Everything posted by grsjax
Interesting paper on the reconstruction of the lines and construction details of the Sutton Hoo ship. https://eprints.soton.ac.uk/438414/1/Tanner_etal_2020_DigitalReconstructionOfTheSuttonHooShip_AcceptedManuscript.pdf
That could be the issue but it looks like they are are the same vessel with identical markings.
Got a chance to look over the newer AL 1:35 scale Botter from AL along side the older 1:50 scale Botter. AL must have some weird measuring devices as the newer 1:35 model is considerably smaller than the old kit. Any ideas why this is so?
Not complaining, just looking for an answer. Why are Woody Joe kits so expensive? The look like good kits that are well designed a d as far as I have seen accurate. However so are many other kits that are not so pricey. What am I missing?
Anyone know anything about Craftbench Models? Ran across akit with that name on it? Can't find anything on the web.
I find myself in Nurenburg altstadt for a few days. Anyone know of a shop(s) in this area worth a visit?
While looking at a model of the Nonsuch I got to wondering about all the carving and gold leaf. When a ship like this was used for exploration or other hard use were the carvings removed and stored away? If so this would reduce weight up top and the easily damaged bits would be out of harms way.
Jig for planing planks?
grsjax replied to Pitts2112's topic in Building, Framing, Planking and plating a ships hull and deck
I think this has been mentioned here before but I will go ahead and mention it again. At least a few companies sell a fixture to hold a model by the keel to make it easier to work on. This one is sold by Mantua. They work really well for trimming planks. -
I have previously posted about interesting wood that I have found/harvested here in Hawaii. I am always looking to find new material for making parts. I was wondering if anyone else does the same in their areas. Please post info about unusual, strange or down right weird wood you have incorporated into a model. To start things off I will mention two woods I have used. Citrus x latifolia - 'Tahitian' lime This is the citrus tree not the Lime or Basswood common in models. Nice hard, tight grained wood with a faint yellow color. Hibiscus schizopetalus - 'Chandelier' Hibiscus This is a rather unusual ornamental plant that has bright red flowers that hang down and form a kind of lacey ball. Wasn't expecting this to be usable wood. However I dried a few pieces and found that the wood was fairly hard. The wood is light tan in color and carves easily.
Wonder if they are going to release a set of drawings of the boat?
Received some packages of scale rope the other day. Looks pretty good but it has a shine on it. Is this typical for rope made with polyester thread? Is there a way to reduce the shine?
Sheet Metal Shear Recommendations?
grsjax replied to DerekMc's topic in Modeling tools and Workshop Equipment
This is a smaller version of the one above. https://baileigh.com/manually-operated-mini-shear-brake-sb-8 -
I can't find a website for the manufacturer or a US outlet. This is a website that sells them and they are available from other places like ebay and Amazon. https://www.teslastrings.com/en/m/luban
I am always looking for wood from the area around me for model building. There are lots of articles and commentary about the "best" wood for modeling but the discussion seems to center the woods like Box, Cherry, Walnut, etc. There are a lot of different wood types out there and I think many that we don't think of as model building wood will work just fine. Bottom line is that any wood that is stable and workable will do. If a model is to be painted grain is not really an issue. If a model is going to be left unpainted there are many woods that will look good either with or without staining. Just my .02, please feel free to let me know what you think on this subject.
Mini Table Saw recommendations
grsjax replied to captainscott's topic in Modeling tools and Workshop Equipment
Check out the above thread. -
FaceBook miniature tools ads
grsjax replied to jmlyle's topic in Modeling tools and Workshop Equipment
Aliexpress has the drill press for ~$50. -
Not trying to hijack this thread but I do have a serious (maybe dumb) question about these kits. How does one tell the difference between v.1, v.2 and v.3 kits?
- 48 replies
I have several pieces of wood from a Gardenia bush that I pruned awhile back. Diameter is small with the larges I have being about 2" thick and very few of the pieces are straight for more than 5-6 inches. That said the wood is great. Very light colored with a straight grain and fairly hard. I am going to try making some parts from it and see how it works out. Anyone here tried using gardenia wood?
Considering the missing parts and parts that don't fit right you should contact Pavel and let him know about it. I know that some of his earlier models had issues that were corrected in later editions.
- 58 replies
- Santa Maria
- Ships of Pavel Nikitin
A quick search brings up a lot of different small drill presses. You might want to expand your search beyond Proxxon and Microlux. They are good products but I think cost a lot more than the benefits they provide.
- 53 replies
- Drill Press
- Milling
You might want to check out something larger than the mini drill presses that have been mentioned so far. This one https://www.amazon.com/WEN-4208T-2-3-Amp-5-Speed-Benchtop/dp/B08ZVT5JKC?dib=eyJ2IjoiMSJ9.-0oQbgDoyMKeUdrGAsEAIVg5RJz0T9P0iiEijuk1RN8lWGjsBcJh2U4Tj6ilqA1qMpFjjGhil9rkAX4vz_RMn111nHFcLRPQJX9Zp-IKcEzEEmpPOjsMZw1FC4g2kMTs-7rQj2VNkkmSfNdUnwPZbTfhKqXB0IiYQC-fJ1X9MhYUUXlSnz6bWEfuCQtjEdKILhvdMZzpZnuokAT3oJg-eBh-4_Uy_XvA9z_ye3RPNoUPOpDZ47Pu7QN66DC97G8SqQJqpmXYsMBLpUIo0D3N8lxJSbggKBn9XI_9RSlirkM266Qz_UwFMnZb_8b2oYIhJBPhBKuxoY-z8sFaJ4kgY8v0pv9mQqZgMOdIqqZDUpGKPj9KCdK6j_BhPJu4V7O0CrJlTZCAwMbubjHaI-09m60bIwE3rqG2KswEBwv1Hk0L-BjBQle2o28rBCwbb-_Z.b8Um8MN7cuRy2k2EcsFJPq8GjBdDKTtsRIK3tX2mtQo&dib_tag=se&keywords=mini%2Bdrill%2Bpress&qid=1736103704&sr=8-10&th=1 on Amazon has more power, stroke length and versatility than smaller ones and only takes up a small footprint on your bench. I have one and it works very well.
- 53 replies
- Drill Press
- Milling
