Rik Thistle
Everything posted by Rik Thistle
  1. Shipman, Bonhams - That is indeed a gorgeous looking piece of machinery. Est £6k-£7k seems a bit of a steal, but I don't have a motorcycle background so perhaps there are quite a few still around. Just found what appears to be, to my untrained eye, an Army version of the same machine..... 1944 Triumph 3HW 350cc Ex National Motorcycle Museum Sold for £12,650, Dec 2020 - https://www.handh.co.uk/auction/lot/149-1944-triumph-3hw--350cc/?lot=51466&sd=1 Richard
  2. It's fascinating to watch all this take form. There is a heck of a lot of detail design in the process and I'm enjoying the journey as it all comes together. Do you have plans to make a model from this work ? ... eg 3D print. Richard
  3. As OC says, really nice work. Looking forward to the completed design.... I wish I had studied CAD, but jumped ship just as it was arriving. Not saying I'd match your standard Egilman, but it is a nice string to one's bow to be able to design items on a computer. Richard
  4. Hi all, Some more updates on the radio truck progress. Only 4 pics but they cover a lot of fiddly parts being installed. First, an easy one.... the tyres and wheels. The pin vice was used to open out locating holes for the wheel pairs. The wheels were given a quick paint using Black and Olive Green. They will later have dust etc added. Above. Also added were more Prop shafts. I found these difficult to install since since either the engine or Diff (... the prop connects both) needs to not yet have been glued into final position. The problem being the props 'key in' to the Universal Joints....anyway, I found a way around this with the engine and diff already glued in to position ;-) Below, preparing the exhaust system. There are three pieces of Photo Etch added to the exhaust...a wrap-around for the muffler/silencer plus two tiny PE exhaust mounting brackets. Below, exhaust now installed, and given a quick 'rust' paint job. And the wheels...and radiator assembly added. It's slowly starting to look like something which may be able to move under it's own steam. Next post should include the fitting of the driver cabin seats, the bulkhead and some flooring. All for now, catch you soon, Richard
  5. James, She looks ready to take-off. Very well done. And the base is a great addition. Richard
  6. Egilman, I hadn't found any of those videos...thank you! And it's great that these vehicles are still around. Richard
  7. Egilman, The truck was based on a Chevrolet .... https://en.wikipedia.org/wiki/Chevrolet_G506 I don't have my notes at hand (...on a laptop at the moment) but that Chevy truck was appaently used (very successfully) in WWII in a lot of different permutations. There is also a generator trailer in the kit...that is a project in it's own right! And then there is the radio operator (squeezed inside the truck), and driver to make. I have a kit of British figures that might do ... the Brits did operate the K51. So plenty to yet plan for. Yes, just about everything will be drab Olive, apart from where there are small oil/grease leaks eg engine, prop shafts etc...and mud, dust and the like. Thanks, Richard
  8. CDW, Thanks for that. It sure has a lot of detail...way more than I'd expected. I had hoped that I could have completed the kit in roughly the same timescale as the Churchill tank or Archer SPG, but I suspect it will take much longer than that ...I just hope I have the attention span to stay the course 😉 As an aside I don't have a spray gun...brushes only...and that wasn't too big an issue with the Churchill/Archer since there were no really large panels, and the tank/SPG were covered in mud (to some degree) anyway. But we'll get there....he says 🙂 Regards, Richard
  9. Hi all, Thanks for all the feedback...appreciated as always. Another short update, whilst the garden etc currently dominates my time 🙂 Most of the following pics are related to the frame and the engine. Plus adding some Photo Etch. I was still using my flat pliers, rather than the new PE bending tool mentioned earlier. The engine block starts to get assembled And some parts being added to the block. Three of the sprues included in the kit...there are about x25 more sprues still to be used. This kit is way more detailed than I had imagined. A final close up of the finished engine, soon to be fitted to the chassis, then all the services, exhaust pipes etc. Sorry this is so short, but best I post something now or I will never be able to recollect what I was up to last time I posted. Once I get through the chassis build I should start to be adding some panel work etc. All for now, Richard
  10. It looks like the Small Shop has a UK distributor ... https://www.historexagents.com/# If I decide to later go for one of the larger Small Shop PE benders then I will buy from them, assuming the potentail new owers still use that distributor. Richard
  11. Jack, "...looks almost identical to the Hold and Fold tool produced by The Small Shop." It does. There seems to be a lot of look-alikes about. Did the Small Shop come up with original layout? If so, apologies to them for sending my money East. Richard Edit: Just read Egilman's post above..
