Jeff59
Everything posted by Jeff59
  1. Thanks Yves, made a mess of that write up, even I couldn’t understand it. 😂 better not to rush things, that’s a lesson learnt. As regards details, always end up going in deeper and deeper. Got to try and complete this, that’s my mission.
  2. Hello folks, going to continue with my catch-up on my build as best I can. By the way, these cameras on i pad are brilliant, even shows up the dust. On the bow and stern 3” gun positions , you will see when you look at photos of instructions how fittery they are, even under close examination, ends up try it and see approach. Here’s what I learned. Gun shield, once formed up try for a tack on open end corner, it is fiddle no doubt about it. Turn upside down onto shield roof and glue this from the inside. You will never see it, same as everything behind the shield, the framework for holding the barrel and the shield together was another yuk moment. The instructions show nothing but 90 degree folds for shield supports, doesn’t work that way, the folds next to the pedestal have to be folded well past the 90 degree, the last fold that lines up with the inside of shield I only a bend of approx 30 degrees , you can see this more clearly on the gun lying on its side inside the shield, and that’s not the last problem with this gun. When you eventually get the gun fitting in, I couldn’t get the gunsight with eyepiece to pass through the front shield due to height, eventually just removed the eyepiece and done what I could to bring down the height of the gunsight itself. A awful lot of guddling about. But we’re this gun is mounted there is no room for the gun to be oversize. Spent quite a while trying to get this right. All this info only good for someone using Pontos set. In other words beware. Best of it is when in position you can’t hardly see any of the gun, but you can see how tight it is. Also blocked the gun in using styrene stock, otherwise you could see right through to the other side plus’s the last thing you want is it ending up inside the hull accidentally. Wow hope that helps someone. The small ladder rungs on the side have a nice little template for drilling the holes, nice one Pontos like it. Stick to the drill size asked 0.4 works a treat, just big enough to take the rung hit the little rib there to stop It going in to far, very light pressure with your nail, almost like a push fit. Took photo of scale so if I can do it anybody can. 😂👍 The little cleats beside the davit arms, fiddle and fragile, this is a mission on minimum glue, five each side front and rear decks. Was wondering what these were for, my guess is possible for tying down awnings when they were erected ? There are more of these than numbered in the instructions, all different lengths. it’s to do with trying to keep the pins vertical to the hull, with the hull changing angles along the side. Incidentally you can visit the Mikasa museum and look at photos of ship on line, it’s the only British built battleship surviving, how ironic is that they couldn’t even keep Rolls Royce cars in House, and the only pre dreadnought battleship in existence. Thanks Japan we only just managed to hang onto HMS Victory. Anyway lots of good photos for people looking for details. Right, the davit arms, all from the kit, the Pontos one we’re done in flat etch doubled up with lots of lovely detail, couldn’t by it, might try cutting some of the details of and fit them to the kit parts. You may have noticed my boat davits at the stern stop at deck level, this is because l have decided to totally build and complete the hull up to deck level, thus t only gets painted once, theirs never a point when these types of warships are not going to be delicate to handle so you make your own choice as to what suits you. I have no doubt I shall break something, already have, name somebody that hasn’t ? Don’t expect a reply to that. So the davits were cut at that point for two reasons, painting to this point will be in black grey, above this point light grey. Also stops me braking them, that would be a guarantee. Drilled small 0.3 holes in centre as best I could for pining them much later in the build. Incidentally the first porthole on port side the one that looks huge and out of position at the bow is. Photos on real ship confirm this, also the fist porthole below this doesn’t exist had to plug it with styrene stock. Easy fix. All the existing attachment points for replaced plastic parts filled using suitable stock styrene and extra thin cement, then trimmed and dressed. Just about up to speed now. Other photos show plastic stern deck with raised details removed, used this electric chisel recommend by one of the excellent builds on this site, maybe CWD might be wrong, it’s brill, tad expensive by the time the customs and excise finish fleecing you. No regrets. Used wood dye, shown to stain wooden deck using cotton bud, can see difference to circular part. The rest is just deck fittings for this area. Need to make a choice for light grey, white grey looks really striking, or light grey for more authenticity ? Thanks Canute for your help with info for spray painting, and to Ron Thibault for the video, started the ball rolling for me. 👍
  3. Thanks for that Ron, shall get myself organised and put this into practice. 🤛
  4. Hi, wondering if you would like to help me with the painting of MIKASA. ? I am really a novice at spraying as I am at doing this, first time of trying a build log, Hope I don’t make a fool of myself. The first part for me to tackle is painting the lower hull. First question, colour and maker of paint, thinking on this for final shade.           ( Model Air ) Vallejo, Marion Rojizo 71.030 Hull Red. And does Model Air indicate the consistency is good to use in air brush straight from the bottle. ?  Would like to jump in the deep end and try shading, have seen this on models at shows and think it looks brill. Looking for technical advice on how to achieve convincing results. I have a model of Arizona for a trial run if you think that advisable, was only ever going to do the lower hull on this anyway. Cheers Jeff.
