NavyShooter
Everything posted by NavyShooter
  1. I arrived in Halifax as a brand new Ordinary Seaman in January of 1993...I suspect the waterfront hadn't really changed that much in the intervening years.
  2. This is neat - one of Bonnie's Aircraft Towing Tractors is still around in the Collection at the Canadian War Museum: aircraft towing tractor | Canadian War Museumaircraft towing tractor | Canadian War Museum
  3. Here's a picture showing what appears to be a Tracker launch cycle from the flight deck not using the catapult, but using the line. You can see the Trackers 'stacked' on the deck astern, with the lead Tracker lined up, wings unfolded, looking ready to launch.
  4. Andy, yes, I think that's exactly what it is. I've seen a couple photos of different launch spec/setups. Option 1 is the catapult launch cycle as seen below - line the Tracker up on the cat, strap her on, and launch. Bear in mind though that every launch saw the strop tossed over the bow. Option 2 - line the Trackers up and launch down the dashed line. I have no feeling for how often they did either of them, but a bit of google-fu shows that there's a lot of cat launch pictures, and while I've seen the through-deck launch pictured, I cannot find one in the first page of google results.
  5. Put a layer of clear gloss on top to seal in the decals. I now have to paint a couple more lines down the deck - the catapult, and the dashed center line (that's not quite on center for some reason?)
  6. Decals applied - those which I'm going to use at least! The elevator decals turned out damn near perfect on the forward elevator - the aft elevator is, for some reason, slightly off-center, but at this point it's an error I'm going to have to accept. The triangle should be basically centered on the elevator - not offset to Port. Alas. I decided to stack a few planes on the deck to appreciate how things look at this point. One thing I decided/determined was that the 'center line' dashed stripe decals are too wide to use. They're about 1/4" wide, and they should be about 1/8" wide. So, I'm going to end up painting that line on instead of using the decals. I spoke with the decal supplier, and we agree that this is probably an artefact of scaling the decals up from 1/400 to 1/144 - and now scaling them up to 1/96 for my model. Before I do the masking, I want the decals to dry and set - and I want a layer of clear coat applied to seal them so that when I mask, I don't accidentally pull any of the decals off. So - Patience is a virtue! I have some painting left to do on the deck anyhow because I'm going to paint on the catapult line.
  7. Yes - I reached out to Above & Below Graphics and had them custom printed for me. He apparently did the decal set for Bonnie in 1/144 for Don Linton's model of Bonnie (that's in the Aviation Museum in Ottawa) and still has the files onhand, so he scaled them to 1/96 for me, and here we are. Ships – Above & Below Scale Graphics Ltd. We won't discuss the cost. It was....spendy....
  8. There are 85 decals to add to the Flight Deck....that seems like a lot....is it though? I got a them all cut out and laid out 'in place' on the flight deck, and started putting a few on tonight. I decided to line up the flight deck distance numbers using a steel rod so that I've got them aligned properly. 220 feet done...440 feet to go! I'm going to have to paint on the catapult line too.
  9. Pulling the masking tape off can either be so very frustrating, or so very satisfying. I am quite satisfied with this outcome. Time to add decals.
  10. I'm a sailor....everything should be Ship's Side Gray....thanks for staying on point and identifying the flaws!
  11. Well, tidying up some minor issues on the flight deck starting with the round-down. Then because I had some overspray into the hangar, I had to tidy that up. Hangar has also had some stiffening members added across the top - I'm pleased with how things look!
  12. My thanks! The rudder is about 200% oversize so that she'll actually perform decently in the pond. In fact, because of the size of the rudder, it actually acts as something of a speed-brake when she's hard over. I'm pleased with the mix of detail and the durability of this build. Interestingly, there's over 120 people world-wide that have downloaded the free 3D model I shared on a couple of sites and I've been sent pictures of at least one other that's being assembled. So, net gain for the RC and model boat communities!
  13. OK, I'm calling this one complete. I'm pleased with how she looks and performs - had her out at the pond on Sunday with the Guild, and all agreed that she looks pretty good. Only thing 'missing' is some signal flags. Here's the pictures - now it's back to my HMCS Bonaventure model!
