hamilton
Posts posted by hamilton
  1. Hi Hamilton,
    Thank you very much for your comments...
    After realizing the presence of your build, seeing your method of building and its value, it would be fabulous your Berlin. And it would be good not to share your potential build of Berlin because I don't want to face with my errors and my incompetence in my build... ;)
    Ferit:
    Please - I'm blushing!! If there is any "incompetence" in your build, you've done an expert's work at covering it up! All I can see is nice, clean and well-detailed craftsmanship!
    hamilton
  2. Good to hear from you Harlequin! We should arrange a side-by-side photo-log of our two builds once mine's done - it would be interesting to see how they stand up - we'll have to make up a list of perspectives so we can each replicate similar shots for comparison - not a quality comparison, clearly, since I cannot hope to match your beautiful work on the Greyhound!
    hamilton
  3. Thanks BE - again, I wish I had both the time and the patience to follow through on your earlier suggestion! But I will live with these results. I was trying to picture her with the lower hull planked and the channels & chainplates on - this will soften some of that high contrast - as will the rails and mouldings once they're on....next time I'll wait a bit longer to read all the responses before moving on!
    hamilton
  4. Hello Augie, J and BE
    Thanks for your words of encouragement and advice! BE - I just read your response now after spending the day re-doing my bulwark planking (see photos below). In retrospect, this solution makes sense....I had a feeling very early on that I may have been positioning the sweep ports too low....but I didn't listen to myself then, as I should have....
    I could certainly have stripped the wales and re-positioned them - and probably this would have been the best solution - either re-positioning and cutting the the sweep ports or omitting this detail....I had considered this, but went for what was "easiest" rather than what may have been "best". I installed a plank along the bottom edge of the gun ports to establish the run of the strakes and then planked up and down from there, spiling the last two planks to fit along the wales-as-fitted.....others may disagree, but I can live with the results....
    Anyway, thanks all once again! Here are some photos of the results (I've only completed the starboard side....). I re-planked, up to the top of the gun ports in the waist and then down to the wales. I then stained this section of bulwark planking with Golden Oak. After it had dried, I touched up along the wales and then planked the remaining upper section of the bulwarks, masked it off and painted it blue at quarterdeck and forecastle. These blue sections will be further segmented with 1mm x 1mm extensions from the rails (later)....
    Anyway - enjoy!
    hamilton
    The patchy look of the paint at stern in the last photo is a function of the glare of sunlight - it doesn't really look that bad!
  5. Hello....
    Did you ever have one of those days when you probably should never have sat down at the workbench? I had one tonight!
    I'd been looking forward all day to starting in on the bulwark planking, though as I mentioned in my last update I thought I might have difficulties here - that is an understatement!!
    I completed the wales last night and as I mentioned previously, I'd tried to keep a distinctive sweep to the run of the wales without edge bending them beyond recognition. When I was laying on the wales I noticed an error that I'm not sure how I could have avoided making.....The sweep ports are about 3-5 mm too low.....Thus, the wales are too low. The upper wale should meet the same point as the top of the counter at the stern - to make it rest even half way up the counter (and thus not have the wales bending under it) I had to put quite a sweep into it - and thus into the wales overall. This sweep doesn't look too exaggerated in the photos, and it isn't really. But you can see that it puts the run of the wales off from the lower edge of the gunports (they should be not exactly parallel, but very close, judging by Goodwin's book).
    This would not have been an issue if the sweeps were a little bit higher up the hull....As it is, however, they are not, and it is impossible for me to correct them at this point.
    So having the sweeps too low means having the wales to low and having them make a much more dramatic run then they otherwise would (or should). But this also means that the bulwark planking will be especially tricky, and it certainly proved to be so today when I came to it after putting our son to bed....
    I thought of three possibilities for attacking the job:
    1. Just lay the bulwark strakes along the same trajectory as the wales - however, this would have resulted in some bizarre edge bending and would have looked very weird.
    2. Start by laying the strake that runs immediately below the gun ports, so as to define the run of the strakes according to the gentle curve of the bottom edges of the ports. Then plank downwards and spile the last couple of strakes to conform to the sweep of the wales - this is what I SHOULD have done, though not, as it turns out, what I did....though I will be doing this tomorrow
    3. Spile a short plank to fit against the upper wales and then just fill upwards like filling a bowl with water. This is what I did tonight, with grievous results. After I had laid 4 strakes (and finally got out of the well created by the wales) things looked good at the bow, but at the stern I noticed that the planks were actually tending downward and not sweeping upward as they should be....This was the result of a cumulative error in my spiling of the planks at stern which led to a miscalculation of the length of these lower strakes at that point.....fortunately I just did the starboard side....