  12. Ken, CDW, Alan, Thanks for the feedback. I'm slowly finding my way in the Plastic modelling world...so had started PE bending by using small, needle nose pliers with smooth inside faces, straight pieces of metal etc. But these PE parts are so small, compared to what I'm used to I ended up with bend lines that I am not completely happy with. I had had an earlier look at the two pliers you linked to CDW (...maybe I had seen them being used in one of your builds?) and almost pressed the Buy button but ended up, for whatever reason, going with the Bending Tool. I'll let you know/see how I get on. As for the K51 build, I'm distracted by other things at the moment but am trying to slowly trudge my way though the chassis/frame build. I think once I get through that section my posts will become more regular again. Thanks again, Richard
  13. To help make better bends etc in the PhotoEtch that was supplied with the kit, I have bought a small bending tool from Amazon .... https://www.amazon.co.uk/dp/B08DNT298P?psc=1&ref=ppx_yo2ov_dt_b_product_details ..... the price seems to have gone up a bit since I bought it, IIRC. It is made of metal and seems reasonably well made. Brief usage instructions are printed on the underside of the box. Richard
  14. Hi James, This is my 3rd 1/35 scale vehicle...the other two were Tamiya. There are an awful lot of small, fiddly parts in this kit, with a fair bit of flash and ejector pin remnants on a lot of those parts. Also, the part to part location spots are a bit indistinct at times. However, I find the subject matter interesting and important - that's mainly why I chose it. Building up the chassis is taking a while...a bit longer than I had anticipated. And then there will be the 'when to paint' question ie paint sub-assembllies or wait till the whole model is finished..... I'll probably go with sub-assemblies. I might (...very small might) add some interior LED type lighting) but will likely position the truck in a scenario eg top of a small rise for better radio coverage. But I'm a long ways from all that at the moment. And Spring has arrived, the grass needs cutting, the garden shed/workshop has been re-roofed. etc..so a number of other 'attractions' are vying for attention. Thanks for dropping in 🙂 Richard
  15. James, That NEC show looks very good. And lots of cracking models being exhibited. Very interesting that Pete Waterman is putting his clout behind it....bodes well. Richard
  16. Haliburton, That's a very impressive conclusion to the build. Very well done. It got me wondering if the gunners used 'ear defenders'? But, from what I read online, it seems they weren't allowed to since they would not be able to hear orders. Richard PS: I worked besides a retired tank Commander for a while....and he had hearing aids.
  17. Phil, Thanks for all that. I found a short thread on Reddit that semed to throw some light on the subject - sorry 😉 ... https://www.reddit.com/r/askscience/comments/mx04t/my_eyes_see_colors_differently_than_the_other_is/ I've got an older version of Adobe CS3 that can do all the photo manipulation ever needed, not that I fully use all it's capabilities. I tend to defalult to Paint.net as it's quick and simple. Yes, I saw your mention of the ring light the other day...I was almost pressing the Buy button but first checked my Panasonic micro 4/3 rd lenses ...and only one of them is covered by the lens filter thread diameters available. So, thinking about what Wefalck said, I'll try to make more of an effort to reduce the differing light sources falling on the subject. Nature's multiple colours - yes, and people think trees are only coloured 'green'...well, about a million different shades of green and combinations thereoff. When I started photography I was using B&W film and had my own darkroom.... B&W can be quite beautiful, as Ansel Adams showed us many decades ago. I have a number of his prints dotted around the house. This all remins me, I am overdue an eyetest. Richard
  18. One thing to avoid is mixing lights from technologically different sources, such as LED and incandescent or daylight. I'm very guilty of that when taking Build images with my phone's camera.....I have daylight, ceiling LEDs, and two 'photography LED lamps' all going at the same time....plus, sometimes, Flash. Richard
  19. Phil, Very interesting, particularly your two eyes. I did a short photography course a few years back and remember using a grey scale card (17 or 18% greyscale?) to position where I would be pointing the camera to set the balance. Do you use a similar card for Custom? Richard
  20. Michael, Welcome to MSW. Vanguard Models do a couple of excellent Scottish fishing vessel models - the Fifie and the Zulu, plus a number of other equally good UK fishing vessels. There is a preserved Fife Reaper in Anstruther harbour ..... https://www.scotfishmuseum.org/zulu-gallery.php and https://www.classicboat.co.uk/news/iconic-fifie-reaper-to-be-reopened-to-public-after-1m-restoration/ There are many superb builds of all these vessels on MSW to enjoy and ask questions about. Richard