  5. Well, I eventually got the portholes finished. Next topic for discussion is the lower hull. Glueing on the bilge keels is easier done by glueing about two inches at a time and letting set working your way along the length of the keel, doing any fine tuning. Will presume that most people building this kit will have been swayed into buying the detail sets. Can recommend the Pontos set, very comprehensive and quality is excellent, although I think they could do better with their propellers and resin, the rest is highly commendable. Sorry don’t have photos of props at start, let’s just say they were shiny and toy like, but still much better than the plastic ones. I used a Dremel with a fine metal burr, contouring the blades and thinning them at the same time, finishing with filling sticks and fine emery paper, patience, this is not a quick job, happy with the end result though. Photos show difference between metal and plastic. Guess this is why we can’t help spending a fortune on detail sets. The kit shaft were flared up like a blunderbuss to fit the oversize plastic props, so l whittled them down to match brass props Was quiet at my work, trying to think of a homer, since didn’t have the Pontos pedestal stands, thought I might be able to make my own, came up with this graze set up, stainless steel and brass hex bar, has a 6mm plate inside, tapped for m6 bolt. You can see bits of plastic frame inside hull the metal plate then glued in place with some resin glue. Think I shall fold up a thin piece of metal sheet to form a channel just short of the waterline to allow for masking, this should let me set the model on its side whilst fitting photo etch and painting, also will protect the paint on hull bottom from handling. I plan to fit all the details and photo etch to hull before painting, then work on the main decks separate from the hull, with sub assemblies.
  6. Hi fellow ship buffs and modellers, this is a first for me, so your patience and guidance needed probably by the bucketful! I bought this model in my local shop in Edinburgh December 2018. I was directed there by my other half whilst she went Christmas shopping. Is there many of us who get away with languishing in a model shop while the Xmas shopping is getting done😀Anyway, I treated myself to this model, so starts this journey. This version of the Mikasa is the 1902 Hobby Boss kit, the dark grey - light grey colour scheme, which I think is the most striking. My usual approach at the start of a build is to drill the portholes out; my preference is to drill the holes from outside then countersink the holes on the inside, easier done with the hull in two halves. This is a slow process using a pin vice, finger covering the hole on the outside and you lightly work a larger bit from the inside until you can feel the bit touching your finger - then becomes a visual (and don’t drill my finger affair) until you get the desired effect. Although this is time consuming, it gives the desired effect of a porthole instead of looking into a hole. Which is much better if you are using fibre optics etc. The hull halves went together reasonably well with the usual filling dressing gets a good result. Probably at at this stage, I found the Pontos detail set online, which as we all know is an absolute must for ship modellers these days. I remember when they first came out in the early 80s I had a 1/350 set for Yamato - brilliant! Still have some if this set with the instructions. Gold medal models I think. Positively lego Like compared to what’s on the market now. 😂 Problem is, it must add about 2 years to a model build. Don’t actually know - never finished one! Here’s hoping I can change that. Incidentally got the Pontos set for Christmas 2019 I thin. Can’t remember. Having found this web-site showing all the builds, this has inspired me even further. (I shall mention their builds later.) I am impressed with all the interaction and help on this site. You know what they say; you are never finished learning until you are 6 feet under! Anyway I started with the porthole etch to the hull. My advice- never hurry, treat every porthole as if it is a one off. Tricky trying to glue these; ended up with my standard practice with a small amount of glue on the end of fine tweezers, applied at the side of etch trying to tack it. Give it a few seconds until it has a hold, then work around the porthole to seal it on the hull. Less glue is best result. Then tidy up with a sharp blade when dry. I shall stop at this point and pick up where I left off on my next post. I have a question, Is it alright to post photo of kit instructions as a reference to what you are trying to achieve?
