Everything posted by John Gummersall
Cathead and Brian Thanks for your comments. I appreciate them... As for my lack of posting...I really should stick more to ship building.... Seems all sorts of other stuff pull me away, but when I have time and in the mode, I always get back to it. As I do enjoy the builds. It sometimes takes me 1 1/2 - 2 years to finish a model, but they do get done. Here are the painted coke can smoke stack shields. They turned out OK I am sure I am the last one to learn this, but I will mention it anyway. When painting coke cans or etched brass for that matter, in order to get paint to stick well to either surface, you really need to first spray on some sort of "etched primer". This primer as the name implies, somehow etches the metal as it is applied and leave a very good base for later paints. I have found (the hard way), that just using a normal primer and then the final paint over metal does not turn our very well. It looks great initially, but when trying to apply the piece to a model, frequently some of the paint flakes off. Sanding the metal with 400 grit and the following up with an "etched primer" and paint leaves a pretty solid finish. I just used a rattle can of etched primer from hardware store, but I have head others talk about an actual product for spray guns call "SMS Etch Primer" that is supposed to be very good at preparing metal for paint. Starting working on the stern timbers and ran into a slight problem. Since I added the railing on top of the fence, you can not get the correct angle of the timbers to reach the vertical posts. Railing is in the way and there is no way to make the timbers match up with the vertical posts. Took a lot of humming and hawing, but about the only idea I could think of was to extend the vertical posts back over the railing as shown in the picture below. With the vertical posts now even with the back fence, was not to big an issue to make the timbers line up. Final result showing the stern timbers now lining up with the extended vertical posts. An other option, might be to have a break in the fence on both sides of the timbers. That might have looked better, but I did not want to destroy the already installed fence. Started working on the hog truss posts and caps Paddle wheel installed and cables. Rather than us the supplied thread I decided to us 22 gauge black wire. If you decide to use wire, 22 gauge wire fits the hog truss posts cap holes exactly. Turnbuckles have not been painted black Black cable over a black floor did not show up on all the picture, but hog truss posts, caps, and cabling complete
- 158 replies
- chaperon
- Model Shipways
Looks like I found an excuse not to not to work on the pilot house staircase.... Decided to finish up the paddlewheel... After aligning the spokes with a piece of wood shown in the rear, I started to add three board to each spoke just keep working your way around the spokes, until complete.. Now it is time for the staircase.... In looking a the picture earlier of the railing added to the pilothouse, I discovered I did not quite measure them correctly. They are a little high the horizontal beams and did not meet the top railing of the stairs. As such I had to add an extension on to the stairs to meet the pilot house railing. In the picture below, the pilot house railing should (if build correctly) align with the top of the diagonal hand railing. In my case, I have a little extra on top, Just needs paint, but all lines up with the skylight deck and the Texas roof. With paint added,,,, And attached to the hull.. As mentioned earlier, there was just no way I could create the tiny cones for the small smoke stacks. No matter what material I used, cardstock, paper, aluminum, nothing looked very good do to lack of skill on my part. For the cone shaped shield for the large stack, I took Brian's suggestion and used aluminum from a coke can. The aluminum is very thin an easily cut with a scissors. Since the cone shaped shield was larger (more my size), they turned out OK.. I strongly suggest you use this method when building your cone shaped shield... At this point the cone shaped shields are just dry fit. After all the rings and crown are attached these cone shaped shields will be applied, primed, and painted. On to the turnbuckles...As others have commented, the supplied turnbuckles are completely flat and cut out of the etched brass sheets. Kurt and others have made very elaborate turnbuckles that really look neat. Again, I made an attempt at it, but I just could not get the slot in the brass rod to be anywhere near smooth and not good looking at all. Instead I took the easy way out and just use 1/16" brass rod and inserted eyelets into each end. I would have preferred to use smaller eyelets, but these were all I had on hand. No were near as elaborate as others have made, but to me they get the point across and look better than the supplied turnbuckles (shown below on the far left). Just need some primer and paint. Any finally for this session, blackened the eyelets. Defiantly gives them that worn look.
