Everything posted by Egilman
You can't get it thru desertcart.com.au? https://www.desertcart.com.au/products/7862466-krylon-k01050007-premium-metallic-gold-foil-gloss-8-ounce Pretty pricey I see but they offer less expensive alternatives as well... Then there is this one which claims they have it in stock.... https://www.caprioleshabbychic.com.au/Krylon-Premium-Metallic-18-KT-Gold-Spray-Paint-8-Oz
Back in the '80's I had occasion to experience this effect, the T-birds were flying at the McChord open house.... The viewing stands extended from the base of the tower in front of the south hangar northward along the runway.... There about 10 yds between where I was standing and the hangar door..... The diamond formation had just cleared the low speed pass from north to south and was exiting the area, nothing at that point causing the crowd to look around to see what was next.... BOOM! #5 came out right over the hangar over the crown and busted all our eardrums, he wasn't supersonic, but he sure sounded like it.... He pulled up into a vertical climb and disappeared... Very impressive.....
If I had had an AF rig (F-4E) I would have did a spiffy paint job brother... but I just went with what I had.... As far blood on the model goes, the Admiral has a saying, It's not mine till it's drawn blood... (most of mine have some form of personal contribution in it somewhere) This one is no different.... {chuckle}
Thanks Gary, It was an amazing aircraft.... There was a development model that was adding newer turbofan engines to the airframe with water injection which would have made it a Mach 3 aircraft... It was rejected by the Airforce because it got too close to the performance of the SR-71, I think the Israelis built a toned down version but it wasn't put into production either... The first real do anything aircraft... The H-13's are suffering from the ultra fine detail affliction, what my minds eye sees compared to what is possible.... I'm working through that at this point and with the wife in her situation I really haven't the time to go into that level of engineering... Probably going to have to turn down the expectations on them... This build was something quick and easy as a way to relieve stress.... They are still coming as are several others... EG
But your battle took place in June, Rye doesn't harvest until late fall, so a little shorter and green would be the choices upper thigh height about 10 - 12 mm... or that's some awful tall rye... I'm sure whatever you choose it's going to look spectacular... PS: I updated that post you quoted with a bit more info and links..
So your looking at about 3' in scale..... Probably "N" scale wheat or hay..... Check this out.... https://www.sceneryexpress.com/Grass-Mats/departments/1051/ From that link you get to this.... https://www.sceneryexpress.com/NEW-12MM-MEADOW-GREEN-STATIC-GRASS-40g_14-oz/productinfo/NH07110/ 12 mm right in what your looking for and it's colored green or golden, late spring/early summer to late fall harvest time..... close to perfect for June in French fields... And this, How to build a Grassinator http://www.pacificcoastairlinerr.com/grassinator/ I hope this helps as I can't find much in the way of tall grass in mats or sheets... Fake Fur is another technique that has gotten good results...
Cool! I'm glad he did change his mind, He makes a good product I would definitely second the motion to get masks from Kenny.... They ARE worth it....
- 321 replies
- Finished
- Flower-class
Look like your learning curve is beginning to shallow out.... Excellent, it will get to be even more fun when it's flatlined.... Great deal! Enjoy...
- 460 replies
- Finished
- Flower-class
Yeah I know, when I talked to him about getting glue, I asked about masks for my Gwin build he told me all he is doing now is selling off the residuals left over... He may have changed his mind though it's been a while since I talked with him...
- 321 replies
- Finished
- Flower-class
Kenny quit making masks over two years ago.... He still makes Gator's Grip glue though....
- 321 replies
- Finished
- Flower-class
A suggestion? Thin copy paper, find the font you like, scale to the size you need, print, cutout the individual number/letters, soak in a 50/50 mix of PVA and water, stick it to the side, when dry, clear flat overcoat it....... I've seen it done on much smaller models.... 2nd method? Heavy paper like card stock, find the font you like, scale to the size you need, print, cutout the individual number/letters, use the sheet as a template for spray painting them on.... Numbers/letters in that size are easy with a computer....
- 321 replies
- Finished
- Flower-class
Thanks my friend, Just figured I would take one out and just build it... Nothing fancy, straight outta the box... I've seen a lot of examples of the (what I call) brake line mania especially in the wheel wells doesn't matter that when on the shelf nobody will ever see it but they gotta have them....
