Egilman
Everything posted by Egilman
  1. General Mess is his son, General Order is his wife and the mother of General Mess.... {slinking away quietly as well}
  2. I agree Craig.... Given that I put it over fine grey tamiya primer on the fin and tanks tells me that a flat primer is the way to go, a micro rough surface for the wax to grab ahold of..... I wouldn't use Tamiya acrylics though good old Testors flat black would be my choice there is no chalky residue with it and it's the darkest black model paint I know of and sprays very thinly as well... Jean Paul used nitrile gloves after applying the RnB specifically to avoid the fingerprint issue...... the 24 hours drying time was new for me so that is now something I will do also. He did the fuselage and wings separate and filled any space with styrene, custom mating the joints before painting them to remove any gaps. I know from my own experimentation that you can put a gloss coat over the RnB after it is down, but since his experience is that the decals will go directly over the RnB without issue, that is probably how I will do it as well and save the gloss coat till the final finishing... But I will test it before I ruin another model..... Anyway, it's all in the experience file now... and I think I have a course on how to do it... that article at least went into some of the details of how he did it unlike the first two..... Thank you that article was a great find.... EG
  3. Yeah, they do tell you the way it's going to be, do it right or go home.... {chuckle}
  4. Craig... I looked up the article the question was based upon, Finescale Modelers December 2014 issue... I read the article.... Build a Canadian Starfighter; By Jean Paul Poisseroux.... It does explain his technique... He built an Italeri #2502 1/32 F-104A/C into a CF-104 and yeah the BMF was overall RnB Silver Leaf & Pewter for the aft dark metal over Tamiya Acrylic Flat Black as primer to give the RnB some bite on the surface.... no other finishes were used.. The decals were set right over the RnB using Micro Sol.... He states that there was no problem with the RnB coming off the model like I had.... And checking it out, I have no problems with the RnB coming off the wing tanks and horizontal stabilizer also... But it clearly comes off the fuselage.... I think I know what my problem is... . I'm putting it on over clearcoat..... That's my error right there in a nutshell... Being an ultra smooth surface, there is nothing for the wax to bite into hence making it easy to just pull off or for hand oils to loosen... Another thing, he masked and waxed the dark panels first before metalizing the fuselage.... Then once metalized he allowed it to dry 24 hours before buffing it up..... I don't know how I could of forgotten that since that is why I did the tanks and tail fin first.... I wish I have seen that article before I did the fuselage.... The tanks and fin buff up into the prettiest shine you would ever want to see... I tried some full strength 3M masking tape, the full automotive grade, and burnished it down across the fin.... It pulled off without lifting anything.... I guess it was time for a break anyway..... As I mentioned when I started, since this was a first time attempt, if there was a way to flub it, I would find it..... (apparently even after hitting on the correct way of doing it) Live and learn..... I think next time it will turn out a bit different..... EG
  5. I saw the second one, and yeah thinning it and spraying it only gives you the same as a rattle can aluminum finish not bad but not great... I did read the one from finescale and yeah they are really looking for a finish that is put it on and your done... There is no BMF like that and there never will be... so yeah they treated RnB like they would any other finish..... And there's a lot of them, I think when I get one done I'll post it to that 6 year old thread.. There was one poster that said it has been done and named another modeler that used it, another Paul over in France... If I can figure out how they finish it off then I'll be in like flint... Cause there is no other finish that can match it... And of course my brothers here will know how to do it also..... I want that finish that says metal, not painted look alike for metal...
