Barbossa reacted to a post in a topic:
Große Jacht 1679 by Baker - FINISHED - Corel - 1:50 - modified model from the Yacht D'Oro kit
Le Fleuron 1729 by Chris. - scale 1/72 - French warship from Delacroix monograph
Gretel by Bryan Woods - FINISHED - Mamoli - 1:54
HMS Sphinx 1775 by Ronald-V - Vanguard Models - 1:64
Xebec / Sciabecco / Jabeque - 1753 - Amati
Le Chebec Requin 1751 by Ferrus Manus - Heller - 1/50
HMS Pegasus by Barbossa - Amati/Victory Models - 1/64
Shrouds and ratlines...at last ( for the time being ). Still trying to avoid as much as possible bulky knots and joins. The swivel guns : this is the last option by using the pieces provided with the kit. Although dry fit ...seems not that bad. I kinda like the contrast between the copper natural look and the metallic color supports. I'm still in the waiting for a better and feasible alternative. Enfin, wait and see...
- 64 replies
Welkom !
Well,...more or less ready to proceed with the first part of the standing rigging. Foremast, main mast en mizzen mast tops are dry fit. Regarding the mizzen mast, I deviated from the plans and ( accordingly to e.g. Pegasus buildlogs belonging to Moonbug and Blue Ensign ) installed some cleats. As I had to drill a number of very small and undeep holes I was nonetheless anxious to weaken the structure of this item, I limited myself to 5 cleats. It will have to do. The cleats were purchased through the aftermarket and were to be inserted.
- 64 replies
Baker, It definitely is : on the left still the same foremast top. On the right the main mast top ( work in progress ) The holes in the main mast top were all exlusively made with cobalt drills. ( 0,9 mm ) And the difference is just stunning. On the risk of digressing a bit on this specific topic, I can only recommend anyone who's dealing with the same issue : Go for the decent tools : it's money well spent.
- 64 replies
Let's call it a recovery. The inevitable splinters were dealt with putty. I connected the flexishaft to my mini lathe ( proxxon db 250 ) A try out on some leftovers seemed the right thing to do.
- 64 replies
Following Bakers and Moonbugs sound advice : here's the latest purchase. A set of 150 quality drills ( diameters 0,4 till 3,2 mm ) and the Proxxon Flexishaft 110 BF. A try out using some wooden leftovers ( same material frames from the kit ) is perhaps recommendable. I'll keep you posted. Thanks guys 👍
- 64 replies
Thanks for the info, Patrick. Good news and following your advice : the HBM cobalt set and the Proxxon 110BF 28622 are on their way.... Bad news : along with this purchase, I could not resist the temptation of this amazing bird ....https://www.italeri.com/en/product/3145
- 64 replies
Foring holes for the crowsfeet : A (little ?) setback. 😒 Drilling holes (close to one another) into walnut : I had already an unpleasant feeling about it but proceeded anyway against better judgement..... In a effort to avoid the inevitable I reinforced these items with a 0,5 strip but this did not work. (see last pic ) A possible explanation : increasing considerably the (rpm) speed with an appropriate drilling machine, which I don't have at my disposal As I'm out of options, I'll stick to the approach related to my previuos build, drilling the holes just behind the edges as you may notice on the second pic in attachment. Later on : filling up the homes with some putty and paint.
- 64 replies
Thukydides, Thanks for the sound advice. I think I'll settle for the brass tube. Nearby ( at least to Belgium standards 😉 ) 2 km, there is a Iarge DIY store. I'll take a look. To simulate the weight, the idea is to fix them to a 0.5 mm brass wire and bend some Güterman thread around the brass wire. We'll see how this works....
- 64 replies
A question about the burton pendants. A slice of this small plastic tube is perhaps an option, any thoughts on this ? All feedback is welcome
- 64 replies
The wooldings. You may notice the grey rings on each side of the wooldings. They're made out of paper that was bended twice around the ramin dowel. The Fore and maintops adding extra planking, be it 0,5 mm strips would make these parts way to thick so I tried something different. made a sort of an imitation using a pencil ( code 3 of H ) upon the black painted surface. For the latter an airbrush is recommendable.
- 64 replies
Started with the masts I did not use the provided walnut dowels and went for ramin. I prefer the natural color especially after a varnish coat. A matter of personal taste, I guess. The bowsprit As I want to avoid bulky and clumsy knots, it is recommendable to consult other buildlogs. 5 blocks at the top of the bowsprit jibboom? A bit crowdy....thus I copy/pasted ( more or less ) the BE and Moonbug approach. By luck I've found a spare triple block and fored a 0,8 mm hole where I inserted a piece of brass wire and created 2 loops on each side The bowspritcap was another concern I replaced piece n° 50 with a scratch built item To compensate the angle of the bowsprit, I fored holes that described the same angle.
- 64 replies
Bill Hughes started following Barbossa
Hi Bug, Nice work (as always). It is a pleasure to follow your progress as I like the way you combine evident explanations with pleasant photos. Non native english speakers ( such as I ) are in debt. Keep up the good work and a happy 2025 !
- 419 replies
- Victory Models
- Pegasus
Continuation Bulwark open rail. I went for another approach as I felt insecure about the alignment of the swivel gun supports that contained a slot in which the rail initially belonged. A vertical misalignment would obviously put myself into trouble so I went the opposite way and did not use the original rails ( parts 81) and creatd my own swivel gun supports and rails. The latter received a small slot. Color swivel gun supports : also AV 70.877. The curve at the end of the rail was made out of several layers of thick paper of light card ( if you like ) Another point : I had to bend the rail in a self made jig ( after warming and soaking ). Added some extra pics, hope they tell ore than words. The pumps, the supports adjecent to the gratings (parts 177 ) were a bit to tiny for my taste so I glued a small piece of wood . So what is to come ? The swivel guns = there's a plan A, B and C Plan A : the aftermarket guns in combination with the hammock cranes ( see pic ) Plan B : using the ones provided in HMS Speedy Plan C : use the ones provided in the kit ....haven't figured this out yet... The masts Definitely use ramin dowels as I'm not very enthousiastic painting these items in any yellow color
- 64 replies
Referring to my previuos post, first of all a sincere word of gratitude towards the kind and very encouraging words and immensly interesting builds on this forum ( finished and ongoing ) which are for me a true source of inspiration. Concerning the color scheme for HMS Pegasus, compared with HMS Fly , I always preferred HMS Fly as I came across a few examples of red, black and white (beneath the waterline ) during my research. Let's overlook a few items. Lamp. I'm fond of the gaffsail arrangement without the boom ( e.g. see Blue Ensign's log ). If not, the lamp would clearly obstruct with the boom. The moreover, I intend to place a flagpole. The lamp itself was purchased through the aftermarket ( Caldercraft, If my memory serves me well ) and was part of a kit of 3 lamps ( the biggest embellished the stern of my Diana ) Paint : AV 70.877 Gold Brown. Rudderhead housing For the same reason, thus the flagpole, I had to customize this part a bit. Concerning the rigging part, I sticked to the building instructions but for the sake of visibility, I omitted the 3mm blocks under the ship's wheel. The Breastwork Quite delicate assembling it was ( says Yoda🙂) and the extremities did not fit properly upon the stanchions ( Pegasus builders : part n° 13 is the subject ) so I had to be creative to solve this by adding a small part of wood in the shape of a half moon. Neither did I use the stanchions provided in the kit, instead I went for spare stanchions which were more to my taste. ( to be continued )
- 64 replies
