Everything posted by RossR
I used the contact cement only because that is what Occre has in the instructions. I had good results using it on my first model, so I stuck with it. I appreciate the info on the plank layout. I will use that in the future.
Occre Diana (Spanish frigate 1792), low quarter gallery windows?
RossR replied to Esap's topic in Wood ship model kits
As a newcomer to ship modeling the terminology can be a little intimidating. I appreciate you sharing this information. One of my goals on my build of the Frigate Diana is to take the time to learn more about the correct terminology as I go. Especially on the sails and rigging. Would love to have you follow my build log and add some help as I need it. Thanks. https://modelshipworld.com/topic/33530-frigate-diana-by-rossr-occre-185/ -
I started with HMS Beagle from Occre. Good instructions and about 130 short youtube videos to demonstrate various techniques. I had no modeling experience and am pretty happy with the result. Good luck
I have completed lining the deck pieces. The instructions called for gluing a single strip the entire length of the base and then using a pencil to create the appearance of caulking along the length of the boards and across the boards. I didn't care for the look of this technique and opted to cut the boards into shorter pieces and I used a pencil to darken the edges of the boards. I think this creates a more subtle look for the caulking. I used contact cement to attach the lime wood pieces to the plywood bases. Prior to my first model I had never used contact cement. Occre has a series of instruction videos on YouTube for the HMS Beagle and I used the method they showed in the video. I wrapped two pieces of painter's tape around a piece cardboard with the sticky side out. Then place the deck boards on the tape taking care to butt them up against each other tightly. Contact glue is applied to both the deck boards and the plywood base. After about 10 minutes the glue feels only slightly tacky to the touch then the deck boards can be attached to the base. Care must be taken not to apply pressure to the deck board until it is in the exact right spot. Then some pressure is applied and the pieces stick together. After a few rows I use the round handle of a pin pusher to apply more pressure on the boards to ensure they are secured to the bases. I stained the decks using Minnwax Golden Oak stain and then applied two coats of shellac. I used a fine steel wool after each coat of shellac. I use shellac made from flakes and denatured alcohol using a 2 lb cut. I received the advice to use shellac on this website after posting about problems I had with using polyurethane. I am thrilled with the results I am getting with the shellac. It's great to have a place to ask questions and get feedback. I have the decks installed and will post about that process soon.
I was referring to these three parts. They make up what the instructions call the gallery and the instructions call the top and bottom pieces in the photo the gallery bases and the middle piece is called the window. Sorry if I wasn't clearer in my earlier post. -
I have recently started building this kit. The gallery windows are made up of two separate castings with a photo etched brass piece for the window in the middle. I may try to fabricate a wooden filler piece between the lower casting and the photo etched brass to raise the window. It looks like there will be space between the upper casting and the railing for this to work. -
Thanks for the info. The planks on this model 3 mm wide. I agree that 5 mm seems too wide, well over a foot at this scale.
As I start to plan the planking of the decks, I am trying to decide if I want to include treenails on my deck. The plans from Occre instruct the builder to simply use pencil marks to represent the treenails. I do not care for the look of that am considering other options. The plans also call for a single strip of planking to run the length of the deck with a pencil line to indicate were one plank board ends and another begins. I am planning on not using the pencil marks for this either and will cut the plank pcs into smaller strips so there will be an actual line between the plank pieces. At a scale of 1:85 I am a little concerned that anything I add will be too big. I know there will be other things that are out of scale such as the belay pins and the thickness of the linen sails provided with the kit, but I worry that due to the large quantity of treenails on the deck they would be too much of a focal point if out of scale. Does anyone know what diameter the treenails would have been on a ship in this era. If they were an inch in diameter that would mean they should be about .3 millimeters on my model. I can get drill bits close to that size, but what material would I use to fill the holes. Would it look good to fill them with wood filler? Has anyone tried this? I am not opposed to skipping the treenails on the deck if I don't think I can add any that look good. I would love to hear other's thoughts on this and what you have done on models of a similar scale. Thanks
I have the frame assembled. I used some Lego blocks clamped on to the false keel to keep each frame piece square while the glue dried. I used regular wood glue to glue the frame pieces together. I find that Occre does a really good job with their laser cutting. I didn't have any issues with pieces fitting together properly. The hole for the bowsprit on the front frame piece is not contoured to properly accept the bowsprit. The instructions say to use a 10mm drill after the hull is planked to drill out the hole properly. I found this difficult on my HMS Beagle, because it was difficult to know if you were drilling into the slot on the false keel without making it bigger. I chose to simply use a file to create the proper contour on the frame piece so the bowsprit will fit properly. I will need to also file the hull planks after they are installed. Next step is to plank and install the deck pieces. I enjoy this step. It is the first step that completes a part of the ship that will be seen on the completed model, so if it feels like progress as opposed to just prep work assembling the frame that won't be seen. Hopefully I have something to post soon on my progress with the deck.