- 158 replies
- chaperon
- Model Shipways
It will be interesting to see how the wire works out...I used 28 gauge wire and plan also use it on the other rigging. For the Hog Truss Posts rigging I planned to use 22 or 24 gauge wire. My hesitance is in the final look with the binding at the end of each wire. As I say,,, we will see what happens,,, especially in my (not so coordinated) hands. I was able to find the "CHAPERON" lettering and did the best I could on the lettering with my fingers. I used an extra fine point (.25) sharpie and that is the way to go. Just needed a little more hand eye coordination on my part. Also mostly completed the railing around the pilot house... In doing so, I noticed the platform was about 1/8" wider than the pilot house, which seemed strange to me. Going back over the instructions I saw the following caution "Note that the pilot house sides overlap the ends fore and aft". The pilot house should be 1/8" longer than wider. This not did not register with me when I built the pilot house as I just slapped the four sides. Thus my pilot house is 1/8" wider than longer.... and the discrepancy. Had I been thinking clearly at the time I would have just cut off the 1/8" and none would be the wiser, but what it the fun in that. Besides,,, as the old saying goes "why do something easy when you can make it hard". Since the platform extended 1/8" beyond the platform, I added a 1/8" post to the left door and extended the fence. For those looking at these notes in the future, I recommend you read the instructions and build the pilot house correctly 🙂 Below you can see the 1/8" post to the left door and the extended fence. Moved on to creating the stair structure to the pilot house. Process to create the structure seems pretty straight forward. Build the vertical and horizontal pieces over the full size drawing and include the temporary piece on the bottom to hold things together. I also added the railing at this time. As the instructions indicate, make the vertical posts a little longer than the diagram ... just in case. It will be trimmed later on when put up against the ship. Flip it over and add the two platforms. I would suggest not using the diagram for locating the platforms. Hold the pieces up to the ship and mark the exact locations. The upper platform should come in just under the the Texas roof and the lower platform butts to the trim piece on the side of the skylight. Only real way to insure this is to measure against your model vs the supplied diagram. In my case the structure is about 1/8" taller then the diagram. As mentioned above, leave the post a little long and trim to fit later on. On a side note,,,,I hate building stairs. I hated building the first two stairs on the Chaperon and am going to hate building these stairs. In a prior life I build the circular stairs on the King of the Mississippi model. To me none of them are fun. Trying to hold things together while inserting the steps to me is all sorts of (shall we say) fun. Anyway....stairs are next. Prior to the stairs, I decided to complete the outer rings on the paddle wheels. Only real challenge here is the the rings are so thin that you can easily break one just by looking at them... As me how I know that,, Paddle wheels with rings attached and painted As as long as I was in the area I completed the Cranks and Pitman Arms. Looking at the picture I see there is a little sloppy glue marks,,,,, Will need to touch that one up I guess I can not delay any longer...... Stairs to the pilot house will be next....
- 158 replies
- chaperon
- Model Shipways
Completed the railings on the boiler and hurricane decks. I used 1/16" square strips to lay on top of the railings. Levering them without a top just seemed not right. Only issue I had (do to lack of skill on my part) was creating the cones that are to go on top the the smoke stacks. I attempted them over and over again with different thickness of paper and just could no get them to look right. After completing the cones, they just seemed lopsided. I just could not see putting lopsided cones on top of the smoke stacks. As a compromise, instead of using the supplied dowel rods for the stacks, which really would have looked bad without the cones, I used copper tubing. To me they look like smoke stacks.... just not like the real Chaperon... Also completed was the trim on top of the Texas structure Next step is to complete the stairs going from the hurricane deck to the pilot house
- 158 replies
- chaperon
- Model Shipways
It has been awhile since my last update.... Summer activates and around the house chores has kept be away from the shipyard. Here are a few updates... Completed the Pilot House... With the exception of the "CHAPERON" lettering... I completed those a long time ago, but for some reason can not find them... Ugh... I will look some more next week when I get back to our home location, but I may have to start over and redo them. Not sure whey the below picture came out blue, as the pilot house is defiantly white.. I guess just pretend you are seeing a white pilot house 🙂 For the support wires, I actually used wires instead of the supplied line. It is 28 gauge wire Completed the lifeboats. Use 1/32 x 3/32 strips to plank the lifeboats. And the Stage is pretty close to complete. Just needs some blackened eyebolts It has been a long haul, but the end is in sight... A few more weeks (at the rate I build) and the chaperon should be complete.
- 158 replies
- chaperon
- Model Shipways
Brian, Thanks for the information.... I really appreciate it. I do not have any copper sheeting on hand, but I do like that idea instead of card stock. In the mean time, I will try my hand with the aluminum can.
