Egilman
Everything posted by Egilman
  1. Looks Sharp! Now to pick up the SO and head down to the local Frisko Freeze.... Can I borrow the keys?
  2. Tip a pint of Guinness for me when you get the chance my friend..... It is always my pleasure.... Glad it worked for you.... (Psst... not so many you injure your other knee, chuckle)
  3. Yep I've used it on furniture finishes, it's latex polyurethane floor finish, made for sealing hardwood floors.... Almost as tough as future and just as effective, but goes down a hair thicker.... It's my backup if I can't find any Future.....
  4. That's your problem right there, it's giving you a smooth finish BEFORE you put the color on.... Some paints need the rough texture of the flat finish to be flat..... And, all paint lines have various colors with this issue, It's the main reason I use nothing but dead flats for primers and separate gloss coats for anything that needs to be shiny..... Good gloss paints will gloss over flat primer but they go on thick.... that is what I have to watch out for... Hence, I paint in nothing but flats unless I have to use a gloss because it's the only way to get the specific color....
  5. I had no doubt that you could fix it that way. It's just a lot of work.... (I've never had to do it on model parts, but have on acrylic windscreens for bikes and display cases) But I would dip it in Future, (Pledge Acrylic Floor Finish) to protect it from any further damage and level out any micro scratches that might remain.... That's what Future does it fills the tiny defects in the surface that tends to dull the look. It will look clearer in the end... Good Recovery.... Well done
  6. Not going to scream here, but I would suggest two things first before you go the polishing route... Since it is an overcoat, try overcoating it with high gloss clear first. you can test this by wetting it, if the fogging disappears when wet, then it is a surface finish issue.... If that don't work, try removing it by soaking in Super Clean overnight to see if it takes it off.... Obviously the finish is fogged but it doesn't appear that the surface is crazed any... I had similar happen once before and removed it with Super Clean. I believe what causes fogging is residue on the surface reacting with the varnish.... I would approach it that way and leave the polishing for last option.... understand that polishing at this point needs to be done over the entire surface, you have to remove all of the varnish.... Another learning moment.... EG
  7. Actually it is Pledge Acrylic Floor polish formerly known as Future Floor polish.... (pledge all by itself has a common appellation as a greasy, waxy furniture polish which my grandmother used on all the wood furniture) Make sure it's the Acrylic floor finish.....
  8. Hey brother, not a big fan of veneers here either, always seemed to me like twice the work.... Good work, looking good... will pull up a chair if you don't mind....
  9. Been there, done that! It's an ongoing process of life on this rock and I'm also dealing with some of it now.... (but this too shall pass) But I'm taking the time I would be hacking plastic to plan the future of my build yard... And a massive future project is in the offing. Along similar lines of scale to a 3/8th scale POF Santissimo or Victory. Scale in the terms of size, time & complexity but not a ship. Well I guess it could be called a ship so to speak.... Anyway good to see you posting again my friend.... EG Cant wait to see your build log.... (we mustn't hijack Dennis's Kannonvogel build)
  10. Looks to me like everyone got to it before I did... getting slow in my old age... You've nailed the look of a properly accourtred Bentley body..... the hood (bonnet) was gloss and the body I believe was doped linen over light ply.... the best you could get for a finish on the real deal was semi-gloss/satin, it glistened rather than shined..... Looks to me that you replicated it perfectly.... Better than I could...
  11. Movin right along..... I'm in... Light AA is another seldom built genre....
  12. Looks like everyone has run most of the options. There is the type of mixer that is used in medical labs for mixing compounds... works kinda like an oscillating sander there are even some videos on how to build one... But alas I'm laazzyyyy.... I use the old rattle ball standard that has been around since little bottles of paint were invented except I don't use one ball, or even two balls... (three neither, sometimes if the paint is thick enough they get stuck in the paint and don't work) I use six balls in each bottle, makes very short work of mixing any separated paints, even those thick ones that have been sitting for a couple of years. The many multiple BB's act like a shot cleaner while being shaked cleaning the paint off the sides and bottom of the bottle. Where the paint can withstand the impact of one, two or even three BB's without mixing sometimes, good paint can't handle the constant pounding of six BB's and if that doesn't mix your paint within a minute or two, throw it away and get another bottle, it's gone bad.... I get mine from Wally World, in the sporting good section, a few bucks for 1500 BB's, enough to last several years and several hundred paint bottles. And guess what? never any mess or spilled paint...
  13. Yep, Testors dullcoat is THE product to do that... I wouldn't have a clue on what that go-to flat overcoat product is for acryls.... (if they even have one)
  14. This is why the make the gloss coats In little bottles, overall flat, and the details you want gloss are done with a Brush.... Similar technique to your highlighting, you have much more control putting gloss on a flat with a brush than flat over a gloss.... Remember gloss works by smoothing the surface to increase it reflectivity and as a result the paint has a hard time sticking to the smooth surface... Flats are by rule not smooth surfaces, so the coating you put on can bite and lay where you put it... Base coat flats, gloss up the details that need gloss...
  15. Like Roger says... Dullcoat... If it's not flat and you want it flat, Testors Dullcoat, no product does it better...
  16. No Skills huh, I wish I didn't have skills like that!
  17. Had to be something a might powerful to get you to leave like that...... It couldn't have been boredom..... {chuckle} I'm relatively new here not even a year.... But more is better as they say... Welcome home..... +1 It's always good to see old timers come back, (even if you don't know them) makes you feel even more like your not alone in the world.....
  18. I have faith, you'll do fine... These are called master modeler level kits, and yes that is what you are.... You'll have no problem...
  19. This is one of the reasons I like this hobby... You can illustrate a piece of humanities ingenuity in serving it's needs, a moment in time so to speak.... Impressive, and in paper no less, even more impressive.... Excellent representation of a very difficult subject... My hat is off to you sir! Beautiful work!!!
  20. Yes it is, When people look at finished builds it's usually the first thing out of their mouths... (or the comment "I always thought they were toys") Kinda as an afterthought they add "Nice job, or beautiful work or the question on "How long did that take?" If you give them a truthful answer then the excuse comes I always wanted to get into model building but I just don't have the time..... What really gets their attention, is when you start telling them about it in the historical context, what it represents how it came about, what it was used for and so on.... That's when you can tell if they are shining you on.... Sometimes their reactions are quite funny actually when you realize that they want to get as far away as possible....
  21. Nice!!! Now you need six machine gun tanks to make up the full attack group... they were platooned two MG tanks to a Cannon tank and the command/radio tank would support three to five Platoons..... And the smoke generators would be on the lead tank... Nice work. 1/72nd scale is difficult....
  22. Well, at least you know you can.... (when you can get some) at least saves you the cost of a new pair...... Trust me when I say, if it is plastic, there is a bonding agent for it.... just figuring out which plastic you have to glue is the real issue....
  23. Because they are made of acetate... a common plastic for eyeglasses... Neither CA nor MEK will stick to it.... Yes you can repair the break.... Give it a try, you got nothing to lose...
  24. Trot on down to any decent craft store, they will be happy to sell you dozens of them.... (chuckle) Oh yes, they still make 5/0 & 10/0 fine liners.... (and they usually have more than one or two hairs, although it is hard to see them)
