Everything posted by ddp
you must be glad that you also did not glue them solid as then that would be an extremely serious problem to try to fix.
- 235 replies
if your model had the 2 rudders & 4 props like the real ship had, then your model might have handled better then it currently does.
- 235 replies
should have put the lead shot into bags so can be removable til all work is done so you would know what lead weight is needed to get the model down to the correct waterline.
- 235 replies
is that hull warped from the swimming pool deck to below the port holes to the right of the clear tape holding the decks to the hull?
- 12 replies
- Rex
- Old Model Kits
the layout & shape of the aft superstructure appears to be wrong according to these links. Starboard view off Norfolk Navy Yard, 3 June 1942. http://www.navsource.net/archives/01/015560.jpg November, 1944. http://navsource.net/archives/01/055/015515g.jpg in 1945. Line drawing by A.L. Raven http://www.navsource.net/archives/01/015596.jpg http://www.navsource.net/archives/01/55a.htm
Ian, do both props spin in the same direction or does 1 spin right & the other spins left?
- 235 replies
would not the motor go in reverse if you reverse the polarity with the battery?
- 235 replies
the Princess Royal outboard/inboard drawing i have on my computer as fitted does not show anything in the spotting top.
- 235 replies
try this as they had to replace server & site domain. https://www.navsource.net/archives/02/06.htm
- 154 replies
- Enterprise
- Trumpeter
here is some more. if you want larger versions of the drawings i had posted as site might limit posted file size then i need your email address so i can send them to you.
- 97 replies
- Curtis Wilbur
- I Love Kit
Kevin, is it the motor getting hot, the speed control or both?
- 235 replies
are all the boats the same or different & same goes for the launches? do you have plans/drawings for the boats & launches?
- 235 replies
what time period are you doing the model as Trumpeter's painting instructions leave a lot to wonder about?
redo the float test after you got it all built & rc stuff installed to make final ballast adjustments.
- 235 replies
