SkiBee
Everything posted by SkiBee
  1. More mistakes on the Garboard planks, I could not dry fit the garboards prior to cutting the rabbet and beveling the other side of the plank. I was still waiting on the glue to set on the keel and bottom planks, to many clamps and rubber bands. This resulted in the error that I cut the rabbet and beveled the planks on the wrong side. I did not want to make new garboard planks and it appeared that the side plank fits nicely next to the garboard plank anyway. You can see that the angle on the end of the plank is going the wrong way to the transom. The good thing was the planks were long enough that this did not matter. I actually formed the curves in the side planks by dry fitting them to the mold/transom, then wetted them and used a hair drier to set the curve. It worked very nice. You can see that the forward end of the side planks fit better next to the garboard planks and fwd transom, much better then the garboards. It looks like I cut the rabbet on the wrong side, but I think that is due to the finger pressure I was pushing down on the plank why the glue set. I still feel that if there were full scale model plans with the kit or in the instructions, I would not made these errors. Still, I thank everyone that gave me input on were to cut the rabbet, THANKS
  2. Thank you all for your input. Kurt, I was wondering after I cut the full length rabbet if it was just on the end. It's great to have a place to go to get help.
  3. HELP, does anyone have recommendations on how to cut a rabbit into planks without cutting thru the plank and chiseling to deep. I was not happy with the results of cutting the rabbit into the garboard planks. I first used a angle blade to cut the depth of the line then used a chisel blade to chisel out the rabbit to the cut line. In a number of areas I cut all the way through the plank when I was cutting width line and then I chiseled to deep past the cut or took out to much. So my rabbits were all over the place.
  4. I did bevel the two bottom planks to the etched line. I bent the bottom and keel planks around a large margarita glass but then when I went to dry fit on the build board it was way too much of a curve. So, I had to weigh them down on a flat surface overnight which took out most of the bend. I found it easier to set the curve by wetting the plank and rubber band it to the transoms and mold frames. However, in the areas without a mold board, it resulted in a extra bend down, see picture below where I circled the bend. I’m hoping that when I glue the keel and garboard planks to the bottom planks it will take out the bend. I also had a problem with keeping both transoms square to the board and each other. I think that the interference fit with the transom and the build board supports had to much play. So I’m going to try and glue some extra supports to the board to limit the movement of the transoms to keep them square.
  5. Fwd & Aft Transoms: These seemed straight forward but when it came time to glue the knees on, I wasn’t sure from the instructions did the short or long end of the knee get glued to the transoms. I did look at the full scale plans on page 3 and it looked like the short ends went next to the transoms. The lines on the outside of the fwd transom did help in sanding the fairing bevel. The aft transom was a little more of a challenge to bevel, it appeared from the lines on the aft face of the transom indicated different amount of bevel as you went from the bottom to sides. I hope I did it right, time will tell when I plank the sides. By the way, I do like when the kit includes a build board, I had to build my own for the 18th Century Long Boat. Started to dry fit and look at how the bottom planks are installed. For the two bottom planks, the instructions state that there is a 1” etched line that you are to bevel to. But the line is not an 1”, looking at the picture it looks like maybe they were referring to a full scale 1”. On the inside of the outer planks and the keel plank there are etched lines but no reference to them in the instructions. I had to assume that they were there to indicate the amount of overlap of the keel plank and the outer bottom planks. Time will tell as I plank the hull.
  6. This is kind of my second build, I finished the ‘Lowell Grand Banks Dory’ and got about half way through the ‘18th Century Long Boat’ both by Shipways when I decided to shift to this boat the ‘Norwegian Sailing Pram’. This is the second in a beginner series of “progressive model tutorials” designed by David Antscherl. I did learn a lot about wooden ships and how to build wooden models from the Dory. I decided to shift sails when I noticed that the Pram was finally for sale by Model Shipways and I thought I could use the additional learning experience especially rigging. The Long Boat rigging is supposed to be fairly simple but the Pram rigging looked even simpler. One thing I’ve noticed is that the instructions for these ‘beginner’ models seem to assume the builder knows a fair amount of how to build a model boat. In my years I’ve built many plastic models but not wood models and I’m really a novice. So, I’m keeping track of recommendations to improve the instructions as I progress through this build. First, I’ve notice that the Pram instructions are missing a lot of instruction points that could easily be corrected with a few annotated pictures and plans. I strongly recommend that a set of scaled plans be included in the kit. The only plan is the one below that is from a real pram design. Even though the Dory was a simple boat to build, I used the plans constantly to figure out things that were not written in the instructions.