    So, long and short? Seeing how horrible it looked, I ripped the planks off (leaving the starboard side rather scarred) and will smooth it out and start again tomorrow.....Here are a few photos - a couple of the completed double wales (which I'm very happy with) and a couple of the scarred outboard bulwarks....
    Tired and morose
    hamiton
  6.  Alright everyone - Happy Victoria Day to my commonwealth buddies! Or Happy May 2-4 for my fellow Canucks. Hope you're enjoying the long weekend.
    In other news, a bit of an update on Greyhound, which I will now stop calling Greyhound and start calling "Blandford", since it's starting to come together as such....
    Here's the latest laundry list:
    1. Cut out gunports - using a template I made a while back that derived from the plans. The gunports in the waist were sawed out with an x-acto saw, while the other full square gun ports were cut out using the tried and true micro-drill/x-acto blade/needle file method.
    2. Inboard bulwark finishing - in Cadmium Red medium (I use Golden acrylic artist paints, which are very nice to work with). Finished off with a coat of polyurethane.
    3. Installed the upper wale - Goodwin's book shows the Blandford with a really distinctive double wale. I'm using 3mm x 1.5mm line for these wales with 1mm x 3mm lime for the filling strake. The upper wale was very difficult for two reasons - first because just locating its placement was tough. Goodwin shows its top edge flush against the sweep ports/ballast ports at mid-ships and then crossing the line of these ports at both bow (slightly) and stern (where it crosses entirely and where a few of the aftmost sweep ports are in line with the filling strake....I could not really get this effect without really edge bending the wale - so I avoided doing this and went with what looked good and followed as close as possible to the natural run of the planking...though I think I may get in trouble with the second planking above the wales.....
    4. Installed the counter planking - and finished it also in cadmium red medium - very straightforward.
    5. Installed the stern planking on the exposed aft side of bulkhead 13 - used a diagonal pattern as shown in Goodwin's book...this was (like the filling strake) stained using Minwax Golden Oak.
    6. Installed the filling strake - see notes above.
    That's it. I'll be laying on the lower wales tonight and then on to the outboard bulwark planking.....Bye for now
    hamilton
  7. Hello all:
    The first planking is now finished, and she is shaping up, I think - or maybe I should say "I'm feeling a little more pleased about her". Since my last post, here's a couple of things that have happened....
    1. I was studying the Goodwin's AOS Blandford and noticed that I had forgotten to cut a little "step" in the f'csl bulwarks.....this I did - see below.
    2. finished planking the 5 bands I had lined off on the hull
    3. applied liberal amounts of acrylic modelling paste to the hull and then sanded it quite vigorously on my front porch as the sun went down.
    4. filed out ballast and sweep ports
    5. I decided to lay a spirketing plank of 1.5mm x 3mm, and then plank the rest of the inboard bulwarks with 3mm x 1mm lime - I'm going to finish them in red once I cut the gunports and line them
    6. finished the sweep and ballast port frames in red (again, and I'll have to do so a couple of times more I think....
    Anyway, things are proceeding now, and the next couple of weeks will show a real transformation....I'm starting to have fun with this build - it only took 6 weeks!!
    Here are the photos - enjoy!
    hamilton
  8. Hi Harlequin:
    I can't believe you're laying on the planks already! Didn't you just finish the Greyhound? I thought I had a reputation for speed, but you've got me here - nice work - the yellow ochre works well to mellow out those brass parts - how to deal with that shiny brass is certainly a pressing question on my mind, though the Bellona is far away for me....I find myself wondering how the precise paint job you see on the box can be replicated, considering that there is absolutely no "tooth" to that brass to pick up the paint.....how did you get yours with such a nice matte finish? Did you treat the brass before hand in some way?
    hamilton
  9. Looks great Harlequin! If mine looks half that good I'll be well pleased. As for launching it against the wall - hahaha!! I have a miniature sledge hammer that I keep on the modelling table as I build, just in case....I've had it raised a couple of times and stopped myself at the last minute.....Anyway, great work - seeing her next to the Victory is really gratifying - must be even more so for you! Think of how it will look with the Bellona moored next to them!
    hamilton