  14. OK, boot topping is fixed enough....and the Barracudas are done. All that's left on my 'to do' list is to secure the flight deck better to the hull, make some search lights, and add some flags.
  15. I touched up the bleeding last night, and decided to hand-paint the other side of the hull. Looks OK. I guess. I'm going to get some matt clear coat tonight and spray the hull with that to seal it in and maybe the matt will blend the hand-painted touch-ups a bit.
  16. I also realized that I needed to add lines (white/gray) along the centerline and deck edges on the flight deck. This DID go well.
  17. I decided to do the boot topping tonight. This did not go well.
  18. I decided to glue in some basic rigging tonight, then, because I had printed and painted them, I did the guard-rails. My 'To do" list is getting short: 20mm guns paint/install 40mm guns paint/install Barracuda decals Barracuda wings glued on Barracuda Clear coat seal Hull markings (D79 + waterline mark + depth lines) Flags? Might want to add some signal flags too. And possibly LED lights - maybe - if I really want to do that work for a model that I'm never going to sail at night. I had to replace the rubber sleeve ball joint I was using with a proper dog-bone. Pretty much finished.
  19. Ballast adjusted a bit today so the bow will ride a bit higher in the pond when I have her out on Sunday. The Martlets are done and now have 2 coats of clear gloss sealing them. The new wings for the Barracudas are half-painted - almost ready for decals. Details have started to get added to the ship now as well - the 5" guns have been installed along with some life-rafts and the ship's boats. More details to go, but she's nearly done. My son has a football game tomorrow that I'm off to watch then tomorrow evening I'll be puttering about with this to get her ready for a fun float with the Guild on Sunday morning.
  20. Overall weight is probably 10 pounds or so? As for the air det, those are mostly for display. The decals are on and will end up with a couple layers of overall clear coat spray applied to seal them in. The only ways that the aircraft would be certain to stay on the flight deck 'at sea' on the model would be to glue them in place, or to inset magnets into the landing gear and underneath the flight deck to hold them. Intent is not to sail with the 'actual' air det - I'm going to end up making some 'sailing' airplanes that I don't bother to decal up - they'll look good from afar though. When the ship is on display at a show or whatever I'll swap on the 'good' airplanes. The rudder being considerably overscale makes her perform quite well in turns, but, if I do a 'hard over' she'll really slow down as it ends up acting as a brake as well.
  21. David, Agreed, the model is too low in the water - that's an easy ballast fix which I'll work on the next time I get her to the pond. Also, while you may have sent me plans, I was mostly focused on having this model be a bit better than the Glynn Guest USS Bodega Bay model - which is at best a stand-off scale ship. An observation - you have a tendency to almost always point out the flaws....I don't think you've ever posted a positive "hey, that looks good" type post. Are you naturally a negative personality, or is this your internet persona? My HMCS Bonaventure model is, truly, huge, and is going to be a challenge to get to/from the pond let alone launching her. My desire was to have a more portable RCN-ish Aircraft Carrier model that's more detailed than the Glynn Guest model. In that I have succeeded. I'm at the point of doing minor ballast adjustments, adding the detail bits, and finishing the Air Det up. (Got 3 of the Martlets decalled up last night and a start on the rest.) This was never going to be a 100% museum quality build. That said. One of the people who's downloaded the free file set that I released is building his up as a display model for the museum he volunteers at, so....I guess it can be whatever you make it into? NS
  22. Ken....your magic math has impressed me....I'll upload a video of her sailing in a bit once get it put together. The ESC is a hobbywing 1080 and the motor is a 400 size I think. I realized that it's very easy to overpower models, so I've limited the throttle to 60% - if I remove the limit, she'll go a bunch faster, but yes, the water over the bow would be a big concern. I'll probably drop some of the ballast to get the bow up a bit.
  23. I did a bit of google-fu and discovered that I need to re-design and re-print the Barracuda wings for the ones in the folded position. That's in progress...