- 158 replies
- chaperon
- Model Shipways
Started on the railing that go around the ship.... I was not looking forward to this as I was sure the hull (do to my poor building skills) was not going to match the curve in the etched brass railings. To my surprise the railings were pretty close to the curve in the etched brass railings. Some of the square stationaries were not exactly 3/32" high so they had to be filled down some, but for the most part the railings on the hurricane deck went on pretty well. As designed in the kit the railings looks a little thin and and do not have any type of place for you hand to rest. Just one skinny railing. I decided to a strip of wood on to of the railing to make them look a little more finished. I decided to use 1/16" x 1/16" strips on top of the railings. In order to pre-bend for the curves it runs out a laundry detergent cup is very close to the curve in the railing. A little soaking and a few clamps and drying over night, and the wood was very close to the actual curve in the railing. Below there are two strips being bent. One already painted the the other to be painted The old saying is try,,,,,, it is not possible to ever have too many clamps While waiting for those strips to dry and be painted, I decided to add some planking to the inside of the pilot house.... I just seemed a little stark with plan walls. On to the six rear smoke stacks. I started out using the supplied dowel rods and attempted to make the paper tops as described in the directions... I used stiff paper, but it was not as stiff as card stock. That may be my issue as i just could not make those stack tops look very good. They looked mis-shaped. At that point I decided to skip the paper tops, but then I could not use the dowel rods as stacks,,,, as they would look like dowel rods. Thus I cut some 5/32" and 1/4" copper tubing to simulate the stacks. They would not have the tops, but at least they would look more like smoke stacks than dowel rods. Below are the smoke stacks ready to be attached to the hull... I have since found some firmer card stock, so I will make a few more attempts at the stack tops, but I am no optimistic of the outcome.... Besides, the copper tubing painted black look pretty good as smoke stacks,,,, we will see what happens with my attempt at tops with card stock.
- 158 replies
- chaperon
- Model Shipways
Got to working with the skylight... Back when I was struggling with deciding on the type of roofing for the various decks (that simulate tar paper) I ended up gluing masking tape to the decks and painting over it. Here is a little "fun fact".... If you use masking tape, or tissue, silkspan to cover the roofs.... you need to cut away some of the material where the skylight attaches to the roofing Otherwise you are gluing the skylight to the material and not solid wood. After removing the weights holding down the sky light for gluing, guess what pops up? Ask me how I know this? Anyway had to remove what little of the skylight was still attached to the roofing, removed the roofing around where the skylight was to be attached to the roofing, and glued it down again. While I am no expert model builder, that was a rookie mistake and I should have known better. I bet that mistake will not happen again 🙂 Below show the 2nd attachment of the sky light Texas housing complete and glued on. The Texas roofing is in the background ready to be attached. I have a feeling I will not forget to remove some of the masking tape where the wheelhouse attaches to the Texas roof 🙂
- 158 replies
- chaperon
- Model Shipways
Cap strips and Hog Truss posts have been added and Chicken Coop Started looking into the smoke stacks and decided i wanted to use some sort of pipe instead of the dowel rods. Looking at other logs, others seem to imply they used 1/2" PVC pipe saying the outside diameter is 5/8" (same as the supplied dowel rod). I am not sure what 1/2" PVC dowel rods they were referring to, but the 1/2" PVC pipe I have has an outside diameter greater then 5/8". I did find at the local box store that the 1/2" PEX pipe is the correct dimension as the supplied 5/8" dowel rod. You can get a short rigid 1/2" PEX pipe about 3' long. As you can see it fits exactly to to outside diameter of the supplied dowel rod. This is what I will be using for the smoke stacks when I get to that stage in the build. Here is an interesting "fun fact".... With the 1/16" square vertical posts installed on the Hurricane deck, it is not possible to install the back stairs. With the posts installed, there is not