LyleK1
Everything posted by LyleK1
  1. Dziadeczek is completely correct! I tried loading some pictures for you but I get a system failure... assuming it's the website since I can open them on my computer
  2. Making some progress... a little slow but getting there! My rope hanks have improved as I continue to use the same method as I posted. Still not 100% happy with them... Definitely an improvement over my first set. Finished the box that hides my lighting wiring, switch and battery: Not particularly anything special but serves its purpose. I need to make about 40-50 more hanks and am working on the touch-up. Still have the barrels to finish and get everything staged on the below deck portions. Getting closer!
  3. I've been working on a lot of projects but am also getting time in on the Bounty... Doing some touch-up and building a box for the wiring, switch and battery of my light system. But the biggest headache has been making rope coils or hanks! What a pain in the ***! I have attempted several methods and frankly, I don't like any of them... none of them look natural to me. It might be the fact that I make my own rope or maybe I just haven't found a good method. I have settled on one for the moment that gives me results that I may have to live with... If any of you have ideas or suggestions, please do tell. For the record, this method was provided by Peter Burton on YouTube I started out by making this jig, I can do 10 hanks at a time: I measured the length that I wanted the hanks to be and came up with the distance between nails. The holes are drilled slightly larger than the nails so that they can be removed easily. I also put down some clear tape to keep the hanks from getting glued to the board. Next, I wound my rope around the nails: This method seems to be the best for keeping the waste to a minimum... Once the rope is down, I use a diluted PVA glue (Elmer's) to coat the entire hank and then left it to dry. Once it was dry, I pulled out the bottom nail while holding the hank down firmly with tweezers and then pulled the middle nail. The top nails can stay in place. Using the tweezers, I gently removed each. Using the tweezers, by passing it through the hank, I grabbed the top loop and pulled it through the hank before placing back on the nail: I then put another drop of diluted PVA on the top loop where it meets the hank. Letting them dry completely before installing them. Here are the results: Not completely happy with these but as I stated, these are the best I've made and after a pretty thorough search, I just haven't found a better solution! Would love to hear your thoughts!
  4. After 4 years and 1300 hours of work (albeit with a hiatus in between), I completed the build portion of the HMS Bounty! I still have touch-up work, detailing (a lot!) and staging to complete along with building a case but the actual build was completed today! I will continue to update as I work through the next several weeks to finish her up. Pictures:
  5. Jib sails in progress... These are the last sails I'll be mounting on this model... one more to go! Installing the rings after "aging" them. Rigging lines installed and ready to mount. Mounted and rigged Second one finished! One sail left and final rigging... lots of final rigging!!
  6. Thanks for the support! I do appreciate it... it is a process getting back into this work. My fingers and arms have forgotten how to be steady and my ham handedness is making life a bit more challenging as I move on! So, a little slower and some changes to reflect the changes in my attitude! After much thought and actually hanging a few of the sails between the fore, main and mizzen masts, I decided I don't like the look for my finished product and have removed them altogether... I think the look of the rigging and deck and having the ability to see it without those sails is an improvement... for me! It may not be for you! Having said that, I finished the Mizzen mast and sail with the exception of a few lines that will come up in the next few shop visits. A couple new pictures: Next update in a few days!
  7. My first build up date in a long time but I am finally back at it. Finished up the sails on the Mizzen mast and hung one between the foremast and the Main mast... Gonna take some time for my fingers to get back in the groove! And for my hands to quit bumping into things! It has felt good to get back to work and I look forward to making more progress over the winter. Still planning to finish this winter but a lot left today. Especially, the finishing and detailing work. Couple pics below:
  8. Great start Kevin! I'm from one of those logs you mentioned, that hasn't been finished... Long story but after a hiatus, I've returned to finish her up. I look forward to watching your progress too. Best of luck! Lyle
  9. It has been a while... I lost my wife a year and half ago. It has taken some time to get my life back on track! I've finally gotten to the point that I am looking forward to getting back to work on the Bounty. I've spent the last several days dusting her off and re-familiarizing myself with where I left off. Did some new lighting in the shop to help with these older eyes and sorting through the tools, etc. Ready to get back at it! I expect to do some sail work over the next few days and weeks and will begin posting updates again very soon.
  10. Good to see you back at it! I just restarted mine as well... been a few months and i need to get back up to speed but it won't take long!