  7. Thanks for the input it was very helpful! I did use Testor’s Dullcote on both sides of the frieze as a protective coat, then I used my wife’s mod-podge (essentially water downed white glue) to glue the frieze to the boat. Both worked very well. Next, I made the hinges and mast retainer. I glued both with white glue but I was concerned about the mast retainer not being strong enough so I put some supper glue on as a overlay and fillet. I made it a little shiny but later I’ll spray the whole boat with a matte finish which should dull it. Then I made the pintles and glued them onto the rudder. I think I’m going to take a break from completing this boat and start the Model Shipways Norwegian Sailing Pram. It looks like the rigging is simpler and might be easier to learn about rigging and sails. My first build was the Model Shipways Lowell Grand Banks Dory by David Antscherl, which I’ve stated before was a fantastic first build. So I think the Pram will be a good learning tool also, back in a while.
  8. Cap Rail: This was a challenge to try cut it to a form as close to the end product as possible, still ended up sanding to size quite and bit. Based on my poor cutting to size of the platforms I took more time. I should have tried a template to see if that had helped, but I was ok with the end product. Also, used filler to fill in the cap at the bow next to the stem, I wasn’t worried to much since it would get painted red. I painted the outside edge of the Cap Rail white but I covered it up when I painted the top of the rail red. Maybe, I will try tape off the top of the rail next time I paint the edge of the rail white. I took a little more time cutting the aft seats and they turned out better than the platforms. HELP NEEDED: 1. The instructions say to pre-spray the frieze with a ‘protective artist’s fixative’, does anybody of a recommendation of what to spray the frieze with? I was thinking of just waiting to the end of the build, since I like to spray all the wood with a Matte clear coat. 2. Does anyone have a recommendation on what should I use to glue the frieze to the hull with?
  9. Ryland & VTHokiee, I ended up using "Elmer's Carpenter's Wood Filler" to fill the gaps since I have used it on larger projects and it sands, takes stain and paints well. Plus it comes in a small container. (VTHokiee, great school, I lived in Springfield, VA for ten years and had some great co-workers and neighbors that were Hokiee's) I installed the Floorboards and Platforms next, not the Cap Rail and frieze. I wanted to build the platforms and then stain the hull, floorboards and platforms all at the same time without the cap rail. There were gaps between the hull and the platforms, below was even a second attempt cutting them, I did use a template made from a file folder. I think I just need to take more time next time I cut something like this. I'm hoping that the thwarts and locker/seats will hide most of my sloppy work. I used the mixture of 50/50 Minwax Natural and Light Oak per the instructions, I did use Minwax pre-stain first. The results were not as rich of a hue while being very light as I hoped, I think that was the natural color of the basswood and the way it absorbs the stain compared to a hard wood. But I think it will look better once I paint the red on the cap rail and the white below the waterline. Next I painted the inside two top planks red. I was not happy about the coverage of the red paint over the stained basswood, it turned out quite dark after two coats. The red paint on the top of the frames was even darker due to the amount of stain they took, so I painted the top of the frames white then repainted them red. That turned out much better. On to the Cap Rail and Risers.
  10. Does anyone have a recommendation on what to use to fill mistakes? I would like to stain the repair.
  11. Planking the model: In general, the planking went well except two errors that I learned from. First, I laid down the garboard and shear planks and one additional plank next to them. Then I tried to determine the number of planks and started to adjust the width of the remaining planks. I followed the recommendations in this website on how to determine the width of the planks and installed the next three planks after trimming them to a reduced width, from bottom up. But as I tried to continue to determine the width I came to the conclusion I should have followed the instructions and started to lay down full width planks from top down. When I got to the point that a full plank would leave to small and irregular plank, I then cut down two planks to fill the gap. In the pictures you can see the final gap on the starboard side and if you look closely you can see the number of small planks that I installed prior. Second lesson learned, when clamping the planks down I indented the basswood plank on the forward end on both sides. Now I have to figure out what kind of putty I can use that will take a light stain, anybody have a recommendation.
