ClipperFan
Everything posted by ClipperFan
  1. Rob, I know I'm getting a bit of a deserved "rep" about being a pain in the *** for detailed accuracy. Believe me, it's not my intention to make your lives difficult as modelers. I'm just trying to maintain fealty to historic accuracy in order to be consistent to our initial stated goal of creating the most accurate version of Glory in every detail possible. Hopefully this will continue to unveil Glory's uniqueness as a McKay Clipper. Case in point this blurry image looks like it proves what I said about the main bilge pumps having a narrower mounting rail then the main fire rail. Otherwise how would the flywheels line up with the fife rails and also be mounted outside their own rails? Besides which, just from a "workflow" viewpoint, as long as the shorter crankshaft don't interfere with pump efficiency, wouldn't it make sense to inset the pump rails, so that the flywheels don't impede on working area around them?
  2. Vladimir, your yardarms are an absolute thing of beauty! It's amazing how graceful and symmetric they all are. Most impressive is how they're uniformly thicker in the center and gradually narrow towards the outer ends. I can even imagine how massive these critical spars must have appeared on Glory herself. Well done!
  3. Vladimir, Rob I took another look at this image of Glory's main deck, with specific emphasis on her bilge pump flywheels. At first, I thought it wasn't possible to determine whether her iron spokes were straight, like the 1886 Ship "Balclutha" or "S" curved, as we discussed earlier. Sure enough, when I enlarged the image it does clearly show that Glory's bilge pump flywheels did indeed have the "S" curved iron spokes and not straight ones. They're also narrower than the mainmast fife rails, since the wheels appear to align neatly behind them. Viewed from above, the fife rails look like they're a square and the bilge pump mounting would look smaller and rectangular.
  4. Vladimir, apparently your improvements are so impressive it's caused Rob to lose his dentures 😉
  5. Vladimir, nice work! Your fore companion looks so much more accurate and in scale now. In this case, less is truly more. Painting the fore house white definitely brings out contrast nicely. She continues to build into an impressive vessel. Great work!
  6. Rob, Wow!.... until now I didn't know that your vast modeling skills included levitation!! How else do explain not one, or two but three beautifully crafted yards seemingly defying gravity and floating in air? Oh by the way, Happy St Valentine's Day to all my fellow modeling friends, I hope you enjoy the day with a close loved one.
  7. Vladimir, like Rob, you're truly more of an artisan than a modeler. Simply beautiful work. If you're planning on angling back the fore companion, might I suggest you shorten it too? According to the deck layout, this hatch way is a little shorter that the fore fife rail. It's also just a bit closer to the front of the rail than currently positioned. Being closer to the fife rail would also draw attention away from the height of the forecastle too.
  8. Vladimir, beautifully done detail work on the windless, capstans and fore Companionway. It's obvious you put a lot of emphasis on the specifics of the Companion. Maybe it's due to your close up pics but I have a concern about the relative size of your Companionway in comparison to other deck fittings. While her deck profile in this image should be slimmer at the Bow, her deck fittings are for the most part very accurate. If you look at upper and profile images, you'll see that Companionway is no higher than the Foremast Fife Rail, matches width and is actually a little shorter too. Actually, when it comes to deck hatches, the Fore Companionway is the smallest of all. I hope I'm wrong and it's just the excellent close ups that make your nicely detailed hatch look outsized in comparison.
  9. Rob, as you described the careful consideration you're giving all the painstaking weathering details of just a single tightly furled sail, it's occured to me that you're transitioning from mere model making to an artisan. You may not recognize it yourself but trust me, I see it and I have no doubt that others would do so too.
  10. Rob, I never tire of seeing the beautiful detailed progress of your build, no matter what the pace.
  11. Kevin, an initial concern I had when addressing the enormous inaccuracies of the Mjelde plans was how to not offend Michael himself, as these were illustrations published in his books. Probably my biggest thrill was how gracious, understanding and generous he actually was in sharing numerous, rare, many never seen before images of Glory herself. Our efforts in attaining a far more accurate version of McKay's final Clipper is a tribute to the selflessness of Glory's greatest living promoter, who like all of us has as his ultimate goal to replicate "GLORY of the SEAS" precisely.
  12. Rob, Vladimir I wouldn't trouble myself too much over period accurate capstans. Unless it states in documents, either form could have been used. As for Footropes, from the viewpoint of modeling simplicity, I think real thin black wire would be easier to create realistic loops. Unless thread is seriously waxed, it will twist and contort in odd ways.
  13. Rob, Vladimir, as you can see, It differs greatly in appearance from the WD Grimshaw Capstan, patented November 28th, 1865
  14. Kevin, Rob has greatly enlarged a plan from one of author Michael Mjelde's book appendices. While the deck layout is mainly accurate, the deck's outline no longer is. That's because we discovered that Glory's bow profile is much slimmer at the entrance than previously thought. Vladimir might be able to produce one since he created the revised bulkheads with his computer. I mainly focused on her broadside profile. I can add too that from a never seen before Stern above shot of Glory docked in Alaska, graciously supplied to us by Michael Mjelde, we now know for a fact that her Rear Carriage House narrows to match the outer contours of her hull, with 5' passages on both sides which remain consistent Bow to Stern.