I have recently completed my first model ship, HMS Beagle by Occre. I am now starting my second, Frigate Diana, also from Occre. I have decided to document this build with a build log. I am hoping to get feedback and advice from more experienced modelers and to hopefully be a source of information to other beginners. Some of the members that post on this site are meticulous about being as historically accurate as possible. While I respect the time and effort that they put into researching and building their models, I am less concerned with this aspect of the hobby. For me it is about the relaxation and satisfaction I get out of building the model and the aesthetic of the final result. While I am pleased with the overall result of my first model, I am looking forward to improving on my second build. One area that I am focused on is the first layer of the planking. I am planning on installing the first layer of the planking using some of the techniques that I have read about on this web site. This may be overkill since I am still planning on adding the second layer of planking, but I am viewing it as practice for someday building a model that only has a single layer of planking. I am also hoping to be more precise on items like the trim on the deck railings and the masts and other deck features. My rigging got better as I progressed on my first model, and I hope to make all of the rigging better on this model. I am also hoping to learn more about the proper terminology for the various parts of the ship, especially the rigging. Thank you for taking the time to read this build log and please add comments and questions about my work. The parts were in great shape except for one of the ship's wheels had two broken spokes. Occre is really good about replacing broken parts and makes the process pretty easy. The laser cut parts are all in good condition and nothing is warped. Occre provides over 100 pages of instructions and plans including detailed rigging plans. I hope the have be basic frame assembled in a few days and will post on my progress.
shaping masts, yards and bowsprits
RossR replied to Charlie pal's topic in Masting, rigging and sails
I am finishing my first model, and had really good luck using a small plane to remove the bulk of the material. Then I wrap a small strip of rubber around one end of the piece that I insert into a drill. The rubber keeps the drill chuck from damaging the piece. I use sandpaper to remove the rest of the material and make the piece round and then finer grit sandpaper to make it smoother. -
Thanks for the information. Appreciate your help and those boats look incredible
- 12 replies
- Frigate Diana
- occre
I am about to start building the Frigate Diana from Occre. The boats that were supplied are metal die cast boats. My first model was the HMS Beagle from Occre that had 4 small boats that were built as a plank on frame construction. I am considering trying to scratch build the boats using a "layer cake" method like Model Shipways Constituion's boats. Curious if anyone has tried this or has any advice.
- 12 replies
- Frigate Diana
- occre
Your model looks very good for a first wooden model. Very clean work. I am building my first wooden model right now, and I am happy with the results, but my work is not as precise as yours. Very nice model.
- 112 replies
- Bluejacket Shipcrafters
- Constitution
I started with HMS Beagle by Occre. Occre has a series of about 130 short youtube videos on how to build the kit. Currently I am working on the rigging. I have enjoyed building the model. I made a few mistakes along the way, but I learn a lot and I will hopefully be finishing the Beagle and starting my next model in January. Best advice I can give is watch the videos (probably useful for any first tall ship build even if you aren't building the Beagle) and really go over the instructions. As I got further along in the build I started watching the videos with the instructions for that stage of the build. This was especially helpful on the rigging. Also, for a first build, remember you are supposed to enjoy building it. It won't be a museum quality model so don't stress over any small mistakes. I have a couple of lines that go to the wrong pin to be tied off, and one big mistake on the main mast that I couldn't correct. Oh well. I will learn from it and do better next time, but my model still looks good.
Thanks. I appreciate the insight and I like the idea of going through the hole. It has occurred to me as I am struggling to wrap the line around the belay pin in a very tight space that nobody will see it after the hank is attached. My pins are already glued in, so I will suffer through on this model but use this tip on my next one.
I am working on the rigging of my HMS Beagle from Occre. It is my first model ship. The rigging instructions show some belay pins having two different lines attached to them. Is this correct? I am a little worried about whether there is enough pin on the bottom of the pin rail for the extra material.
The Diana I am building is the Spanish Frigate Diana that was built in 1792 not the British ship. Thanks for the tip though. I would love to find more information about the ship I am building if anyone has any suggestions.
I am currently finishing my first model, HMS Beagle from Occre. I had some problems with the polyurethane that I used to finish it. I opened a new can of Minwax quick dying polyurethane in March and had really good results. By summer the poly from the same can wouldn't dry. I expected slower drying due to higher humidity, but no matter how long I waited is stayed tacky. I would appreciate any insights into why this happened. Also, I will be starting my next model in a couple months and I am wondering if I should be using a lacquer or shellac instead. I will be brushing it on, not spraying and would love to hear any thoughts on whether I should stick with poly or switch to something else. Thanks
I am currently building my first model, HMS Beagle from Occre. Going pretty well. I have made a few mistakes including one big one on the main mast, but have learned a lot. I started about 10 months ago and am currently about half way through the rigging. I hope to be done after Christmas. I will be starting the Frigate Diana next and I am planning on creating a build log as I go.
