so screwed up, it's kinda of a free for all anyway. Going down to San Diego. While I'm there I'm going to take a look at ship they used for the movie. The HMS Rose replica. Just for fun mostly but I think It will help me get some perspective on how it should look.
Hi
HMS Rose is on my to do list. Been based in the U.K. For a number of years but originally from NZ and may take some convincing of the wife to go the LA route just to pop down to San Diego and see a ship. Plans and parts seem to be all over the show so will need to do more scratch building. As it is really a fictional ship I am sure we can fall back on that as an excuse. Will try to do some more this weekend so can post some more.
Rgds
Waitoa
Inspirational build that wants me to push my meagre skills further
Waitoa
- mtaylor, Blue Ensign and Martin W
- 3
16 hours ago, captain71 said:
Looks really good. Your a brave guy, Waitoa. I'm inspired. I'm always scared to move forward. First off. Damn! Makin those gun port boxes must have been tedious.
How far did you set them back from the surface of the first planking? How bout a close up. And finally what size and wood did you use for the finish planks? they look wider than the ones I thought
we use. I have all my gun ports framed in and first planking on but haven't set them in place yet. I'll be adding pics to my log soon. Great job!
Hi,
Thanks for for the feedback and glad you are still out there. Think Bindy has dropped out so looks it is you and me. The gun port boxes weren't too bad I used the gun port lids as the template for the size. I tried to set them back enough so that the ports would be flush but in some cases they stick out a bit. Used 5 mm mahogany strip for the second planking with something else which may have been meant for the deck. This was spare wood I had so that is why it won't look the same as yours. Need to label the wood when I unbox it. Photos below.
Finally finished the second planking. Glad that I decided to paint the hull rather than go for the natural wood finish. I forgot to label the wood when I unboxed it so ended up using some spare strip I had. I am not very good at planking but could not seem to get the planking to run on this so had to use a bit of putty. Hoping that with additional details added and painted it will not show too badly.
Waitoa
- coxswain, zoly99sask, Eddie and 1 other
- 4
Hi, lost my access to the website and took awhile to get back in. Looking good, getting to the end of my second planking and think I will need a bit of putty to clean some of it will post some photos soon
HI
Thanks for the feedback and the tip. Made a jig with one of the cannon port lids last night to check. They weren't as bad as I thought but can see some small issues with the first planking makes them look worse. If anyone else is making this would suggest a couple of extra frames between cannon port 3 - 6 from the bow so that the planks lie right.
Waitoa
Hi
Still struggling to get the time to dedicate to this build, started the second planking which is hiding some of the mistakes of the first. Will provide a good surface as will fully paint this one. Also hoping the detail added will hide some of the gun ports that aren't as well shaped as I would have liked.
Waitoa
Hi
I have used a pin pusher for the first planking, mainly to hold them in place while the glue dries. Trying to move away from this with clamps but still find it useful. Usually only push them halfway in and once the glue is dry remove with pliers. Need to add my signature but not great with technology even though that is the basis of my job. Building the HMS Surprise and some of the pictures show the pin holes and some of the pins in place.
Waitoa
Hi Bipper,
Thanks for your comments. Be good to see some photos of your build. I have planked the upper deck to make it closer to the real surprise. I have not measured how high I went was basically three of the planks higher than the original plans. On the lower gun deck I used some scrap wood to make the planking thicker inside so it looks more real. Will do the same for the upper deck once I get to it. You can see some of the initial framing for this.
Hope this helps
Waitoa
HMS Surprise by Waitoa - Mamoli - Scale 1:75
Thanks for the feedback,started painting the hull this week so will post some more photos later, will have to scratch build the stern which I am not looking forward too