  15. Vladimir, you work quickly! The last I knew you had just a few yards done. I see too that the Mainmast now towers over the others. If you seriously want to "tease" how about a nice broadside. However with the size of your model, you may have to take those pictures clear across the room!
  16. Rob, according to her description in Boston Daily Atlas Champion as originally designed by McKay carried four sails per mast. It's most likely the daguerrotype was taken before the royal mast could be mounted. Still, four yardarms is a throwback to the old Ships of the Line for sure, as his earlier cargo Extreme Clippers all had five. Perhaps it's due to their intentional Passenger Ship designation that until "Donald McKay" all three of the Black Ball vessels built for the James Baines line had similar rigs, with exception that Champion was the sole ship without at least a Main Skysail. A big advantage of Howe's modification of Forbes design, it that it did away with the need to stitch upper and lower topsails together. Howe's rig also required less men to trim a vessel's sails. Looking at it that way, it may be McKay's way of lowering the actual number of sailors necessary to serve on board. Either way, all contemporary paintings of these magnificent Clippers depict them with sky sails mounted on all masts. So sometime in their service, they must have been re-signed to include them. As a connoisseur of Clipper Ships, I prefer them to have a full suit of five sails on each mast, four for some reason just looks.... awkward.
  17. Vladimir, A few years ago, my family was treated to a few cruises on Royal Caribbean vessels. Twice we embarked on "Majesty of the Seas" and once on "Liberty of the Seas." Ironically Majesty was a twin to the appropriately name twin sister Ship "Sovereign of the Seas" which was the largest Cruise Ship in the World at the time of her launch, which was way back in 1987. What I particularly enjoyed about both vessels was the romantic feeling derived from a sense of being on an elaborate movie stage setting. Everything was magnificent multi level views and especially on Majesty there were enormous but tasteful amounts of highly polished brass and gold metals. She was definitely a Ship of the 80s too. I agree about modern shipping vessels, they're just enormous but nothing beautiful to look at.
  18. Rob, Donald McKay was constantly experimenting with both Hull shapes and sailing rigs. Apparently both "James Baines" and "Champion of the Seas" like his first "Sovereign of the Seas" as well as "Lightning" all had Royals on Fore & Mizzen with only the Main sporting a Skysail. These ships were all launched before Howe's innovative split Topsail rig was introduced. However it appears McKay "went wide" instead. The Main Yardarm on Champion stretched 95' while her counterpart on the James was a staggering 100'! Topsails on both vessels were similarly immense.
  19. Vladimir, when you consider exactly what Lifeboat Davits are there for, it wouldn't make sense to dismantle them while at sea. It's one thing to mount boats on roofs but can you just imagine the utter chaos trying to desperately remount and re-rig your Boat Davits as the ship founders around you? However it also makes total sense that they need to be in a sensible position where they don't interfere with the operation of the ship. Rob pointed out to me the exact placement of the Davits on the outside of Glory's hull but I'm still unsure as to that exact placement so I would ask him for precise placement. While I agree it would be awesome to have been able to see a McKay Clipper in real life, I suspect it would be a huge shock to actually experience the demands of being a member of the crew on any American American Clipper Ship. The men as well as their Ships were all driven hard, "twenty four-seven." There's a reason that for a decade at least, American Clipper Ships dominated the Nautical World for record shattering journeys. But I too share a romantic affinity for these magnificent, impressive vessels. What I didn't fully comprehend until we did Glory's reconstruction, is how truly massive McKay's Clippers truly were. Even his first "Staghound" was the largest ship in the world when launched.
  20. Rob, I was attempting to show Vlad that mounting points for the Boat Davits were on the outside of the Hull, since he gave me the impression that he wasn't sure exactly where those Davits mount. In no way did I indicate the exact locations, only a general position. I chose Champion since the Boat Davits are so clearly visible.
  21. Vladimir, that's really nice work on those yardarm corrals. They look very realistic.
  22. https://www.google.com/amp/s/batgurrl.net/2021/07/03/demise-of-a-clipper-ship-on-endolyne-beach/amp/ Rob, Vladimir while looking for more images of Glory's bilge pump, I came across Michael Mjelde's deck plan illustration. It's also inaccurate as it shows the flywheels inside the main fire rail, while photos clearly show they were mounted outside. This is a somewhat poignant article and indicates her final resting place as well. Scroll through the images and you'll also see a magazine excerpt showing her beautiful figurehead described as being 90" tall.
  23. Vladimir, beautiful work on the Mainmast fire rail and bilge pump. The sole concern that I have is the gaps on your 2 pump flywheels. I've attached a link to the Baclutha website with specific focus on her Bilge pump. While Rob's correct that Glory's pump wheels mount outside the rail, Balclutha's mount inside. There are handles which attach to the wrought iron crankshaft, which similar to how an old Model T Ford's engine would be turned over is how the flywheel crankshaft would be turned over.
