Waitoa
Posts posted by Waitoa
- Edwardkenway, Ekis, Egilman and 10 others
13
Get well soon, picked up something a week or so ago and then spent a couple of days being paranoid that it was C19. One hot chilli later all back to normal
- Egilman, Edwardkenway, Canute and 1 other
4
Very cool, have some items on order from Shapeways who do 3D printing mainly Medieval guards but also some Oxen as want to add a few carts as well. Not getting much done on my church as roof tiles isn’t part I get much enjoyment from
- Edwardkenway, Ekis, Old Collingwood and 3 others
6
Really stunned and lost for words just amazing
1 hour ago, Kevin said:
draw straight lines on the paper to keep bricks in line
Well you will be one step ahead of me if you do this
Hi Kevin,
I actually like it as it is different to what I have normally seen and makes your build unique.
Waitoa
- Egilman, Canute, Old Collingwood and 2 others
5
May be picking the master builder’s brains on weathering the bricks as have started to experiment with a bit of slime here and there and think it really adds to it
7 hours ago, Kevin said:
very nice, after my church im looking at doing a warehouse
Me t on my list is a watchtower it will look similar to Ekis’ one as it came with the original kit but sure mine will look like it has done 20 rounds with a series of siege weapons. After that I have half a house and half a lords manor that came with the original kit. Then I have 3 houses that came with an Aedes Ars kit sadly I am in love with their bricks.
Will need to scratch build the gate house and want to add a forge, stable and a series of animal pens. Definitely keen on doing a silage pile but not sure how to model that big.
55 minutes ago, captain_hook said:
Very nice! Meanwhile there are a bunch of nice medieval kits out there.
Thanks for the comment. Any suggestions on the kits as need to plan out the rest and open to ideas on buildings, people, wagons etc. May have to do some scratch building.
- Canute, popeye the sailor, Egilman and 6 others
9
Looks good, like the windows
Using similar card and my suggestion is to use internal bracing as I have a lot of bowing in the walls which makes it hard to get things level and looking dressed. I now use the dust created from sanding and basically brush it into any gaps I see and the either wet it lightly to make it return to clay and leave it to dry or in some cases use a Matt varnish to hold it into place. This doesn’t remove the gaps but lessens how much it stands out when you look at it and seems to work well.
- Edwardkenway, Kevin, Egilman and 5 others
8
- Egilman, Edwardkenway, Jack12477 and 10 others
13
Great painting and looking forward to seeing this progress as always wanted to do a Napoleonic diorama
- Edwardkenway, mtaylor, Egilman and 1 other
4
52 minutes ago, Old Collingwood said:
I have to ask (can not help myself) are you going to do some figures?
OC.
It is addictive, have the last 15 townspeople to paint and tempted to outsource them to O.C. given the results he gets. Looking forward to seeing what you are planning as I am still battling through my cloisters.
- Canute, popeye the sailor, Egilman and 5 others
8
Oh no, Another great addition! Was thinking of something similar but mounting it on the wall. Before the current war travelled through Syria and spent a few days wandering around Krak de Cheviallers. There were a number of turrets that I auumed were some type of catapult mounting but turned out to be for windmillls. I remember there were about 14.
Thanks Ekis for the detailed response, looked at having the larger bricks on the corners and as the first layer of bricks but am now holding them back for use on the walls. Plucking up the courage to try your weathering technique as it looks amazing.
Waitoa
Just found this log and look forward to viewing it once you restart
- Kevin, Canute, modeller_masa and 2 others
5
21 minutes ago, Kevin said:
very nice indeed, well stuck on otherwise they would fall off being upside down,
Far better than my drop test, looks good by the way and there is always more room for these builds.
Kevin - thanks experimenting with various ways o building so good to get your comments
- Canute, Old Collingwood, lmagna and 3 others
6
Interested in how Kevin and Ekis do their walls. I tend to zig zag my bricks laying a course of bricks for each length of wall. This means that different parts of the walls are at different heights which hopefully shows what I mean. This stops me from getting bored but also allows me to run a file across the top so it is relatively flat for the next layer. Also it has allowed me to weave the various bricks in on the corners and has made it quite strong. Accidentally dropped it and other than a few bricks it held together.
Ekis and Kevin - your thoughts?
Building a Medieval fortress - by Waitoa - Del Prado 1/87
in Non-ship/categorised builds
Thanks Louie, taking a bit longer than I first thought but hoping to have this finished by end of Jan
