Everything posted by Balclutha75
Thanks md1400cs! I'm actually pleased with how it generally looks, and have had a lot of fun working on it.
I suspect many of you have been waiting on tenterhooks to see how this build has been progressing, and that you can recognize sarcasm when you see it. I've slowly moved forward in between several large home projects, and have now reached a possible impasse. The hull planks have been moving steadily away from the frames for several strakes. I saw this happening but figured I would come up with something near the last strake. And I think I have: my goose is cooked! As you can see, the angle of the upper strakes needs to be more vertical. I've thought of steaming or soaking the entire side of the boat and bending inward so I can glue to the frames. But I suspect disaster lies down that path (?). The Skipper (she doesn't want to be an Admiral) has said that for "only" $108 I should chalk this up to a learning experience, get another kit, and start anew. There is clearly some benefit to that strategy, and perhaps the next best move. I suppose some solace can be found in James H's build log. He is an MSW Admin who gave a generally favorable review to this kit. But the last entry in his nice log simply says: "Struggling with pre-formed ply planking at moment, so put on hiatus." By the way, I turned 71 last month and the Skipper got me a very nice stylized Viking boat T-shirt. Looks great!
Thanks for posting and good luck moving forward. Indeed, this should be helpful for future builders. I've run into a similar issue on my Amati build, fairly serious it seems to me. I'll try to post an update to my build log with a similar hope - offer help to the next beginner tacking the kit. Still, you've got a nice boat looking here.
Very belated Happy Birthday and congrats on getting a photo in the NRG calendar! I bought one last night, got the shipping notice already, and after the fact saw the thread about it here. Cool!
Also sorry to read of these troubles. I can't offer any help, but it looks like you have some great minds working on it. I'm having a similar problem on my Amati kit, as more planks are glued they are getting farther and farther away from the frames. I'm about to turn the corner and be above deck. Not sure what I'll do as there will be a gap between the frame and plank that shouldn't be there. I don't recall other Amati builders having this problem. Hopefully there will be a solution, but I'll burn that bridge when I'm standing on it. Good luck with your issues.
Andrew, Yes, the Jack P log is another masterpiece, full of all kinds of fascinating diversions, like yours. Here is where he drills the holes for his nails. He may mention the source farther down. I should reread the whole thing. Lace making pins were new to me. I've since downloaded a catalog (catalogue?) from the Tichy train group that has lots of track nails. Rolling your own crossed my mind and I even wondered if I could use square stock, but I let that thought quickly go. - Nelson
Thanks for the encouragement Steven! There are a number of construction flaws I could point out, but all in all, considering it's a first ever model so far it's "OK". Next up, I've just purchased a can of MinWax pre-stain conditioner and will start experimenting with applying stain to some scrap pieces.
Making some slow progress, now have four strakes on each side, but want to point out a problem in case it helps another beginner some day. Kind of related to my shim question above. After the 4th strake I dry fitted the bow and stern deck pieces and they didn't fit. The strakes were bent in to far after the last frame. So I'm having to sand a bit off each of the decks. Now I'm planning to glue these pieces before adding any more strakes, which should help reestablish the proper curve to the hull. The circles show where I had to sand to get the deck to fit. Here's Captain Aegir, in authentic Viking garb, checking out the hull. He wishes Floki was working on it instead of me, but so far he's not planning to cut back on my ale allowance.
The red-yellow resonates with me because I was thinking to make my top two strakes red and yellow, and do the sail similar colors. But I also like your red-yellow-blue, 7th one down, I guess reminiscent of the Sea Stallion. In any case another great use of your 3D modeling. The "Oseberg Buddha" has a bit of red-yellow theme. I have a couple books on my bookshelf with red and yellow dust jackets that look nice. Non-Viking related but kind of classics in their genre.
My little shim seemed like it achieved the desired effect. Whether it was actually necessary or not is an open question, but I'm glad I did it. I did do something I had thought of earlier up thread - used my new divider to transfer the distances on the 1:1 scale drawing to the bow. Presumably that will help in correctly positioning the strakes as I proceed with gluing.
Thanks for sharing this process, it's all been super educational for me. I was interested in your staining before removing the planks, something I had been scratching my head about. I decided to glue first stain later. Good luck and stay well!
Another vote (from a complete newbie, so worth less than $0.02), for Walnut A. Agree with Cathead that the mahogany Is too red. Did you decide against oak? The Model Expo paints I have are short, squat bottles. Now I see there’s a practical reason for that. Thanks for the linguistic lesson. Louie, your Hasting Battle looks incredible.
Thanks Steven, I’ll probably go this route. But no worries, no doubt I’ll have something worse visible to everyone before I’m done.
Thanks, yes that could work and I'll do that. Actually, the shadow is not as bad as it looks in the photo because more clamps will help, but they obstructed what I was trying to show. My wife said I should just ignore it, but it's kind of fun to think through a solution to the problem. And I think it will look better. I'll wait another couple days before gluing. Hopefully the finished model will have "coolness". 🙂 By the way, as you can see I'm making use of the clamps you showed me. I found the soft handled ones at the pharmacy a week ago. I like the colors since I can find them easily.
Don't know if this shows it any better. So far it's the best option I'm coming up with that's within my skill set.
I'm enjoying your build log Andrew, as I stumble along on my Viking ship. Seems like Viking ships rule on this forum right now. My plan is also to go with a walunt / oak mix, so I'll be interested to see what you come up with, and will presumably learn as you go. I have paints from Mode Expo on hand already. Nelson
Thanks, but not quite so fast Steven! 😄 I have a screw up in the planking. Due to poor fairing of the frame, excessive clamping, or some other combination of missteps, I've broken the smooth curve of the hull at the last frames. This photo should indicate it, though this a bit exaggerated, it's not quite this bad. You can see the divot in the garboard strake. My plan for making it better is to place a tapered shim under the next plank, something like this. Then the next plank can resume the desired curve. It looked pretty good when I laid the next plank on top of the shim, it kind of disappears. Please stop me before I start gluing if someone has a better idea. Thanks! Nelson
With the dog days of summer here I've been maximizing outdoor time and haven't done much on the boat in recent weeks. But the other day I decided to take a step forward and glue the garboard strakes. I first bent them with the water immersion technique mentioned above, and the result seemed pretty good. This is where she sits right now. (Starboard side view, bent port side plank sitting in front) With this bending technique - soak, clamp, glue, clamp - I can only do max one strake per day, and since that won’t happen it will be well over a month before the hull is planked. I’ll report back then. Being my first ever build, at this point I have no idea how good of a job I’m doing or if things will turn out well. Perhaps that’s makes this hobby seem like an adventure!
I was mostly kidding! I'll no doubt at least give it a try and see what happens, that will be some months from now. I'll report back either way. Thanks.
- 35 replies
- oseberg
- billing boats
Eric, thanks again, really appreciate it. I found "soft grip binder clips" on amazon, a Staples brand, so I can probably find them at any office store. Great idea, whoever thought it up, I'll give it a try. The clothespin trick is new to me as well, thanks for that. Now I'm looking around the house and wondering what other things I might have that could be useful!
