Posts posted by The_bitter_end
7 hours ago, Retired guy said:
Hi, look at your plan on framing it will tell you where the beading line starts to where the it will end at the rabbet
Drawing just to show you what I mean
I used tracing paper and traced the shape then relaid it to my frame, on my model the keel is part of the frame, do you have to add the keel on yours
You shape from the beading line down to the rabbet, rabbet depth will be the thickness of your plank
Hope this makes sense
Regards
Richard
Hi Richard
Thank you so much for your response. This now makes perfect sense.
The only problem is that I have is that the plans fail to indicate either a bearding or rabbet line.
Is it appropriate to just run the bearding line right below the lowest point of the frames?
Good Evening All
This is not the most positive way to start a build log but I guess it was to be expected for a newbie like myself.
So I have finally received my HMS Pegasus from Amati. The box is barely open and I already have problems.
This would be a great point to recommend a build log or other resource for this build. I have found many but Im struggling on that covers the finer details that a rookie like myself needs.
The instructions make no reference to a rabbet or bearding line, I have however come across reference to this in virtually every single build log that I have read on the vessel. My extreme lack of experience has lead me to several questions regarding these two subjects.
1. Rabbet line:
- Am I correct in saying that they should be cut from the very bow to the very stern(excluding the vertical portion of the stern as indicated between the red arrows)
-Should this line be cut 1.5mm "tall" and 1.25mm "deep" on either side of the false keel?
-Do I need to sand the true keel down from 5mm to 2.5mm to match the width of the false keel after being cut down for the rabbet line?(this doesn's seem to make a hue amount of sense but it seems like this is what some people have done on some of the photos that I have seen.
2. Bearding line:
- how do I determine where to draw the bearding line?
- should the false keel be tapered evenly from the bearding line down to the rabbet line?
- the instructions say "the stern area of the false keel to which the rudder post will be glued is to be sanded to roughly half the original width" does this essentially mean that I should sand from the bearding line to the vertical portion of the stern as well as the rabbet line(so that it tapers to the edge of the keel both vertically and horizontally?)
Thanks a million in advance!
Just now, Jim Lad said:
A real pity that we here in Oz won't be able to avail ourselves of your offer due to our strict quarantine regulations.
John
Good morning Jim
As a matter of interest what is the process for importing foreign timber into OZ? Is it even theoretically possible? It is ultimately a good thing that you guys have these kinds of regulation. I could probably DHL a school of live piranhas into South Africa and nobody would bat an eye.
Good Morning all
I hope that I am not in contravention of the rules of MSW and if i am please let me know immediately and I will remove this post. (this is NOT about commercial gain, it is about limiting my waste and hopefully yours too)
I am a fruit farmer in South Africa with access to an almost unlimited supply of fruit woods(Pear, apple, peach, apricot and plum). As it currently sits I use this wood for barbecuing, as there are mountains of it on the farm and on farms all around me and we are creating more ever day as we pull out old trees and plant new ones.
This post consists of 2 parts, firstly, if there is anyone who would like some of this timber, either in block shape or a specific curve or curves please let me know and I will be happy to ship to you if you can cover shipping costs once the timber arrives at its destination.
Secondly, I do not want any money for this wood BUT I am a new modeller and equipment can become very expensive very quickly, if anyone would like to trade old/used/damaged equipment/plans/parts for this wood I would really appreciate it.
Please remember that the primary point of this is to not let tonnes of good pear wood go to waste so if you do need some and have nothing to trade for it please let me know and we can make a plan to get supplies to you.
Kind Regards
Haiko
15 hours ago, Matt H said:
Hello and welcome.
Hello and Thanks Matt!
17 minutes ago, mtaylor said:
Welcome to MSW, Haiko.
It sounds like you have a good plan and now you have a great support system here. Do start a build log once you have the model in hand. It's a great way to get help and make friends.