room to slide the stairs into place from the side. Even inserting the stairs at the bow of the boat and sliding it all the way, back back, I was unable to right it into place. Only option was to remove one of the posts, insert the stairs, and then replace the post. Below shows post removed and stairs ready to be righted. Once stairs were in place, post was replaced Decorative support brackets have been installed... I have a lot to learn about painting brass... I am not sure what the story was.... I primed the brass and then followed up with at coat of paint, but as the decorative support brackets were glued in, some of the paint came off and had to be repainted. I am not sure, maybe I should have sanded (scratched up) the brass before priming it as it is really smooth. I can see why paint has a hard time sticking to it. I need to look into that for the future.. Anyway, below shows the decorative support brackets installed Sky light complete and ready for the Texas. Masing tape was used here too to simulate the tar strips Texas house almost complete. As with the Hurricane deck the Texas has 1/32" squares battens. And as with the Hurricane deck they are a real pain in the $#%@. Once all the battens were in place, just needs a another coat of paint and the doors. And the top to the Texas. Again masking tape was used to simulate tar strips
- 158 replies
- chaperon
- Model Shipways
Brian, Thanks for the comments... I am no where near in the same class of builder that you are, but I have fun with it. Here is a picture of the final Buckwagon. If you care to see all the gory detail, below is the log https://modelshipworld.com/topic/35314-western-mountain-buckboard-by-john-gummersall-finished-model-trailways-112-scale/
- 158 replies
- chaperon
- Model Shipways
It has been about four months, but I am back.. Took a little break and worked on the Western Mountain Buckboard model. It is what I call a "quick win" and just want I needed to re-energize myself. Back to the shipyard (Buckboard is not a ship).. Just about completed the boiler deck stationaries (ran out of painted posts) and started the cap strips. They were previously bent and painted. Just waiting for the boiler deck stationaries to be completed.
- 158 replies
- chaperon
- Model Shipways
Only thing left to do is mount the wheels and add the large nuts to the axle (to keep the wheels on). The four large nuts are made/cut from the same rubber like material used for the outside of the wheel. Instructions all to glue two of them together to make what looks like a large nut. Below shows eight rubber nuts guided together to form four large nuts. Mount the wheels and add the nuts to each axle, holding the wheels on. If you look close you will see one of the nuts inside the hub on the axle. With at, all that is left to do is add the whip and I am "calling it" done... For anyone you is interested in building the Buck Wagon, below are a few points to consider. All of these have been mentioned above along the way, but here is a summary. 1) The 3/16" bolts are too short of many of the places that call for 3/16" bolts. Before you begin, I would contact Model Expo and have them send you some extra 1/4" nuts. They easily fit in those spaces the 3/16" bolts are too short. 2) The supplied nails are way oversized and the heads are cone shaped instead of flat. Since the bottom of the wagon could not be seen, I decided not to use them there, but by the time I reached the wheels, I still could not see using the supplied nails. For the wheels I purchased much small nails and they worked great. If you are going to purchase smaller nails, purchase enough to cover the bottom of the wagon too in addition to the wheels. 3) The Reach plate assembly (to me anyway) was really unclear. I studied it a long time (way too long) trying to figure it out. It finally came to me, but unless you already know about Reach plates, you will spend some time trying to figure it out. Hopefully some of the pictures I supplied above will help. 4) The axle coupling (not sure what purpose it serves on the wagon), really should be on the front axle. Diagrams are not real clear as to the exact size and location of the front axle clips. Be sure to fit one of the longer clips on the outside so to have room for the axle coupling. For me it is back to the Chaperon Riverboat. I was about 3/4 they way though that build and I needed a break. I took on the Buck Wagon as a "quick win" and a break from the Chaperon... Have been revitalized, I am going back to the shipyard and complete the Chaperon.
