ubjs
Members-
Everything posted by ubjs
I'm building a Norwegian Pram myself now, but it's not going well. I don't get along with dory builds at all, I've tried Bluejackets before. To all beginners who are trying to put together a dory and not succeeding, I can console you with the fact that it's much easier to build a regular hull with a little more real wood. I've built a number of hulls, Vasa, Bohuslän, Polaris, Spray, Lilla Dan. They're not fantastic builds but ok. But putting together a Norwegian Pram, as I said, doesn't go well. I don't get along with this thin, soft wood. When it comes to bending the hull parts for the Pram, I recommend the same as Palmerit. I usually bend with an electric plank bender, but it doesn't work for the Pram, you get burn marks right away and also sinks in the wood.
It's starting to take hold, now you just have to clear coat as many times as you can with wet sanding in between. :) But it's just a fairly modern plastic body and not a Rolls with real sheet metal so this finish will probably be enough. Is this the best looking F1 with advertising? Of course the Alfas, Silver Arrows and the green Lotuses were better looking. :)
Interesting build. I, like many other children in Sweden, got it as a Christmas present in 1973. I remember the black parts that were treated so that they looked painted when you unpacked the kit. We built many of Tamiya's big F1s in the following years, we learned to use paint sprayers from Badger and run our own electrical and fuel lines in the engine. Everything was thrown away when Ronnie died at Monza in 1978. I've looked at the updated kit but don't know if I would feel good about building it. Luckily, I have plenty of wooden boats on my shelves that need to be built. Another thing I remember from 73 was the fit. We were used to a lot of Airfix and this kit was amazing compared to Airfix. But how good is it today?
Planking problems
ubjs replied to Mrgj24's topic in Building, Framing, Planking and plating a ships hull and deck
You also have to fair the frames more (bulwarks is something else). As soon the planks dont lay flat on the frames you are beginning to get problems and as we see on your picture the problems get worse for every plank you try to attach. You must bend planks in two directions so they follow the frames. -
I dont like cleaning an airbrush. I have several airbrushes and compressor but today I never use them. Today you could find a lot of colors in spray cans and you get a good result with them. I often use Tamiya primer spray can and then a brush when I paint ships or modelhouses. If you use a primer first its much easier to get a good result with brushpainting. With metal I use what in swedish is kallgalv, its a car primer you use repairing full scale cars. After that I brushpaint.
Planking disaster
ubjs replied to sgrez's topic in Building, Framing, Planking and plating a ships hull and deck
Look at this build log of Polaris and you get some ideas for the second planking. Your first planking looks ok so far. -
Best White Wood Glue For Ship Building
ubjs replied to OldeManToad's topic in Modeling tools and Workshop Equipment
If you react to ca-glue, you must be very careful. There is a risk of developing an allergy to approx. I can't be in the same room as someone who glues with ca-glue. I also can't use fully liquid plastic glue, but what is more like a cream, for example from Faller with a narrow metal spout works well for me. So be careful, once you develop an allergy, there is unfortunately no way back. -
How are you planning to bend your planks? I like my electric plank bender, but there is other ways to bend planks. You can easily make sanding tools by gluing sandpaper to a piece of wood in the shape you want. I usually use contact glue for this. You need a straight board or something to put the frames on the keel. Something to check that you are gluing them perpendicularly. I usually use Lego pieces!
Spray from Bluejacket.
I'm thinking if it would be worth trying on the 1st planking. Speaking of planking guides, I can forget most of what I've read if I want to build a model that looks like the real ship. If I look at the Vasa ship, they have planked it completely wrong, pointed planks in the bow, etc. So the question is should I build according to the model building gurus or should I build it as it looks in real life? As for the Vasa, it is easy to check how it is made, perhaps many of the ships of that time looked exactly like that in reality and not as perfect as model builders often build them?
New to ship modelling? But what do you build first?
ubjs replied to MSW's topic in Wood ship model kits
The thing about wooden ships is that most things can be fixed. The important thing is to start building. You will make mistakes but they can be fixed. If you fail to plank Polaris, you can always plaster her and paint. When you do the second planking on Polaris with the thinner strips, I suggest that you finish planking one sian first. Then the other side will probably be better and you can turn it towards the ¨audience¨. My tip, whatever ship you choose, buy it now and start building. You learn step by step by building, not by reading. -
BR-18 Locomotive by Greg Davis - OcCre - 1/32
ubjs replied to Greg Davis's topic in Non-ship/categorised builds
Can you motorize it? I have some Märklin carriages in 1:32 scale and a garden railway, but mostly LGB trains. -
Reminds me of Torborg, a small Norwegian rowing and sailing boat from Billings. Build log: https://shipsofscale.com/sosforums/threads/torborg-billing-boats-1-20.6226/ -
There are of course a lot of options. I searched at Krick on simple and here is the list. https://www.krickshop.de/Models/Static-Models.htm?shop=krick_e&SessionId=&a=catalog&p=80&filter=k10g53p55 Billing boats are hated by Americans, I understand, but for Europeans, they have many interesting ships. Here we Europeans have the opposite compared to Model Shipways, Billings kits are relatively cheap in Europe and probably more expensive in the US. I have built the fishing boat Norden and it is nice and absolutely suitable as a first boat. Link to Norden, the instructions can be downloaded. Billings instructions are based on exploded views instead of text. https://www.billingboats.com/index.php/modelboats-footer/39/120/boats/the-beginner/P-bb603-norden-cutter
