Everything posted by Matt D
I’ve spent some good quality time in the shipyard the past week and a half and wanted to update my log.I added the rubbing strakes after using the bowl trick to get a nice curve in them. With the added width of the rubbing strakes, my model no longer fits in the temporary cradle I had built. Rather than spend time on fixing that, I built the stand I plan to display it on. I really like the launch that Peter built (SardonicMeow), but I wanted something more like a dry dock. This is what I came up with out of wood I had laying around. Of course, the awkward part is going to be when it’s all done and it’s sitting in dry-dock with unfurled sails.
- 68 replies
- virginia 1819
- artesania latina
It looks great, Peter! Thanks for sharing it.
- 222 replies
- sultana
- model shipways
I ruined my rubbing strakes. Somewhere along the way, I used two of the rubbing strake applewood pieces where I should have used mahogany. So I didn’t have four matching pieces. I decided to stain them darker so they would all match, but I overdid it on darkness. So I had to cut new 2x3mm strakes out of some larger applewood stock that I found at the hobby store. Here’s a pic of the dark stained original and my four fresh cut replacements.
- 68 replies
- virginia 1819
- artesania latina
Peter, I love your transom windows. They look really nice. I especially like The way you built the assembly up.
- 222 replies
- sultana
- model shipways
Happy Easter! Here are some pics of my recent progress on the second layer of planking. I’ve done some sanding on the port side to see how it would smooth out. I’m pretty happy with it and hope I can do as well or a little better on the starboard side.
- 68 replies
- virginia 1819
- artesania latina
QUICK-FIND INDEXES to BUILD LOGS FOR KITS
Matt D replied to Dan Vadas's topic in - Index of all kits by brand and subject
Hi Danny. I saw that you’ve changed the index for wooden ship kits from pdf to xls. For some reason, the links don’t work for me now. Have you heard this from others? Or am I doing it wrong? -
Hi Mark. You have a sharp eye. I have had that happen on almost every strake starting at about the third one going down from the top. The compound curve causes it to want to pucker up just slightly. There's very little stretch in these planks, unlike the first layer. So on each spot where that happened, I used a paint brush to push extra glue under the popped out section and then taped it down good and tight to dry. This photo must have been before I glued that one down, because it's tight and secure now. Thanks for your attention to detail and for pointing it out.
- 68 replies
- virginia 1819
- artesania latina
Thank, Wallace and Nikbud. I didn’t come up with that idea on my own - I learned it from your logs (and others).
- 68 replies
- virginia 1819
- artesania latina
I’m working on the second layer planking. I’m using PVA brushed on with a dampened paint brush. Then I tape it with blue painters tape until it dries. It’s a slow process, but it’s very forgiving: I can make adjustments if I don’t like how it goes on. I was thinking about CA to make it faster, but I don'twant it to dry fast in the wrong position.
- 68 replies
- virginia 1819
- artesania latina
Wow, Peter! Your model looks amazing! I’m following this and really like your work.
- 222 replies
- sultana
- model shipways
I had to travel for work last week and wasn’t able to work on my model for a few days. Before I left, I added the bulwarks. Today, I installed the upper stern piece and added some wood filler to smooth out the hull before planking the second layer. After getting that done, I made wooden bitts to use instead of the metal ones that came in the kit. They came out pretty good after a few tries.
- 68 replies
- virginia 1819
- artesania latina
Sardonicmeow, Wallace, nikbud: thank you very much for your answers. I will confidently sand away this evening.
- 68 replies
- virginia 1819
- artesania latina
I’m finished with laying the first layer of Hull planking and working carefully on preparing for the next few steps. I still have more sanding to do and then some filling. I’m looking at the bulwarks and the transom/upper stern. The instructions are not very clear on how the upper stern and deck beam mate up. The deck beam piece flares out and is slightly wider than the back of the deck and the upper stern. I think I need to sand it to the same width. It also interferes with the bulwarks, so something has to go. Since unsanding is hard, can any previous Virginia builders tell me what I should do to get a good result?
