mikegr
Everything posted by mikegr
  1. More details added, masts, boats, AA guns and few others. Masts where high detailed gave a nice look at the model. The main one was made of 13 brass pieces and 2 resin ones.
  2. had issues how to permanently straighten the hull. A wooden base was made, model was placed on the center and a small amount of resin was poured. It was left dry overnight. Hull sides were painted gray already. Looks like I have to cover the base before future painting. The instructions are practically unreadable. So I followed some basic guidelines. Biggest parts were attached first. The missile launchers: Apart from their base, the other parts are metal ones, a frame and the "skin", mini parts than must be folder in oval shaped and attached over the frame After trying for a couple of hours I realized that this will never going to happen. So once again using the current pieces as a reference I designed and printed my own missile boxes which were decorated with PEs and attached on the model
  3. I bought a cheap basic model of a Bergamini frigate in 1/700 and I am working on it to add more details. When its completed it will be posted online
  4. I had issues how to permanently straighten the hull. A wooden base was made, model was placed on the center and a small amount of resin was poured. It was left dry overnight. Hull sides were painted gray already. Looks like I have to cover the base before future painting. t Upon my first look at the model it was noticable how many PE pieces exists, comparing to the few resin ones. First trouble came when I start to make the missile launchers. Apart from the base the others are metal ones, a frame and the "skin", mini parts than must be folder in oval shaped and attached over the frame After struggling for 2 hours it was pretty obvious that there's not a chance I accomplish this task and even if I do result will be mediocre. So once again standars parts were used as a reference for size and I made my own launchers pack after 3 attempts. Then I only add the enchancing PEs. Since there was an option for the hatches to be left open, I made also a few missile heads. Finally the funnel was added with bit extra detailing according to pics I studied
  5. Another model of a less popular ship on my bench, Anshan the first destroyer of the PLA Navy. Ex Russian ships, converted with Chinese missiles replacing some torpedo tubes. This ship today is a museum The model I bought it from EBay. The manufacturer is Chinese but I can't see the name. There are two PE sets with lots of big and small parts and few resin pieces. In fact most are PEs even some big parts of the superstructure. Finally the instructions are a 3 page photo copy, showing each part assembly, them fitting them all together to the hull. Not sure how helpful will that be. The first I did is to straighten the banana shaped resin hull
  6. Thanks I'm just keep on effort so every work will be a little better and not a repeated one
  7. I added the remaining AA guns. They gave noticeable details. Some single 25mm added as well. Some darkening with black oil and a basic rigging. As the ship had a very short life no weathering is required. Seabed is also done. It looks well apart from the wakes close to the stern. They shouldn't follow the hull shape. The decision of using a narrow base led me to this mistake. But need to move on, can't spend time to make a 3rd base.
  8. I made some AA guns. Then fitted a few. A new seabed is under construction because the wooden base of the previous one got warped
  9. I decided to glue the planes to avoid any accidents along with the anti falling nets. I didn't have a PE part for crane so it was made by two masts glued together, like those at the sides of the ship but bit shorter. AA guns and life boats need to be added but my printer needs to be fixed so while the parts are on their way I spent time making the sea base
  10. I added the A6M Zero. Totally 12 pieces. PEs were bit smaller but I added them all. For paint I use grey primer directly mixed with white. That saved me some time. It would me a nightmare to built 60-70 of these.
  11. Thank you The rule is ruthless: You can hard to built a flawless looking model but its the little details that will catch the eye
  12. Next sreo is the placement of rocket launchers. They turned up a big success, with high details, the teasers look like a giant fork behind them.
  13. I just finished working on the 5 masts. It took me 1 hour 20 min. They are very fragile.rigging is going to be a challenge Placed over my future project, Bergamini class frigate 3d printed
  14. I like the paper glue method over the foil. You can work better the wave form and direction of the waves with a brush. It takes more effort but worth it. There's no easy way out on this.
  15. Try to shape the waves in a way they look they come from the same direction. Make a corridor at the stern for the wakes that should be almost flat
  16. I used self made mask and painting techniques to achieve the desired result
  17. After camouflage painting the model began to look realistic. There were moments that I was about to give up but looks like its good I didn't Next phase is working on the deck. After that, details will be added like cranes, guns and ofcourse aircrafts
  18. Ok after a lot of mods I managed to finish the hull. There are more things to be done but this can't be done in a sensible piece of time especially in the aft area. Anyway a light primer was sprayed mostly for the brass representing the degaussing line
  19. Too late 😂 Cannons, barrels, extra barrel rafts and both types of decoys launches By the way the angled gun is the later stealth type. Should be combined with the Sea Send or (my guess)
  20. My HMS Montrose kit The 4 parts missing are the halfs of the 2 Sea Gnat decoy launchers. However seems that type 23 ships have been updated this heptagon device is called Sea Sendor, soon be replaced by trained launcher system I already prepared a test file, not sure about the dimension of the Sea Send or but looks almost same high as a sailor, means approx 2.6mm in height I noticed also that these ships seems are carrying the Mk1 Version of the 4.5" guns the one with the angles not the rounded one provided in the kit. I have a file for this and it was used in my type 45 scratch built project. It should come along nice with the Sea Sendor update. Will also check if more pieces can be improved so I can use them on my own built.
  21. After a lot of work the deck section is almost ready to attach. It will be a major task about 70% of the work has been done