As for the tools... you can open a topic here: https://modelshipworld.com/forum/18-modeling-tools-and-workshop-equipment/
Good day to you kind sir!
Thank you for your message. I will head over to the tools department shortly to start gathering all the advice I can(thanks for the link).
As for the build log I think I will be making use of one to create a forum to help me through my challenges.
I would like to say that I am remarkably impressed by this group of enthusiasts. I am yet to see a negative or unhelpful comment anywhere on here. even the most disastrous builds are revieved with kindness and helpfulness. It is an absolute pleasure to see in these times.
14 hours ago, tigerdvr said:
Welcome. I know it's just me but I tend to let a build log interfere with my actual building project. Considering this is your first major project you might consider focusing on the build itself. You
seem have a good systematic approach which will be a great asset. As they say (whoever "they" are) there's no such thing as a dumb question just unanswered questions. So don't hesitate to share your questions with others on this site. That will help you and others of us that may have the same question.
Most important, enjoy yourself. When things get frustrating, take a break.
Cheers, Harley
Good morning Tiger, thanks for the input and support. I think that it is so critical that I dont force myself through a portion of the build when things stop being fun, I will be sure to walk away and revisit each step when it feels right.
As for the build log i think i might just do a "questions log" basically post with photos and a background to the issue every time I have a question about a portion of my build(i expect this will turn into a fairly comprehensive build log regardless)
17 hours ago, chris watton said:
I usually only soak the planks for a few minutes, if you leave it too long, too much water soaks into the wood and as it dries out, the planks shrink and leave gaps between each. I have personally never used a heat gun for the limewood, as it's quite pliable anyway. However, everyone will have their own method for planking.
Thanks for getting back to me Chris. I will do a couple of trials with soak times and heat/no heat and do a mini post about a novices ability to use each method.
4 minutes ago, chris watton said:
Congratulations! The Pegasus is a relatively easy build, as all major components are pre-cut, and the photo etched decoration will always fit perfectly and is very easy to apply. The most difficult part will be hull planking, but make sure you check in here for advice, all the planks need is a slight taper and perhaps a soak in water for extra pliability.
Thanks Chris!
I agree entirely that the hull planking looks like it might be the greatest challenge. Im hoping that I can learn the bulk of my lessons(without destroying the model) ont the first planking so that my second planking doesnt suffer too much.
What is an appropriate soaking time for hull planking and should one then make further adjustments with the application of heat?
4 minutes ago, Jolley Roger said:
Welcome Haiko!
Looks like you are of to a great start.
If you are in the Koo valley then you should have access to pear and apple wood - very valuable for model ship building.
All the best and good luck with the SAPO.
Good afternoon Mr. Roger
Thanks for the positivity, I need all I can get. You are absolutely correct, I didn't even think about that. You might be horrified to hear that I use pear wood to braai(barbecue) on. If you(or anyone else in the hobby) ever need apple, pear, peach,plum or apricot wood I have access to an almost unlimited supply which you are most welcome to. Infact I am about to pull out 900 forelle pear trees if you are looking for fresh wood.
- mtaylor and Jolley Roger
- 2
2 hours ago, loupy45 said:
Hello form Cape town (Durbanville) , unfortunately you will have to pay customs and post office handling charges.
I purchase my kit from Artisania Latina "San Juan Nepomuceno" in Barcelona while i was on holiday.
I took me 47 months to finish. I posted the photos on the MSW.
If i can be of any assistance let me know.
Regards,
Renato
G'day to you Loupy
I know Durbanville well, I grew up in the southern suburbs before moving into the karoo to farm. Its good to know there is someone so close to home to help, I think you can expect me to pick your brain on surviving this hobby in RSA where everything is just a little harder to get and takes just a little longer.
I believe that I actually took a look at your build while doing my research. If Iremember correctly it is inspiringly beautiful. If you dont mind me asking, of the 47 months of work, were there long breaks inbetween or was it more or less constant chipping away?