  6. Well, I'll be starting this one back up in the near future... Got to get a little organizing done over the next few days.... EG
  7. Yeah I had a hard time Ed arguing that logic myself... (she can be pretty persuasive when she wants to be, especially when she is right) But she does understand.... I don't know about a Floaty Thingy right now, I have the Bandit to re-start/finish.... and get my build space cleaned up and organized...... But I will be back with another Zipper... a much better kit I understand...... Final picture, where I finally wound up... (I pulled the canopy masks not bad but I'm rusty) She does look good I have to admit, it's not the look that is stopping this build, it's the overapplication of finishes preventing any further advance on finishes... So it can't be finished properly... But I have learned how to get the metal finish on the plane... that's the take off from this hobbying road trip.... I learned what I needed to know even if I didn't arrive at the end of the journey... I found the silver lining so to speak.... {chuckle}
  8. Definitely test it first my friend, the clear coats are not adhering to the metalized finish is the problem, they cover, they dry and work as expected as long as nothing else is required of them... it's not like putting it down over primer or even paint... It has nothing to grab onto... So the metal finishes have to be the last part of the build then the clear coat for sealing leading into the decals and you only get one shot at it.... My problem is too many coats and not enough grab to them.... My pleasure on sharing, at least everyone got a good idea of what not to do........ And I'm not giving up, Blue Jay Four will be sitting on my shelf eventually... just not this time.....
  9. This was a lady that didn't want to be consummated.... I'm sure you know what they are like.... Always more fish in the sea... and for every non-success, there is another success just around the corner... Plans are already being laid for Blue Jay Four #2..... I never quit, just sometimes it is best to make a strategic withdrawal...... And thank you my friends for all the support..... It's means a lot.... It really does....
  10. Thanks Nick for the vote of confidence... The work isn't being throw away my friend, all of what was learned will be applied to the next one....
  11. Outstanding representation my friend.... A lot of work went into that.... Very impressive.....
  12. Well, still in the deciding stage... The Admiral sat me down and told me that I have to look at the end result.... She knows me too well... Her opinion is that going further is going to frustrate me even more cause it will not be what I envisioned so I will never be happy with it, so why waste any further money trying to fix it...... Italieri is coming out with an updated kit (now available in europe for preorder) and use this kit as a learning experience... I still have all the decals and the extra parts that haven't been used and I can save the seat and cockpit...... Her recommendation is to stop beating my head against the wall and move on... And to be honest with you all, that is the way I'm leaning.... It's not a defeat but a heavy learning experience.... We travel down many roads in modeling, occasionally we come to a dead end.... I believe this is one of those times... I can't fix it unless I tear it apart and do a complete strip down and get all the accumulated finishes off... That in itself will create even more fit and finish problems down the line... It's not happening fellas..... I know my limitations.... (and I know from experience where it goes from here) Her opinion is get another one and try again in the future.... she doesn't mind the expense as long as I'm enjoying myself.... She also says is that it is painfully obvious to her that I'm not enjoying myself.... it has become a drain.... It's my stubbornness that is causing this, my unwillingness to give in... She says it is what makes me good at what I do.... but not to forget to face facts, this is NEVER going to come out the way I want it to... Go back and take the other road... Sorry fellas, I have to agree with her... This is going on Hiatus while I sort it out... It is the only course forward at this point...
  13. Well, No pics today, just a frustrated lament... I went to mask the tail for the pewter wax color sections... I used the light tack frisket tape, and the finish pulled off with the tape... Tried it a second time and same result... It's sealed but I can't mask it for colors.... Way too many paint layers on this thing that aren't really sticking... So I think I'm going to try and freehand it and if that fails, then I'll leave it as it is... It won't be completely color accurate I know..... Don't know what else to do with it...... except bin it and start over.. It's been a learning experience, an expensive one as the Admiral has noted, but still a learning experience..... Sorry for the rant my friends... I wanted this to come out nice, but it's time to decide which way to go, cut it off and get it done or bin it... She is being a real contrary lady.... EG
  14. No, no difference in words. Just a difference in meaning based upon context or subject matter..... Also in American usage I've never seen an example of "The Lords house" used as the subject of a conversation. When directly referred to it is referenced as a church... "The Lords house" in reference to a church is an inference or metaphor used in describing an ideal rather than an actual object.. I know it's technical language usage which is a very droll subject, but it is the truth..... EG
  15. May I suggest non-drying Modeling Clay, available from most any hobby/craft store and very cheap, fill the nose with it and tail sitting is over..... best thing abut it is you can conform it to whatever space you have.... and it doesn't need to be glued in... EG
  16. Thank you Mark.. The wax is permanent, it's what puts the metal finish on the plastic and is gloss coated to seal it down, the decals go over the gloss coat..... And it doesn't change color when sealed.... EG Update: Below is an image of her gloss coated.... Yep, she doesn't change colors.... Waiting for a solid cure, before I continue... Way too many coats on her now, so I just wanna make sure before I go farther....
