marsalv
NRG Member-
Everything posted by marsalv
Pandora by marsalv - FINISHED - 1:52
marsalv replied to marsalv's topic in - Build logs for subjects built 1751 - 1800
Thanks guys! The milling machine is Proxxon M7 70. -
Thank you to all for very nice comments! I finished the deck, including treenailing and attachment of the sculpers. -
Thanks to all for nice comments. I added the top part of the planking above the wales with free space for decorative moldings. -
Thanks Greg, you are right - not hours but days . I finished the first part of planking above wales. This part will not be colored, so I used here the treenails. -
Thanks to all. The idea for making treenails with needle is not mine, I learned this method from russian modelers . To rtropp: see enclosed picture - front side of the block with treenail is covered with masking tape, block is cuted off with saw. After removing tape you can easily eject treenails from the block. After endless hours I finished the hull treenailing. Result will be more visible after waxing. -
Thank you Greg. Although it is not historically accurate, I decided to leave the hull without copper plating. On the other hand, the whole hull will be with treenails. So I started the "mass" production of the pins (about 8,000 pieces). -
Thanks to all for nice comments . So after about a month of hard work is the planking of the hull under wales finally done. -
So I began planking the hull. It's my first attempt planking in one layer. I'll see what happens, and depending on the result I will decide whether to make copper protection or not. I started with a few plank in keel area. -
Thanks to all . To amateur: I wanted to build a model in scale 1:48. But due to space limitation I chose a compromise scale 1:52. Now is the time to show the figurehead which made for me Doris (for those who do not know her work http://modelshipworld.com/index.php/topic/854-royal-caroline-by-doris-card-1749-140/?hl=doris).I appreciate very much this assistance because my attempt would probably ended very pathetic. -
So I decided to continue on Pandora. I solved before winter whether to use color or not. Finally, the choice fell on a partially colored model and started to spray wales. On the first attempt with airbrush it does not look bad. -
So I returned from my first participation in the national championship, where I won the bronze medal. Thanks to everyone on this forum for your support. The model is placed in a display case, and now I am going into the continuation of another model - http://modelshipworld.com/index.php/topic/7073-pandora-152-by-marsalv/?hl=marsalv
- 206 replies
- royal caroline
- panart