I hope you are mistaken about the customs bill according to the schedule there is no charge but who knows what is going to happen, the whim on the SA post office and customs has proven to be somewhat fluid.( I hope you can see the extract from the customs website below)
2 hours ago, Jim Lad said:
Hello Haiko, and a warm welcome form over in OZ.
John
Jim Lad, thank you for the welcome. It seems like sharing a hemisphere makes us neighbors in this hobby. I hope you are enjoying the start of summer as much as I am.
3 hours ago, bruce d said:
Hello Haiko and welcome to MSW. Your approach sounds good, hope the parcel arrives safe and sound.
There is a place for tools and jigs, scroll down the forum list and look for the clues in the titles.
You can ask anything here: I have and it can lead in interesting directions.
Hi Bruce!
Thanks for the support and kind words, I already have hundreds of questions but I decided for everones sanity that I should cross each bridge as I get to it and then patiently wait for replies before progressing to the next step in my build.
DO you recommend starting a build log? and if so would that be an appopriate place to ask questions as I go?
Good day Gentlemen/women
After much thought, research and deliberation(literally years of umming and aahing) I decided that I would bite the bullet and purchase a fairly challenging vessel to start my career in model ship building. I settled on the HMS Pegasus and I am extremely excited about getting started on it. I realise that any sane person would have started on something far more simple but my thinking is as follows...
1. I have prepared myself for what I expect to be a 2 year project.
2. The wealth of knowledge, willingness to help and attention to detail that can be found on this forum really gave me hope that I could work through this project and succeed.
3. I feel that every single element of doing this project is essentially very simple if it is broken down to its tiniest detail, every step is researched carefully and tackled without haste.
4. I like to think that I am fairly good with my hands. I do blacksmithing and carpentry both as hobbies and essential skills for a farmer in a remote part of South Africa.
I hope that this somewhat simplified approach to this problem will turn out to be correct but the proof will be in the proverbial pudding.
As of this moment I am still waiting for my model to arrive(I ordered directly from AMATI and paid 319 Euros including shipping). Unfortunately amati used a shipping company called Asendia who then handed the shipping over to the South African post office. This means that I can expect my package to arrive sometime within the next week or possibly during the next ice age. At this stage my primary means of securing my package is being on hold to the post office, checking my tracking number 380 times a day and thumb holding.
In the meantime I have built a couple of simple tools to assist me and purchased the rest. The home made tools include.
A "U" shaped desk(which through some bizarre negotiation with my girlfriend ended up being painted "teal"(thats blue to you and I))
An adjustable, lockable, rotating, swiveling, pitching, rolling keel clamp
An adjustable keel rest (this is probably not the right term)
And a guillotine with adjustable angles that takes a carpet knife blade.
A plank bender made from a forged and polished chunk of copper and a soldering iron.
I am not sure if there is a specific place where I should post photos and text about some of the tools that I made or if anyone would be interested in this but the information if available if anyone is interested.
I also managed to get hold of a broken down scroll saw for a bargain and I restored it to a condition that im proud of.
I have a dremmel stylus with a decent selection of attachments as well as the following bits and pieces
Soldering Iron
hand scroll saw
razor saw
multiple scalpel blade holders
a variety of drawing equipment for technical drawig
a variety of drill bits, sandpaper, clips, clamps, files, brushes, chisels blades, rulers, squares, clippers, cutters and pliers.
If anyone has any questions, advice, suggestions or guidance for me(or perhaps a recommendation for which pegasus/fly builds to reference most) then I would be eternally grateful.
Gods speed to you all!
Cheers!
Haiko(The Bitter End)
HMS Pegasus by The_bitter_end - Amati/Victory Models - 1:64 scale
It is a bummer indeed haha
I will pay careful attention to the framing. That is going to be a whole other challenge.
Yes, I do have to glue what they referto as a "true keel" onto the edge of the false keel