  17. Thanks Ken, It looks good... I know it takes a clear coat cause I already tested that on the turret.... I was just trying to get the pewter wax on the tail before sealing it down when I noticed it coming off on my hands... Easily fixable... I have some nitrile gloves that will allow me to handle it during this process, just a minor setback. So I'm figuring that I need to do it in stages, base metal finish down first, then a light seal coat, then the other metal colors on the tail..... So as adjusted, the procedure is now finish off the planes basic assembly, a thin coat of gloss black paint, the RnB silver wax (which goes down very thin), then a light gloss clearcoat, and finally the Pewter or Titanium colors on the tail and then an overall light gloss seal coat... Overall there are a lot of painted BMF's out there which are very very nice, but they do not match this in realism and it's done without an airbrush.... I'm going to finish this one, it's not my best work and has a lot of issues, So, I will be doing another F-104C - Blue Jay 4 in the future, (probably the new Italieri) but it's time to get this thing done and move on..... I've learned the basics of what I needed to..... Even the Admiral understands that this one was a learning experience..... she thinks it looks great, but admits she really doesn't know what she's looking at... Gonna touch it up now and seal coat it so it doesn't come off again... Thanks guys for following along and your patience with a plastic hacker's inexperience... EG
  18. Thank Ed for the vote of confidence, But alas I still have more figuring to do... Not quite there yet... Over time, the wax will soften and come off when handling it... I already have a few areas where it needs to be touched up... And it's not going to stay hard long enough to get the decals down..... so I'm into testing mode again I have to find a sealer for it... Two steps forward and one step back..... It masks fine though tape doesn't pull it off I guess that is a good thing....
  19. Thank you OC... But, we are not done yet, Rub n Buff is much better than the Uschi powders easier to put on... but it is effected by hand oils also, just not as fast... So I need to readjust the application procedures for it to account for that......... Probably have to put a clear coat over it and see what that does to it.....
  20. Update, the one everyone is waiting for.... Waxing this lady!!! (no, not that kind of waxing) We start with masking... we don't want any wax on our wings... Using 3/4" frisket tape we mask even to the fuselage to the flap then even with the flap to the trailing edge... We finish off with covering the wing surfaces with masking strips. I did it this way cause I do not want the masking tearing during application of the wax... Rub on and buff out.. It didn't take very long at all about 15 minutes to completely cover the fuselage... Top and bottom... With the masking pulled.... Wing Tanks and stabilizer added, she is really looking the part now... Time to get some outside shots.... She looks better from a distance than up close, yeah, the finish suffers from the refinishing work that went on before... But as far as the metal surface goes it duplicates the natural look of aluminum sheet metal in a semi polished state..... Some reflections, but not mirrors, the way most of them in common use were.... It reflects sunshine the way it is supposed to.... I don't think there is a better BMF product hands down.... There is nothing out there that matches this... Absolutely nothing... (of course in my humble opinion) Gonna leave it sit overnight, give it a final rubdown and call it good... Next, I will start concentrating on the details... which first up is the different colors on the tail...... Tamiya fine grey primer, a light coat of testors wet look and Rub n Buff... My next aircraft will have a black base coat... Anyway it is what it is..... It does look like a bare metal F-104 just don't get too close to it to see all the imperfections in the surface... A heck of a learning experience..... EG My first one, I hope you like it....
  21. Thanks brother..... Up next masking off the wings and waxing....
  22. You can do this on windows, but windows has a function built in for scrolling thru pic files in a directory called file viewer... It's been there since Windows 7....... just double click on the file opens the viewer
  23. Beautiful work brother.... really looks the part, Hendon or the maintenance facility at RAF Strubby near Alford, could be any of a dozen basings.... Wonderful job!!!!
