grsjax
Everything posted by grsjax
  1. I have several pieces of wood from a Gardenia bush that I pruned awhile back. Diameter is small with the larges I have being about 2" thick and very few of the pieces are straight for more than 5-6 inches. That said the wood is great. Very light colored with a straight grain and fairly hard. I am going to try making some parts from it and see how it works out. Anyone here tried using gardenia wood?
  2. Considering the missing parts and parts that don't fit right you should contact Pavel and let him know about it. I know that some of his earlier models had issues that were corrected in later editions.
  3. A quick search brings up a lot of different small drill presses. You might want to expand your search beyond Proxxon and Microlux. They are good products but I think cost a lot more than the benefits they provide.
  4. You might want to check out something larger than the mini drill presses that have been mentioned so far. This one https://www.amazon.com/WEN-4208T-2-3-Amp-5-Speed-Benchtop/dp/B08ZVT5JKC?dib=eyJ2IjoiMSJ9.-0oQbgDoyMKeUdrGAsEAIVg5RJz0T9P0iiEijuk1RN8lWGjsBcJh2U4Tj6ilqA1qMpFjjGhil9rkAX4vz_RMn111nHFcLRPQJX9Zp-IKcEzEEmpPOjsMZw1FC4g2kMTs-7rQj2VNkkmSfNdUnwPZbTfhKqXB0IiYQC-fJ1X9MhYUUXlSnz6bWEfuCQtjEdKILhvdMZzpZnuokAT3oJg-eBh-4_Uy_XvA9z_ye3RPNoUPOpDZ47Pu7QN66DC97G8SqQJqpmXYsMBLpUIo0D3N8lxJSbggKBn9XI_9RSlirkM266Qz_UwFMnZb_8b2oYIhJBPhBKuxoY-z8sFaJ4kgY8v0pv9mQqZgMOdIqqZDUpGKPj9KCdK6j_BhPJu4V7O0CrJlTZCAwMbubjHaI-09m60bIwE3rqG2KswEBwv1Hk0L-BjBQle2o28rBCwbb-_Z.b8Um8MN7cuRy2k2EcsFJPq8GjBdDKTtsRIK3tX2mtQo&dib_tag=se&keywords=mini%2Bdrill%2Bpress&qid=1736103704&sr=8-10&th=1 on Amazon has more power, stroke length and versatility than smaller ones and only takes up a small footprint on your bench. I have one and it works very well.
  5. New to me at least. Stainless steel and the grip is pretty strong. sizes available from 2" to 5". I find them useful for model building. I bought them off of aliexpress but they can also be found on Amazon.
  6. Message sent
  7. Hi
    Any chance of getting a copy of the plans?  I have a stack of pear looking for a good project.
    Glenn
  8. As requested here is the amazon page with the light on it.
  9. Ordered this from Amazon and am very pleased with it. Best work light I have found for model building.
  10. I have one from a different vendor. Same machine, different label. Works well and I have had no issues with it over the last 5 years.
  11. Haven't tried using clear coat. I let them age for a couple days before I try to handle them.
  12. I find that sanding and etching the parts with white vinegar then washing the parts in soapy water, rinsing in clean water followed by dipping in acetone then a rinse in running water as a prep works best for me. Your mileage may vary.
  13. I have a couple of kits in my stash and have to agree the instructions are not great. However it seems the larger kits are somewhat better. These kits are for people that have built several kits and are familiar with what goes where. Just start it and ask questions on MSW when you run into a problem.
  14. Anyone know what happened to Arkit and Dikar models? Were they taken over by other companies or just closed up shop and disappeared?
  15. You might want to take a look at brush plating. Seems to be the simplest method to do small parts. Caswell is the most common one but there are other sellers out there. https://caswellplating.com/electroplating-anodizing/brush-plating-products.html
  16. Depends on what you actually need the saw for. If you just need it to cut strips off of billets of wood and then use the thickness sander to bring to final dimensions any reasonably accurate saw will work. I have experience with the old Dremel table saw, the Micromark saw, old Craftman saws and a couple of off brand hobby saws. The Dremel table saw is pretty good if you update it with some add on that are available on line. The Micromark is good out of the box. Best saw I have for ripping planks is an old 8" saw from Sears. Sold under the Craftsman name but actually manufactured by the Seeley company. Cast iron and steel with a strong motor. Very solid and accurate with a good blade. I prefer a hollow ground planer blade for the best results. If the saw is in good shape you can get 1/32" strips consistently. I see them on ebay regularly for $50 to $200.
  17. Anyone know if Model Shipways is going to issue a plank on bulkhead kit for the Sultana? They seem to be do that to all their solid hull kits.
  18. A couple of mini lathes for sale on eBay. These are not mine, just passing along the info for anyone that is interested. https://www.ebay.com/itm/226173908145?itmmeta=01HZWW0J1MQBXTCHEG1BRE4FK0&hash=item34a903f4b1:g:fTcAAOSw0ORmXJz9&itmprp=enc%3AAQAJAAAAwLG%2BNfqUNjHSkM7%2BkY9JjK57%2BZtnZVXMIDpmA8JgrbxS6eONLETJ8UXVyfiJZZXImUoLRVPMNN%2F5NhYf%2B%2B5AqibV16veAH3ocRDWhUUzwV9hHxKBN4NQGn9xFwD8FVREAAIaEpE8MbmJ9BlZsB5zi6Pw1U%2BG7Rz97RLrRR3KNKMyMP%2BYbCQ7aCaa0xZpcTIPMwYI6s1i85%2FDppqqT%2BHRgQzNutBoIR2ZHMEFMtVuu8jSJoXBOk2TD8iIeY1ot3H5Nw%3D%3D|tkp%3ABk9SR4qhgpz_Yw https://www.ebay.com/itm/285893211189
  19. Did a bit of web crawling and found that the Jarmac is available from a number of vendors. Don't know if it is still being manufactured but seems to be plenty available. This one seems to be the "deluxe" version. Tiny motor but apparently fairly reliable. Motor can be upgraded with a new motor with the same form factor but twice the power. Going to mess around with it a bit and then pass it along.
  20. Anyone know anything about this table saw? I picked it up recently and there is no brand name or indication of where or who made it. Looks well made and solid. Sorry about the upside down pictures. I am not real good at graphic editing.
  21. It is available from various used book sellers but isn't cheap. About $170.
  22. Specs said the shaft turned in a brass sleeve. I assume that means the spindle but I could be wrong. Be interesting to take one apart and see how it is made.
  23. The specs on some of these micro drill presses states that the shaft turns in a brass sleeve rather than bearings. Should be ok for light work but I don't see anyway to lube the sleeve so for anything serious I would be a little worried.
  24. I agree with Cathead, a 2 foot model is good size for most homes. Smaller models are also a good thing as they can be displayed in otherwise unused spaces like bookshelves and hall tables. My choice would be models between 9" and 2'.
  25. https://www.ebay.com/itm/296173848539?hash=item44f55647db:g:JLIAAOSwE7Vlqgqj Not mine but I thought someone here might be interested.