On to the wheels. All four wheels went together very well and stained As mentioned early on, the nails supplied are grossly oversized. Earlier I mentioned skipped them on the underside of the cart. but the wheels really needed some sort of nails. I went out an purchased some smaller nails that fit the bill perfectly. Holes were drilled between each spoke and a nail (with black painted head) was inserted. Below you see some of the nails with sticking out of each wheel. After all nails were inserted, they were clipped off the outside of the wheel and files smooth. Final version of one of the wheels with nails cut off, rim cleats added, and gasket material added on the outside of the wheel. At this point instructions all to cut little swales between the nails on each spoke. Sounds good in theory, and it actually looks good in the pictures, but someone of my skill just could not handle it. I started out making the swales (about 10 or so), but I just could not get them consistent looking. Seemed each swale was different and the overall look was horrible. I took some wood filler and covered up my mistake. So my wheels will not have the swales. What you see below is how they are going to look. On to the apron... Not much to say here... goes on pretty easy. Likewise with the luggage rack.. Only thing I will say here is with these two parts, and like the other Britannia parts with the model, they are so thin that they bend out of shape just looking at them... Lots of fun with Britannia 🙂
There are two parts to the cart that are not mentioned in the instructions... Axle Couplings and Wheel Rubs. They are shown in the diagrams, but not very clear (to me anyway) as to where they belong. Below are the Axle Couplings (in black) and Wheel Rubs (in red). I contacted Model Expo in requesting a picture of their cart showing the location of these parts. The below picture was returned. Note the location of Axle Couplings (in red) and Wheel Rubs (in green). A picture is worth a thousand words. At this point I have an issue. Looks like the Axle Couplings only go on the outside clips of front axle. When I assembled the front axle, the front axle diagram showed all the front axle clips to be "about" the same size, with each one a little longer. If you look below, the diagram shows the clips going from short to long on the axle from outside to inside. My problem now is the short clips at the end of the front axle are not long enough to hold the Axle Couplings. I think at this point I am going to skip them. I am not even sure what they are supposed to do. To me an axle coupling function to join two shafts together. From the picture they do not seem to server any purpose. Put them on if you want, but to me it is not worth (at this point) switching some of the longer for shorter clips just to add the Axle Couplings. Below show the Front Axle clips I mentioned above. As you can see, it shows the clips going from short to long on the axle from outside to inside. If you follow the instructions (as I did), you will not have room for the axle coupling fittings on the outside clip. Not a big deal, just swap the last two clips and you will have plenty of room and the shorter clip will fit just fine as the 2nd clip inward. As for the wheel Rubs, they have a couple small holes in them for bolts. Bolts do not go through the deck. Cut the heads off some small bolts and inserted them into the holes to show they are bolted to the underside of the cart. Wheel rubs with small bolts stuck through the holes And with the bolt cut off Anyway, I just wanted to insert this topic on the Axle Couplings and Wheel Rubs as it is a little confusion as to where they are located. Hopefully this will help someone down the line.
Completed adding the spokes to the wheels and doing some fine tuning on the spokes. I have have made a mistake earlier when I indicated that it would be easier to do the bulk of the spoke trimming before they were glued into the wheel. Turns out that may not have been the case. While doing the fine tuning, it was easier then I expected and the spokes are well glued into the wheel. I might suggest following the instructions (who does that?) and do all the trimming of the spokes after they are in the wheels. Still have to add the tire bolts, round the edges, and re-stain, but these wheels are close to being done. Speaking of tire bolts, they call to use the same nasty nails that were supplied for the underside of the carriage. For these I ordered some more appropriate size bolts. Hopefully they will arrive in the next few days Nearing the end. Below are a few pictures of the current status. Will still need to touch up the paint here and there at the end. All Reach Assembly parts have been added. A couple close ups of the forward Reach Assembly parts. And some overall pictures of the current status Rear view Front view And a couple overhead shots Next plan to add the Luggage Rail, Apron, and whip
Prior to completing the Reach Assembly, I decided to take a break (for my eyes) and move on to the wheels. Assembling the Reach Assembly, with all the tiny screws and bolts, is defiantly not for weak eyes or large fingers. Quite a challenge. Instructions call to cut out the "life size" wheel patterns from the diagrams and use them on the jig to assemble the wheels. Here is an interesting "fun fact". The life size diagrams are not life size. Note below the outer edge of the wheel only matches up with the inner edge of the diagram. Over time either the wheels have gotten smaller or the diagram grew. Not a big deal as only the inner portion of the diagram is used to position the spokes. Not sure why I even mentioned this, other than an interesting "fun fact". For some reason the instructions call to assemble and glue all the spokes into the wheel and then trim them down to an oval shape. At my skill level, to me that is asking for trouble. Instead I choose to trim the spokes down before they are assembled into the wheel. Maybe after assembly I will do some fine tuning of the spokes, but the bulk of the trimming was done prior to assembly into the wheel. One thing to watch out for... As you might expect the wooden wheel is pretty weak prior to adding the spokes. Instructions call to clamp it down to the jig with four clamps. That part is good, but before you start gluing in spokes, dry fit four spokes (at opposite sides) to verify the wheel has remained round. Even though it looks round, chances are when adding the clamps it became a little out of round. The spokes are exactly the minimum length. If the wheel is any out of round, the spokes will be too short on at least one of the sides. In fact, initially when I was dry fitting them, the wheel was a little out of round (but not to my eye) and I thought the spokes were too short and I would have to make all new stakes. Fortunately I realized the clamping put the wheel out of round and corrected it so all the spokes would fit. Even then, with the spokes being the exact minimum length they are barely were long enough. It have been helpful if the spokes were a little longer. Once you have verified the wheel has remained round after the clamps, then start gluing them in. I choose to glue in two at a time on opposite sides.