  12. I looked at Justin P’s build on this web site and decided to cut the fwd end of the garboard plank in a curve taper. Also, I tried to bend a second plank around a straight diagonal cut and it didn’t bend smoothly, so I went with the curve cut. Decided on a ¾ in. cut, after bending a plank on a small French curve, it seemed to be the smoothest curve length. It appeared to be a good choice as I continued to plank. I also used the small French curve as a jig to bend the remaining planks, worked grate! I knew I saved my old high school drafting tools for a reason and my old wood drafting pad has worked great as a mobile work table top.
  13. Justin How did you figure out, how to cut the forward curve on the garboard plank, on the 18th Century Long Boat? Need help!
  14. Fairing the Hull: I did take my time to ensure that there were good transitions from bulkhead to bulkhead, something I learned from my first build. Also not to remove to much wood from the depth of the bulkhead frames. Planking: Even the first port sheer plank compound bend was a challenge, it seems to go well. There is not as much bend that I have seen in other builds but I think it will be ok. The instructions were misleading, the written instruction say to follow the drawn plans for the bend which was about a 1/8 inch below the top of the bulkhead, but then the written instructions say it should be a 1/16 inch drop. Mine start at about 1/16 inch in the middle few planks and then decreases to almost 0 at the transom and bow stem. I then glued the starboard sheer plank, but once dried it looked almost straight for most of the bulkheads and less then 1/16 inch. So out came the alcohol and will start over. As I was removing the plank, broke a small chunk out of the bulkhead frame, so glued in back in. Question for someone who has built this model: Started to look at how to trim the garboard plank and I don’t have a clue on how it should be ‘tapered toward the bow’. Most pictures show it curved and some show it a straight cut tapper. And if it is curved, how much?
  15. This is the start of my second build, the ‘18th Century Long Boat’ by Model Shipways. I had bought this boat prior to reading some threads on this web site, which convinced me that my first build should be the ‘Lowell Grand Banks Dory’ by Shipways. This model was a fantastic first build; it was cheap, simple in design, covered a number of needed skills for the future, and allowed me to make a lot of mistakes on a cheap model. Even with the errors, I was very satisfied with the outcome and enjoyed the build. Actually, my first wood boat was a Model Shipways solid hull that I tried to build about 20 years ago. I never got past shaping the hull. I tried to start it a few times and always got frustrated since I didn’t know what to do or how to finish the hull. Now with COVID, I started building plastic airplane models again which I enjoy very much. But I wanted to do something different and thought about wood ship models. I always like how they looked in stores and really enjoyed them in the U.S. Naval Academy museum. So here I am with my second build, the ‘18th Century Long Boat’. I’ve tried to apply what I learned from t he Lowell Grand Banks Dory and this web site. False Keel: not sure I got the rabbet right, did it all by just sanding, we’ll see when I start planking. For a model that I’m sure a lot of beginners build, the instructions could use a lot more pictures. Didn’t look at other build logs until now. Attaching the Bulkheads: I built a simple jig to hold the keel while I glued the bulkhead on, learned that from this site. I applied a lot that I learned about the importance of getting the bulkheads plum and level from my first build and tried to apply here. I relied on a small 1/64 metal scale I had from the old days and did a lot of measurements on each bulkhead while the wood glue was setting. I also glued scrap wood pieces to the top of the waste bulkheads to keep them plum/level. This work extremely well since I could not figure a way to hold the bulkheads with the few clamps I have. Learned this from other build logs.
  16. I had bought the ‘18th Century Long Boat’ by Model Shipways prior to reading some threads on this web site, which convinced me that my first build should be the ‘Lowell Grand Banks Dory’ by Shipways. This model was a fantastic first build; it was cheap, simple in design, covered a number of needed skills for the future, and allowed me to make a lot of mistakes on a cheap model. Another great thing about this model were the instructions, they were clear and very helpful and clear. Also, the build logs and other articles on this Web Site were extremely helpful. Even with the errors, I was very satisfied with the outcome and enjoyed the build. I would highly recommend that anyone new to model shipbuilding start with the Lowell Grand Banks Dory!!!!! Actually, my first wood boat was a Model Shipways solid hull that I tried to build about 20 years ago. I never got past shaping the hull. I tried to start it a few times and always got frustrated since I didn’t know what to do or how to finish the hull. Now with COVID, I started building plastic airplane models again which I enjoy very much. But I wanted to do something different and thought about wood ship models. I always like how they looked in stores and really enjoyed them in the U.S. Naval Academy museum.
