Everything posted by Nearshore
Hi Frecap, I am impressed with your research into the accuracy of the Bellona. I agree with Yves that you are taking the construction of Corel’s version of this ship to another level. I am amazed at the details you are achieving at this scale. (1:100) Building the same kit myself I see areas that I could have improved on, but I am past that the point of construction and am not going to go backwards and try and (probably fail) to replicate the detail you are achieving. I agree with you that each modeler has their own vision when constructing their models. For me, I am trying to use the PE parts and cast fittings that were supplied with the kit and use the natural tones of the wood to create my own masterpiece. LOL You are certainly raising the bar with your Bellona build, and I look forward to watching your progress. I am sure I am going to have many questions going forward with by build and I am grateful to have an expert like yourself to rely on when those questions arise. Keep up the amazing job you are doing, and I wish you and your family well for the holiday seasons. Cheers Nearshore
Hi Frecap, Your guwales look fantastic!! I am curious on what technique you used to get the end of the gunwales to curve up. I am going to be building mine in the near future and was hoping you could provide me some insight on how you achieved this. I am assuming that you used two pieces of wood glued together and shaped the final result. I am very impressed with your work and your Bellona is really coming out nice. The paint scheme you have chosen is beautiful.
Hello All, I have a small update on the Bellona progress. I have been working on assembling the deadeyes and chain plates. It has taken me several attempts to fabricate them and come up with something that I feel looks better than what was supplied with the kit. I used a .5mm brass wire for the deadeyes and a .7mm brass wire for the chain plates. I was not happy with my first attempt, the chain plates seemed to look kind of like a paper clip. My second attempt was a little bit better, but I was still not very happy with my results. My third attempt was more pleasing to my eye, so that’s what I went with. For the purest out there, they are not historically accurate, but there are quite a few things on this kit that are not accurate. I have completed the port side channels and will move on to the starboard side applying the knowledge and skills I gained. I don’t think the starboard side should take as long as the port side now that I kind of know what I am doing. LOL I won’t get into too much detail of how I constructed these, I will let the pictures speak for themselves. As always, you comments and guidance are always welcome. Cheers Nearshore
Nice job. Looking pretty good. The veneer will more than likely have to be tapered for it to fit properly. Just take your time and treat each plank as though they were there own project. Keep up the good work.
- 19 replies
- Viking
- Artesania Latina
Welcome to MSW.
Hi Captain Amateur, Yes when i faired the bulkheads I sanded the deck to be flush. I did have to add some material to a couple of bulkheads to allow for a smooth transition of the planking. Are you doing a build log? If i haven't clearly answered your question, maybe you can share a picture of what you are questioning. Thank you for the compliment. Cheers Nearshore
Hi Matt, Welcome to to hobby. looks like you picked a good project for your first build log. I look forward to watching your progress. Cheers Nearshore
- 19 replies
- Viking
- Artesania Latina
Hi Frecap, I like the molding tool you made. It looks like it produces great results. i am curious about one thing. Your roundhouses seem to overhang past the bow deck. I am thinking that this may cause you some issues when the time comes to install the headrails. You may have a plan already for this, but if you don't you may want to look at their positions and move them inboard a bit. Nearshore
Hi Captain Amateur, I stopped using the instructions a couple years ago as I found that they did not give the proper sequence of assembly and they are very vague. If you follow the instructions as they suggest, it will get you into a bind in the long run. The 2 lines that you are referring to are for the 2 babbets and bearding lines that need to be carved. The first one is for the first layer of planking. If you look at my post #53 I show where I carved out the second babbet and bearding line to recieve the second layer of planking. I ran my first layer all the way to the stern post and went back and carved the babbet and bearding line out removing some of the first layer of planking. This is optional as you can stop your first layer planks at the line shown on the drawings. I decided to run the planking all the way to the stern post as I figured this would add strength plus I needed the practice. There are a few build logs on MSW and only one that I am aware of that completed the Bellona at this scale. Halaquen completed this kit and did a very good job describing his build. I use it as a reference quite often. I hope I answered you question and that it helps you on your journey building this amazing ship. Cheers Nearshore
Hi Andy, I think it is optional to plank all the way to the stern. if you do, you will just have to remove some of the material so the second layer will sit flush with the stern post. That is how i did mine when i was at the stage you are at. It was a little more extra work but i think it added strength to the hull at that location.