Starting on the front and rear axles. Below is the result of gluing the wood axle caps on both axles. This is a good time to dry fit the wheels hubs onto the axles. The instructions do not call for this until the very end of the build when you are attaching the wheels. In my case, the wheel hubs did not slide onto the axles. The axles were a little thick vs the hole in the hubs. The axles had to be filed down some so they would slide on. Much easier doing this now than at the end when the cart as been built. Note on the front axle, behind the large hole for the King bolt, should be a very small slot in order to later apply the brass rod that will eventually be bent around the head plate. Verify at this point the brass rod will slip behind the hole for the King bolt. You may have to use the small drill bit and enhance the slot. Read Axle attached to the read spring bar Moving on the the Reach Assembly. Do to my limited skill, this section was about a clear a mud as to the process. I am embarrassed to admit how many times I read this section and and studied the plans before I figured it out how all the parts went together. And even then, I did not follow the process. Instructions seem to indicate to build the reach Assembly on the cart one piece at a time. To me there are just too many really small parts that need to be (shall we say) "adjusted" to get to fit together as part of this assembly. I found it easier to build the reach assembly outside the cart and then just insert it into the correct position on the cart. What makes the process confusing is that there are a number of parts that all have to come together just right in order for all the bolts to line up. Since we are dealing with the bottom of the cart there is one picture of the cart inverted in the instruction manual and there there is the one diagram of the cart that is not inverted. Between the two pictures it is really easy to get confused as to what you are dealing with. In all fairness to the instructions I guess they did a pretty good job describing the process, just that it was hard to understand the process with only these two pictures to go on. A few more pictures of this process would be really helpful. Starting to build the reach plates.. On the lower reach plate there are two holes that need to be drilled out. Final reach assemble ready to be inserted into the front spring assembly. While working on the Reach Assembly I started priming and painting the wheel hubs
Began to assemble the seat... No real issues here other than be sure to drill you holes straight or (as mentioned before) you will have an issue with room enough to apply the nuts on the bolts. And just to see how it will look I dry fitted it on the the chassis. It was then removed as it it too early to glue the seat to the chassis. Went on to add the front and rear steps and the rear spring. Rear spring took some fiddling to get it into the correct shape. Finally decided the best way to do it was to secure both feet to a solid surface. From there it was relatively easy to adjust the two springs. Once again I learned painting the Britannia before it has it's final shape is a waste of time. You just have to repaint it again. The end result. The spring on the left is better than it looks in the picture. Not sure why it looks so out of shape
The kit is supplied with various size bolts, the smallest ones are 3/16" and 1/4". They come attached to a single pieces of metal and need to be cut off (as shown below). The problem is they are way too short. They are supposed to be long enough to go through the designated part and be long enough to put a nut on the other end. As I started out every place I put a 3/16" bolt it was not long enough to reach the nut. In many cases I had to just glue the nut over where the bolt was supposed to extend. I finally got smart (way too late) and just started using the 1/4" nuts every place it called for a 3/16" nut. Problem is, I will run out of 1/4" nuts. Since this was Model Expo (and they easily replace missing or broken parts), yesterday I requested extra 1/4" nuts. They should show up in the next week or so. If you are starting out on this model, I would suggest right away asking Model Expo for extra 1/4" nuts.. you will be glad you did Started on the seat. Main "gotcha" here (and it got me) is with drilling the holes for the seat rail. You drill from the inside out. That part is easy, but the holes are so close together, that unless you drill the hole exactly parallel they there will not be enough room on the outside to put the two nuts. Here is the seat from the inside And from the outside. If the holes are drilled correctly the nuts should be next to each other. But if they are off at all, there will not be enough room for the two nuts. In my case, since I did not realize this until I drilled the holes, about all I could do was fill off the bolts and just glue on the nuts, like the bolts came all they way through. Seems that one nut needs a little touch up paint Bending the apron wood and attaching the right angle bolts is pretty straight forward Front side Back side Front spring bar attached to the chassis is pretty straight forward Underside view Top view
