mcb
Everything posted by mcb
  1. Thanks Keith and Wefalck, thanks all for the likes. Those blocks are from Bluejacket. They are 'Iron stropped triple blocks F0384', they are white metal. They seem a good match to the photos. Making blocks myself is a little too much for me. The chutes and pipes in the tower are just so something might be seen through the openings. In reality there was a lot more in there. Thanks again, MCB
  2. Hello everyone, It is again time for a small update. I have finished with the hull for the most part. I added a hatch in the deck at the bow, coal scuttles, water fills etc. in locations that are my best guess after looking at drawings and pics of other elevators. I may add some cleats later, I think there were probably 4 at least. The bitts and bollards should be close to their proper positions as I can see those in the photos of 'Isis'. I painted my representation of the top of the steam engine and plopped the rear deck house/engine room over it to look in the skylight at it--it is barely visible. I am glad I looked otherwise I would still be making chairs and wrenches and calenders.... I am easily distracted. Before mounting the tower to the hull I installed the previously rigged triple blocks for the marine legs and 'parked' them on wire rods until I get to the stage where I can mount the marine legs. I hope they don't come off or tangle too much, I would be in a lot of trouble. I don't know how you folks do it on this forum, the rigging you do is astounding. Since these photos I have put on the tower and started to sheath it. From here it will mostly be assembling parts that are already made. Thanks for looking, MCB
  3. Hi, You are doing a beautiful job here mbp521. Those 'pre-heaters' and 'auxiliary engine' (or one might say heat exchangers and pump) seem analogous to the later feed water heater systems found on locomotives. This of course is to get the feed water temp as close as possible to the boiler temp using waste heat, minimizing steam pressure loss among other things. Keep up the nice work! mcb
  4. Thanks Everyone, These elevators seem to have been built on the NE seaboard. Many around NY harbor. The 'Isis' and sister 'Themis' built in Camden NJ 1898. They certainly must have been dusty (No Smoking) and I don't think the owners spent a lot on upkeep. MCB
  5. Hello Everyone, It is time for another update. Thanks to MSW member Canute for pointing me to another source (RMIG--'Transfer' #40 ) for information on these vessels. I found that by making my hull longer I am actually close to the correct length now. I discovered a few details that I should probably add on as well. Also found that many of these floating elevators were not self propelled, some had barge like hull forms. And I got some confirmation that essentially no two of these things were alike or that one would retain its appearance for long. I am now near the stage of assembling the parts and sub assemblies. Here are various parts and the rebuilt marine legs. The last picture (if I can manage to get all the pics in order) shows a plastic structure protruding from the area of the engine room. That piece is meant to support the stack which otherwise would be too heavy and vulnerable. Just behind the support for the stack is the top of the steam engine (in primer) which will be under the skylight. For some reason I seem to put these details in where no one will ever see them. I do this in model RRing as well . Now I am starting to think of other things to go in there. It must be one of the reasons I never get anything done. Thanks for looking, MCB
  6. I think I may try that wefalck, The more I look at them I don't care for how they hang. The one at the bow next to the name looks better. Thanks everyone, MCB
  7. Hello All, It is time for a small update. Here the hull is almost complete. The wooden 'stick' fenders look pretty clunky in the photos, I probably should remake them. The 'woven rope' bow fender is a small piece of tack rag. Moving on to the superstructure now. Thanks, MCB
  8. Hello All, I thought I would update this log to show what I have been doing lately. The first picture shows the 'marine legs' which are the movable conveyors that are let down into the grain barge to remove the grain, probably with some help from men with shovels. These were made some months ago but I have decided to modify (articulate) them so that the discharge will be into the interior hopper. Second picture shows the movable discharge tubes which are positioned in the ships hold to deliver the grain. They are masked so that 'seams' can be painted on. Thanks for looking, MCB
  9. Thanks Keith Black and the same to you and all at MSW. MCB
  10. Hello again, Thanks for looking in and the likes. Wefalck: Looking at these photos at higher resolution I can see that the elevator tower itself seems to be sheathed in metal, what used to be called around here corrugated 'iron'. The windows in the elevator look like ordinary off the shelf double hung windows from the local lumber yard. The lower ~ 10' are a different composition, I am assuming wood. Strictly low budget. The deck houses look like wood. The interior skeleton is simply to support the sheathing. I added some pipe work etc. in the event that any thing might be visible later. Over the years it seems that there were changes made (some drastic) at least to 'Isis' and 'Themis'. By the way, I did see an old pic or illustration of a grain elevator that was not fully enclosed, I believe in Buffalo NY. Keith Aug: 'lack of aesthetic appeal' …. I don't know about that, I found her irresistible.😮 Thanks again everyone, MCB
  11. Hello again, This model was pretty far along before I decided to post it. I used photos to make a sketch to build from. Since it appeared to me that the hull form resembled an elongated harbor tug boat I used a hull from a Noch n scale tug boat to help determine the shape of the bow. However after building the engine room house I did not like the proportions and scrapped it and the hull. This project is primarily styrene, I will try to list all the detail parts before the log ends. Here is the current state of the model along with the old and the longer new hull. The deck houses just positioned for show and need more fitting. Please excuse the cell phone photos and the disgraceful mess of a work bench. Thanks, MCB
  12. Hello all, This log is for a floating grain elevator as could be seen in New York harbor in the early 20th century. These self propelled grain elevators were used to transfer grain from barges to freighters in various locations around the harbor rather than directly from a large elevator on shore. Freighters would presumably fill 'unsold' hold space with this bulk cargo. I became aware of this subject through my interest in railroad activities in New York harbor up until the '60's although these grain elevators were independently operated. I was unable to find as much information (drawings) of these floating elevators as I would have liked but I enjoy building (model railroad subjects) from photos in styrene. I was not sure if this log should be in 1901- present but but the sister elevator to 'Isis', 'Themis' was supposed to have been built in 1898. There is some information and color photos in the book "New York Harbor Railroads in Color" Vol.2 Thomas R. Flagg pgs. 20-21. The photos below are from NPS / William W Barry Jr. (Steamtown N.H.S. DL&W RR glass plate negative collection ) 'Isis' is between two grain barges, unloading them and sending grain down its chutes to a freighter. I have already built approximations of those two barges. Any info about these grain elevators or any rail /marine operations would be appreciated. I will post photos of the current state of the model following this. Thanks, MCB
  13. Hello all, I am a model railroader who stumbled onto this site looking for ship fittings. I found that I could not stop looking through the incredible work here. My train layout has been getting dusty. I am currently building model railroad related equipment and vessels (all in 1:160) for New York harbor pre '60's. On my bench now is the floating grain elevator 'Isis'. It is being built from photos in styrene. I hope to start a build log for it soon, if there would be interest in such an ungainly tub. It certainly would be unique. And of course at the last train show I attended I could not walk by a table where there was an old ('80's ?) AL Bluenose II at a price not to be refused, naturally missing the instructions. I have the hull done on that but I am told I must get going on the NY harbor things first. Sorry I did not join in sooner. I've been hanging around for months. Thanks, MCB
  14. Hi Ken, This is great. I am interested in (and working on) NY harbor scenes especially Harlem Transfer/ DL&W facilities. I have seen your post above for the stick lighter. Please keep the pics coming. I cannot believe I missed this as I have been hanging around here for months. Thanks, MCB