  11. Clumsy and not paying close enough attention... it happens to the best of us! I appreciate your thoughts... no changes at home... unfortunately. However, I do have some help and wandered back to my workshop a few days ago! Although, I cannot spend as much time as I was on her... expect to see some updates again in the near future. The Bounty will get done!
  12. They are on the stern... but I get your question. I used a brass tubing which is softer and easier to work... using a small amount of heat and a thread spool as a form, I just heated it up and bent it around the spool. As a side not, unfortunately, I bumped the starboard side tubing during some of the rigging work and broke the wire going to the light in the lantern... about made me cry!! I tried for several hours to get a piece of the wire pulled out to reconnect it... in the end, I had to give up... just is not possible. Makes me sick! But stuff happens!
  13. Just a quick update... Some times in life we are dealt a hand that doesn't seem fair! I'm dealing with that right now as my wife is very ill and I am spending most of my days caring for her. The Bounty is on hold for now but not forgotten and I will finish her but priorities come first. Hope all of you have a Merry Christmas and a Happy New Year! I see you all then!
  14. Takes a bit to get back into things! But after a few days of familiarizing myself, I got moving on finishing the main mast. I decided to furl the sails on the main mast. It keeps the sails and associated lines present but leaves the ship more open to viewing. And it still meets the look I am trying to achieve Here are a few pictures with top gallant and top sails essentially done and the course sail in progress with the lower yard just installed today: And off we go! More in a few days as I am focused on getting through the build by years' end... but not rushing it!
  15. Back at it! A month in Europe and a week of jet lag! Updates coming soon!
  16. Welcome back!
  17. So for this update, I thought I would go through how I mount a sail to the yard and then mount the yard and run the rigging for that sail. The sail I'm working on is the Main Top Sail. I begin by cutting several small ropes about 2.5" long to tie the sail to the yard. Once cut, using a needle, I attach each piece to the sail: ... and tie it to the yard using a simple overhand knot. After all are attached and the sail positioned equally side to side, I cut the excess rope and use a dab of CA glue on the knots to ensure nothing comes loose: Next, I layout the position of the blocks to be added to the sail and tie the block needed: The blocks are attached with a simple overhand knot and the loose ends removed, again, using a spot of glue on each: I cheat a little when hanging my yards! Trust me, it makes thing soooo much easier in the long run. There is so much work that goes into each and every sail that it is nearly impossible to get the yard to stay put! I cut a small piece of brass rod and drill a hole into the mast and the yard in the position that I plan to mount the yard. A dab of CA is used on the mast side of the rod only... I do not glue the yard to the rod. This allows me some freedom of movement but not so much as to be frustrating: The yard is mounted: Let the rigging begin! I do the yard lifts first. I run the lines to their end points but I do not tie them off until I have the lines run for each type. So, for example, I run all the bunt and leech lines before tightening and tying off: And then I realized I had forgotten to attach the Parrel to the yard before hanging! Not too difficult to recover! But would've been a whole lot easier to have done it on the table: Once all the lines are run, I begin drawing them up to shape my sail. As noted, I'm displaying my Bounty with the sails in a dry-set configuration. The sail is shaped but still needs some finesse! In this case, I'll leave the lines loose until I have the Main sail up and can figure out what will look best: It looks similar to the Fore mast top sail... maybe to much... dunno yet! I am going through rope so fast! I have to stop and make more before moving on. Be back in a month or so! Off to Europe for a month!
  18. This will be my next build... your log and pictures are on the top of my list for reference. Very nice!
  19. The sails have been aged... Attaching to the yards is up next.
  20. What a great summer! Lots of boating, sunshine, good friends and good food! Back in the work shop for a few weeks before heading to Europe for a month later this month! After tying a whole lot of blocks, I've completed the main mast and mizzen mast yards. Additionally, the mizzen booms are done too: With all of them completed, I'll be concentrating on aging the sails (method shown in a previous post) and hanging them on the yards and boom. Hoping to get this work done before leaving... again! Still hopeful of finishing her by years' end! We'll see!
  21. My final update for a few months... off on the boat until late August! Just about finished with the yards and booms for the main mast and mizzen mast: Some quick pictures of the current state of the Bounty: Be back at it in September! Expecting to finish by years' end. Have a great summer and thanks for hanging with my log!