- 68 replies
- virginia 1819
- artesania latina
I’m not quite done with the barrels. I started by making stave joints with a pencil. I tried backing them up by cutting into them with an exacto knife, but I couldn’t really get much effect, so I left them like you see the lines. Then I stained them with Minwax Gunstock stain. I was planning on using golden oak, but really liked the gunstock color when I was at the store. I also found some 6mm wide Tamiya masking tape, which looked really skinny when I bought it, but is actually closer to a mile wide when compared to the masking needed for the barrels. But it cuts nicely with an exacto knife with a straight edge. Masking was tedious because of the shape of the barrel. I used black acrylic paint with a fine brush. After it dried, I pealed the tape only to find that half the bands were too narrow. So I had to tape them up again and paint some more. I still wasn’t happy, so I tried filling in with a sharpie marker and that’s when I learned that I should have skipped the tape and paint and just used a sharpie. I still have a little more touching up, but I have to be in the right place mentally so I don’t mess them up with an errant mark.
- 68 replies
- virginia 1819
- artesania latina
Here’s a picture of my work as of this morning. I hope to get some time to work on it some more this evening.
- 68 replies
- virginia 1819
- artesania latina
Thanks, Stevinne. I have that book and I’ve read most of it. But I had mostly been going by the AL instructions and many build logs. I had not connected the dots on figuring out the plank tapers early on, but now see some really good examples in other Virginia build logs. I’m not stripping off the upper section, but I did pull off the three stakes at the keel. Looking more carefully at other people’s first layer, I didn’t think what I had would mate up well with the keel extension. I then faired the bulkheads as advised. Then I went a little further and did a little bit of sanding on the remaining planks. I think they look pretty good, but I didn’t take any photos yet. Constructo Enterprise is one I’d like to build some day.
- 68 replies
- virginia 1819
- artesania latina
I decided to strip off the bottom three planks on each side because that seems like the area I have the biggest problem. I’m sanding that some more and then I’ll work my way down from the top the way that Robert Vaglio did in his build. Thanks for giving me your honest opinions. It won’t be any fun if it turns out like crap. Oh look: I’ve made it to page two!
- 68 replies
- virginia 1819
- artesania latina
Mark, thank you for pointing that out. I thought I had faired it enough with the work I did at the bow. I didn’t go over each bulkhead with a block and instead sanded through all of the laser burning. I thought that would suffice, but I still have a lot to learn. I’m not going back and I think it will be ok because I have a decent contour now. If I had it to do over, I would have blocked the bow and stern to give me more wood to glue to in those areas.
- 68 replies
- virginia 1819
- artesania latina
Thanks for that tip, Nikbud. I’m still going slow and steady on the first layer planking. I lost my modeling time to taxes yesterday. Somehow, I don’t enjoy that as much as ship building. Here are a couple of shots of my progress today. I’m hoping to get one more piece on each side later today. Then I might get the last two on tomorrow.
- 68 replies
- virginia 1819
- artesania latina
I’m still progressing on the first layer of planking. I have four strakes per side to go. I’m also working on the caronnade rigging. I think I’m going to need a needle threader to get the line through the tiny holes in the blocks.
- 68 replies
- virginia 1819
- artesania latina
Thanks for the line info, Martyn and Peter. I checked and found that my favorite local hobby shop has the correct AL lines for this kit. So I won’t worry too much about running out.
- 68 replies
- virginia 1819
- artesania latina
I’m taking it one strake per day with neatly cut tapers and getting them a lot tighter. So I started working on the blocks for the cannon and I don’t like the thin wire in the instructions. Instead, I’m using the 0.25mm brown line to tie the blocks to the eyes. My method is to tie a two half hitches knot and back it up with a drop of CA. But I was wondering if I’m likely to run out of that line. Is the amount of line provided with the kit generous or do I need to use it sparingly?
- 68 replies
- virginia 1819
- artesania latina
I spent a little more time reviewing other Virginia builds for planking and decided I needed to back up a little bit and taper mine at the bow. You can see in the photo from my last post that there wasn't any tapering at all. I thought that would be OK because it was looking a lot like the pictures in the instructions. But I changed my mind when I started looking at the quality of other people's builds. The thought I kept having is that you can't build a good house on a bad foundation. It was painful pulling off the glue joints where I needed to cut the tapers. The first cracking sounds made me question my judgement, but I think this is the right thing to do if I want my model to come out good enough to display. From here, I'm going to spend a lot more time shaping the planks the rest of the way.
- 68 replies
- virginia 1819
- artesania latina
Thank you for pointing that out to me. I was able to pop them free where the clinkering was and glue them down better.
- 68 replies
- virginia 1819
- artesania latina
Thanks, Stevinne. I’m glad to have found this forum to share with.
- 68 replies
- virginia 1819
- artesania latina
