HIPEXEC
Everything posted by HIPEXEC
  1. I just added extensions to the bowsprit scrolls since the pre-cuts didn't reach the hull.
  2. I'm not good enough the make those razor cuts, so I will do something else to "pretty" them up.
  3. With the help of pics in Rustyj's Syren, I figured out where the missing pieces were. Thanks Rustyj!
  4. I'm still playing detective looking for pre-cut parts that the instructions say are supposed to be there? As you can see from the instruction picture versus my picture...the pieces from the bowsprit across the stem onto the hull are missing? I called Model Expo but now we are playing phone tag and without pre-labeling or numbering on the kit's part, I can't imagine how I will even communicate what I can't find. Oh well, I'll just have to design and fabricate my own parts.
  5. At least I have several previous ships to look at as I figure out how and where everything goes
  6. Trying to move on but have now started being a detective. The kit comes with a few sheets of laser cut parts THAT ARE NOT NUMBERED OR LABELED! The drawings only show various parts but also are not labeled. Obviously some parts are easy to identify having built several models that have similar characteristics, but some I have to play detective to figure out what and where they go. Most kits have detailed numbering or lettering systems to show where parts go. Not Model Expo. Oh well....nobody said it would be easy.
  7. The rudder is finally installed along with the tiller that I made weeks ago.
  8. Seahawk1313's Argus has a beautiful eagle mounted on the stern. I'm going to dig up and eagle and glue it on my transom.
  9. I'm finally starting fitting out the rudder. I always struggle with pintels and gudgeons.
  10. Thanks to Seahawk1313, I now have multiple views of a model of the Argus! Hooray!!
  11. I finally bought hardware to mount the rudder. They are pre-made but I will have to bend and cut them to size. That's easier than trying to make them from scratch. I had to pin and glue the top portion of the rudder since it snapped off while sizing the inserts. I also installed the full size gun port lids on the two forward gun ports as per the instructions. Hinges will be added after a while.
  12. I give up trying to make gudgeons that look good. I will now try to purchase them. The kit only provides a strip of brass for pintels and gudgeons. In the meantime I am still pre-making different components that will be added later. I can't glue too many things that stick out while I wrestle with installing the rudder. After the rudder is installed, the ship will stay basically upright. The pics show the mass production of planks that will make up the gunports whether I make half or full gun port lids, I now have the pre-cut pieces I will need
  13. Look on page 6 (six) on my build site. That's how I started the wales
  14. Thanks, Hal. It does show that some Brigs used full size lids attached at the top and that agrees with the picture I have. Oh well....decisions to make? How's Long Island?
  15. Thanks to Seahawk 1313 I saw a picture of the Constitution followed by a Brig thought to be the Argus at the battle of Tripoli and it clearly shows one piece gunport lids that swing upward.