After a lot of Britannia cleanup I decided to prime/paint all the metal parts. Took some time to get this point. Almost every hole on each Britannia part had to be reamed out with the #55 drill bit. In addition many of the skinny parts had to be re-shaped to be close to the final shape they would take on the model. Below starts the primming And after the final coat of black. At the time I felt the best way to deal with all the small nuts on the brass was to prime/paint them in place and then separate them. That turned out to be a waste of time. Priming/painting went great, the problem is when you remove the nuts from the brass there are a couple little "tags" on each nut where it was attached to the next nut. In the process of filing off the "tags", all the paint came off. In the future I would suggest, first separating each nut, file the smooth, and then mount each on a toothpick for painting. That way after painting not additional handling is required prior to putting them on the model. Below you can see one of the painted nuts cut from the brass. By the time you trim off the tabs, to look like the nut on the left, all the paint is gone. Thus the toothpick method mentioned above is best for these nuts At this point comes my (shall we say) first "executive decision"... On the bottom side of the base there are 65+ little holes to where nails are to be inserted. Below you can see both the large and tiny holes. Supplied nails are to be inserted into these tiny holes, cut off from the other side, to where only the nail heads would show on the bottom of the buckboard. These nail heads will only be seen if one picks up the buckboard and looks underneath. As you can see below, the supplied nails and no where near consistent in size. I put a few in and they looked terrible. I just could not see putting in 65+ of these nails that would never be seen. Not only are they ugly, but some if the tiny holes are so close to the edge, I can easily see splitting the wood. To me it was just not worth all the pain for what would be an ugly mess. Thus I choose to skip these nails. If one really wanted to build the model correctly, I would suggest ordering some good nails from Model Motorcars. They are somewhat expensive, but they are high quality nails and would look much better than what I have going here. Even from the side view, the heads just do not look right Moving on to building the seat and platform brackets. Instructions call to build a simple jig to assist in drilling the holes in the seat and platform bracket. At first I was a little Leary of this jig, but it turned out to be simple and every accurate. The only issue with the seat and platform brackets is the instructions call to insert the 1/4" and 3/16" bolts (circled below) after gluing the seat and platform brackets to the seat springs. Problem is there is not enough room between the spring and the bracket to insert the bolts. Thus you have to bend the Britannia springs out of shape, insert the bolts, and then bend the spring back into shape. Bending these Britannia springs (without breaking them) is it's own form of excitement. I would suggest gluing in the bolts before attaching the seat and platform brackets to the springs
Not much to really report today...... Started inserting the boiler deck stationaries. As Cathead mentioned on previous post, putting a square stick into a round hole works out pretty well. Just the smallest touch of glue and the stationary easily slides into place. 1/4" above the huricane deck was easily maintained with a 1/4" piece of wood as a guide As you can see toward the middle of the boat the hurricane deck flared up a bit on the overhang and to be (shall we say) persuaded with some jigs to keep the proper curve. Same jigs used between the main deck and the boiler deck were modified and did the job well. Once glue dried, the hurricane deck was in the correct position. Closer look at the stationaries... No big deal.
- 158 replies
- chaperon
- Model Shipways
Cathead, I agree with what you are saying... As I tried to dry fit some of the square stationaries into the round holes, those little extra bits of tape really help hold the stationary in place. With the hurricane deck glued down it was a simple thing to slightly lift up the aft portion of the deck and slip in back wall. For those that follow in the future with the chaperon... when building that back wall, the jig provided is good in helping with the curve, but not that accurate. Even my "juice can" method (mentioned earlier) is rough... No matter how you bend the walls, the most crucial point, and it really should emphasized in the instructions, is that that back wall curves need to match the last holes in the boiler deck floor. Otherwise the wall will not match up to the last stationaries and will just looks off. Had I know that fact when I was bending the walls, I would have insured the final bends matched the last stationary holes. In my case even with a little fiddling, the wall does not match up exactly to that last stationaries. At this point I think I am going to leave it as is..... But don't make the same mistake. This could have been better had I know the exact bend was critical As for the bow and the forward stairs, as mentioned earlier, save yourself a lot of grief and do not mount the stairs prior to the hurricane deck as stated in the instructions. Once the hurricane deck is down it is easy to slip it into place. No way could I have glued those stairs in prior to the hurricane deck as expect them to line up exactly
- 158 replies
- chaperon
- Model Shipways
