mikegr
Members-
Everything posted by mikegr
Try to shape the waves in a way they look they come from the same direction. Make a corridor at the stern for the wakes that should be almost flat
Too late 😂 Cannons, barrels, extra barrel rafts and both types of decoys launches By the way the angled gun is the later stealth type. Should be combined with the Sea Send or (my guess)
My HMS Montrose kit The 4 parts missing are the halfs of the 2 Sea Gnat decoy launchers. However seems that type 23 ships have been updated this heptagon device is called Sea Sendor, soon be replaced by trained launcher system I already prepared a test file, not sure about the dimension of the Sea Send or but looks almost same high as a sailor, means approx 2.6mm in height I noticed also that these ships seems are carrying the Mk1 Version of the 4.5" guns the one with the angles not the rounded one provided in the kit. I have a file for this and it was used in my type 45 scratch built project. It should come along nice with the Sea Sendor update. Will also check if more pieces can be improved so I can use them on my own built.
The model is made by 3 main pieces. The flight deck, the hangar area and the lower hull section. I start working on the gun platforms around the main deck. These should be all removed and replaced by correct ones. Unfortunately these are part of the hangar deck, so I had to cut them using a low rpm rotary cutter. Then sand a lot to remove the excess plastic. The fist piece installed was the bow platform set for the rocket launchers Looks like there is a lot of work to be done. I estimate this project to be done before Christmas.
There's only one picture of Shinano available. I have Kagero's 3d book for reference. Starting from the top I realized that the oval shape of the funnel is wrong. So I printed some replacements to experiment with a teardrop shape. The superstructure is also not compatible with the PE parts so I need to work with it also Under the deck there is actually a Yamato class hull which seems that Tamiya used this to the Yamato or Mushasi model
Merkava III by mikegr - Revell - 1/72 - PLASTIC
mikegr replied to mikegr's topic in Non-ship/categorised builds
I wanted to build a base, like a small presentation but without spending much time. So I found a some 3d files, however it took me all Sunday to adjusting to my preference and scale. Anyway I turned quite ok. A couple of pics with the other beast. My first base of the M1A1 was big and empty, the T-90 muddy terain was better even simple. The 3rd was nicer I think -
I added some equipment to fill in the empty space behind the turret. Next was the weathering by painting some areas with light shade. Then applied acrylic black wash all over but i made it thinner over the rougher horizontal surfaces to avoid excess accumulation of dark liquid. Tomorrow more shades will be applied -
I had to make some loopholes for the wires so I found an affective way I cut a needle in small pieces, made a loop with 0.3mm wire and glued them. Easy. Then I moved on weathering the tracks -