  21. James, That's a useful last pic in your post above showing the electrics. I recall getting about 3-5mins flight out of my Nano RC helos using one of those batteries. But a helo battery has to power the large diameter main rotor and tail rotor, whereas a fixed wing prop a/c only has the prop to be driven...so I imagine you will get longer flights out of the battery. And of course battery technology also will have improved over the past 10 yrs. Richard
  22. CDW, Welcome on board the truck...space is slightly limited but an extra pair of ears is always welcome 😉 Richard
  23. Hi all, A (very) brief update follows - I've been working on other things for the past week but am trying to keep to a one-post-per-week schedule on the Radio Truck. The vehicle frame is the first part described in the instructions. It is made of many small parts and alignment is done mainly by eye. Some of the parts are not quite as accurately made as, say, Tamiya ones but will no doubt lead to something that does look like the K51 Truck 🙂 Below, the basic parts that form the structure of the fame are removed from the sprue and filed smooth. The kit also comes with a photo-etch sprue. I haven't use PE before so was on a learning curve. I used CA glue to attach the PE parts. Below is the plastic former that part PE1 (x2) is shaped on. A close up of the former in action. Finally, on to the axles. I should make a bit more progress for the next post ...it feels like I have hardly moved forward at all in this post 😉 Anyway, some more info on the radio Transmitter and Receiver from Wiki etc.... https://en.wikipedia.org/wiki/SCR-299 "The SCR-299 was a U.S. Signal Corps mobile military communications unit used during World War II. The SCR-299 "mobile communications unit" was developed to provide long-range communications during World War II. The US Military sought improvements of range, flexibility and durability over its existing SCR-197 and SCR-597 transmitters. In 1942, Hallicrafters Standard HT-4 was selected as the SCR-299's transmitter, known subsequently by its military designation as the BC-610. " There are a couple of good B&W videos of Hallicrafters ruggedising their SCR-299 Transmitter for military use .. The Voice of Victory Part I https://archive.org/details/VoiceofV1944 - Part II here https://archive.org/details/VoiceofV1944_2 Below, the Transmitters being assembled on the production line. The Receivers were BC-312's ...more here....http://www.armyradio.ch/radio-e/us-bc312-e.htm "The receiver BC-312 has been built by several contractors in the U.S. for the US Signal Corps in World War II and has been used as receiver in several wireless stations. The Swiss Army used this receiver in their Funkstation SE-402 / SM 46, an American SCR-499/A bought as war surplus." The 3rd part of the radio system and, arguably, the most important are the transmit and receive antennas...more in a later post. A screen grab from 'The Voice of Victory Part II' showing how the radio truck took messages from General HQ and transmitted that info to the battlefield, and then received information back from the soldiers in the field. Having watched the short 'Voice of Victory' videos it is really quite amazing that commercial equipment could be sufficiently ruggedised to allow it to be carried in the back of a truck across battlefields. Although the glass radio valves were now firmly held by clips, and the electrical modules held in retaining slots, it was still quite an achievement. More soon, Richard
  24. Andrew, Yes, the electronic fittings need to be lightweight. My DX6i Transmitter was used with micro-helicopters and slightly larger (...Blade Nano CPX etc) , and drones. The Receiver I have somewhere in my attic will probably weigh more than the Scrappee so is unlikely to ever be used with a Microaces a/c. If/when I get round to making a Microaces a/c, I'll follow James path and the advice/parts on the Microaces website. Richard PS: I still have dozens of the E-Flite LiPo batteries stored away, but they are probably now well past their use-by date. The Dragon Rapide looks like a classic, but may need more parts replacing should it ever crash 😉
  25. "I emailed Jon at Microaces to see what I should buy. The kit comes with the motor and prop and then you can order the receiver from them which I did. It's the Microaces All In One (AIO) 5CH Micro Receiver. And he recommended a couple of transmitters, I went for the cheaper one because I'm not sure how much I'll actually use it, but of course I want to try it, so I bought a Flysky FS-i6X 10CH Radio Transmitter from Amazon. Regarding the battery and charger he recommended the E-Flite EFLB1501S25 as the one to get with a little USB charger EFLC1008 that charges one battery at a time." Great info, thanks. I already have a Spektrum DX6i 6 channel radio....it's about 10 yrs old.... it did come with a Receiver, which is still in it's box safely tucked away in the attic somewhere.... IIRC, it was maybe a bit too large/heavy for the Scrappee. I recognise the battery you mention, and I do have a charger. But if/when I get round to building a Scrappee, the route of least pain may be to follow your Build of Materials. I have watched a few YT videos of Microaces planes flying and they look good. Anyway, all good stuff 🙂 Richard