Hello All, Well, I updated the shipyard again. This post isn’t necessarily related to my build log, but I find that it is appropriate because I find that looking back when I started building the Bellona 3 years ago and how the ship, the shipyard and I have grown, I wanted to share. When I got back into the hobby over 3 years ago, I set up a small workspace in our spare downstairs apartment bedroom. I had a 2’ x 4’ foldable table and a plastic chair that I worked from and a small lighted magnifying glass. I wasn’t sure if I was going to enjoy this hobby and didn’t want to invest too much into my workspace especially since I had chosen a model as complicated to build as the Bellona. Over the course of time, I added a few shelves to clear up some space on my worktable and purchased a small floor lamp to help with the poor lighting. As time progressed my lovely wife purchased me an office chair to replace the lawn chair I had been using for the first year or so of the Bellona build. I must say that the office chair was a big improvement especially since I have a bad back to begin with. I also purchased another lamp that I was able to attach to the table to improve the lighting. I eventually added a larger tabletop to my foldable 2 x 4 table adding an additional 10” of workspace. I used a piece of starboard for this, and it was great until the edge started to sag over time and the game of keeping the round tools from rolling off the table began. Well after 3 years of working on the Bellona and loving every minute of the challenges that it has provided and the satisfaction of learning new skills, I must say that my love for this hobby has given me a sense of reward that I did not anticipate when I first set up my small little workspace. In addition to the shipyard, I have also turned my tool shed into a small makeshift wood shop that I go to for the messy stuff. I think that I have reached the maximum growth as I purchased an electric adjustable height table 60" x 30" to replace the 2 x 4 foldable one. I also added another light, and I must say, my new setup is awesome, and I hope to use it for many years to come. I appreciate you taking the time out to read this post as I think it brings an interesting point of how we grow in our pursuit in this hobby. Cheers Nearshore
Hello All, I have a small update on Bellona. I completed the 20 cannons that will eventually be placed on the upper gun deck. It was quite satisfying to see them all placed on the deck and I am very satisfied with the way they turned out. I will keep them in storage for now until the time comes to permanently install them, which will probably be some time from now. After I completed the cannons, I moved on to the installation of the channels. The plywood channels that came with the kit were replaced using solid walnut that I fabricated sometime ago. The knee braces that came with the kit needed a notch carved in them to fit between the raised molding on the hull. I used a third hand to help with getting the rough positions of the channels and applied two-sided tape to the channels to help with holding the knee braces in place. I made a couple of templates of the knee braces to get their final shape as the kit only came with the exact quantity needed and I didn’t want to mess up any of them and have to make new ones from scratch. I drilled holes in each of the channels and installed pins to attach them to the hull. Pretty straight forward technic. I shaped a groove in the center of a piece of 2mm x 2mm beechwood that will be installed as the channel rail securing the chainplates in place. I highlighted the rail channel molding using a black pigment pen which will match the molding on the head rails. I think having this detail on all the channels is going to add a nice flow to the natural colors I am using. After I completed the channels and knee braces, which I have not permanently installed yet, I started working on the chain plates and deadeyes. Well, I must say that the deadeyes and chain plates that came with the kit are awful. There are two sizes of deadeyes that are called out for in the plans. 5mm and 3mm. The 5mm deadeyes are more like 5.4mm and the 3mm ones are 3.9mm. I replaced them with ones that I purchased from Syren, and I must say not only are they much more authentic looking in comparison, but they are much more accurate in their sizes. There isn’t much room on the channels to begin with, so using the kit supplied parts would probably cause me some spacing problems. Well, I have begun the daunting process of making the chainplates from scratch and will provide and update on them once I have made some progress. That’s all I have for now and as always, your comments and guidance are always welcome. Cheers Nearshore
Welcome to MSW!! Nearshore
Welcome to MSW. Your models are superb and your craftsmanship is amazing. Hope you start a build log here to show us some of your techniques. Cheers Nearshore
Hi Frecap, I really like what you have done with the bulkheads. They look much better than the PE parts that are supplied with the kit. You are doing a very nice job and you are inhancing the look of this kit with the parts you are making from scatch. Looking forward to seeing more of your inovated ideas and technics. Your Bellona is looking great!! Nearshore
Hello All, This is a short video of how I made the cannons for the Bellona. It doesn't show every step, such as making all the eyelets, split rings, preparing the cannons and such, but it does give an idea of just how labor intensive it is to construct the cannons. On an average it takes me about 2 hours to make each cannon. Hope you enjoy. Cheers Nearshore
