botra288
  1. Congratulations 🏆 you have done so exceptional work which undoubtedly has earned this prize I would love to follow your new project because I also have the same monograph, I will learn a lot from you
  2. Siggi, your work on the model is very impressive , the two "fill-horn" carvings are Wonderfull work, well done🫡
  3. beautiful model, a masterpiece 👌🏆
  4. I would like to know where you buy the adjustable table that connects between the clamps and the work surface of the mf70, thus allowing milling at a variety of angles Thank you very much for your help
  5. Karen, you do construction and carving work at an exceptional level, I would be happy if you could explain in detail the working methods in creating the ship parts as well as the amazing carving you create, so that we can learn from you and there is a lot to learn😀
  6. Your boat building method looks great and I learned a lot from it, well done
  7. Very impressive and beautiful work, well done👌
  8. I admire the in-depth research and the courage to take on such a fascinating project, well done!!! I will continue to follow and learn with curiosity
  9. Dick, Your project is very interesting and a significant challenge! The research you are doing with the help of friends is simply fascinating! I will continue to follow with great curiosity and learn from you
  10. Louie Your project is very interesting and a significant challenge, I will continue to follow with great curiosity and learn from you 😀
