Everything posted by Loracs
About Inlays. This is what I'm thinking (see picture). The "feather pattern" (top one), on the side, along with a number of walnut strips. Nothing really fancy, a simple outlook. The two below, likely for deck wall decoration, again with walnut strips for accent. The last two, unlikely. The one with the vertical pattern may clash due to the color. The moon-cycle inlay is nice (loving it)... but maybe it's too wide. Let me know what you think. Would truly appreciate all your comments.
@Baker, you are more than welcome... BUT it is going away fast 😉 @AllanYed, a thousand thanks for the reference and comments. I will definitively look it up. The printed sections from the kit are in fact nice. I just like the look and feel of wood. Hiding it behind paint/decal just makes me cringe. It may end NOT historically accurate to use alternative, but I may just prefer the look. What if the "Revenge" was sold, late in its life, to a rich merchant that revamp it a little (hey!). Still few weeks to think it out over.
This ship has curves, which is nice aesthetically but harder for planking. Here's my process. 1. I measured the length at each bulkhead, then defined the optimal plank width at each position (Fig 1). 2. I used a mini planer to trim the planks. I did a batch of 4 (x2) at a time (Fig 2). The edge remains flat with a nice tapering. Don't forget to mark the tapered edge. 3. Using a curly iron, I give the plank its rough shape, primarily at the bow. THEN, 4. I slightly wet the plank using a rag (5 sec no more), then I attached it without glue (Fig 3). 5. Using a hair dryer, I then dry on the ship. Repeat 2x (wetting then dry), leave alone 15 min, then dry again (until completely dry). Figure 4 shows the upper plank in place WITHOUT any glue... a nice fit. It was then glued in place. Rinse and repeat.....
In planning for the first planking, I built a number of stands to invert the ship and keep the bulkhead off the ground. Having a worktable with rails will be handy here. Note: found a use for the many masks left over from the pandemic. The worktable is set on 2 feet circular "Lazy Susan", which allow me to rotate the table and work on either side without having to handle the ship.
Wet the side walls lightly and leave it dry on the ship for a few days, then finish the curvature with a steam iron. The front parts required more aggressive bending using a small jig. The frames for the gun-ports were glued off-ship, but require close fitting back and forth to the ship... a very close fit.
My god.... such a nice model. Are you serious about potentially releasing it as POF kit. If yes, I'm 100% in. On the same line of the semi-scratch build Winchelsea but POF (than would be so nice)? A rigged version would great... I'm a fan of rigged model. Still have no room for a bunch of power tools even mini ones (the reason I'm looking for semi-scratch build). I was looking around for such a kit... but almost all are Chinese manufacturer. CAF model seen ok... but would 300% prefer a model from Chuck and Co. Let us know if you have a timeline. cheers, --loracs
Second deck and cross beams... slow (due to bad back) but steady progress. Note for the sake of accuracy: If you look at the deck with the whipstaff assembly, I forgot to leave spaces (un-planked space) between bulkhead 12 and 13. Therefore, parts 12b and 13b will be 1mm higher (the thickness of the planks). Luckily, dry fit with the third and final deck seen ok.... Since everything is currently glued, reversing the mistake would have been quite some work. For once, I appreciate the slight tolerance that the kit offers. On the plus side: not having to deal with those spaces at bulkhead 12 and 13 allowed me to perfectly align the deck planks within and across both decks. Really like the model so far, the manual is great... remind myself to follow the steps.
Deck planking: more of the same. The front deck was slightly shaped (round down) before fitting by first damping the back, placing on wood spacers on the edge (5mm high) and placing weight in the middle. Worked well. Rounded holes/squares using files and tested them before gluing. The rest was easy.
Very nice, indeed. I like the color you choose for the hull and shield. Look Classy. One comment, although a very minuet one, when planking deck, you could use an interval of 3, 4 or 5 to create a cool and realistic pattern. However, it may not be relevant for this type of deck (with the vertical strips covering the joins. Just saying, if you're planning a larger model.
Thank you for the thumbs up... this is a great hobby and a wonderful community. --Loracs
- 18 replies
- Amati
- Chinese Pirate Junk
Allan (my God I replied using your own post lol), You are right... I even look for public schema of other ships... unfortunately, little found there. Note: I find it interesting. Something I have not even though about it until you raised the question. I just assumed the kit designer had it right (they may have, but maybe not). --Loracs
After planking the deck, I treated the wood with "sanding sealer" and applied three coats of water-based matte polyurethane. The brass grates were a little trickier. First, they were oxidized with "Brass Black" and the finish seal with matte poly. The oxidation is very thin and at the surface, they chip very easily until sealed.
The first step was to work with the bulkheads 1-3 for better contact in future hull planking. Was easier to do off-ship. I went ahead and planked the first deck as per documentation. Quite straightforward when working off ship. The deck comes in two pieces and I started in the middle using 120mm strip pieces. The middle strips are glued only to the first half... as many suggest here.
Greetings all, Starting to build Revenge from Amati. Several reviews are available, so I won't describe the kit content but rather go right away to my build log. Overall, great kit, excellent documentation and well printed plans. I'm not a fan of the printed decorations. Not sure now how to handle it later. Either paint myself or, most likely, use commercial inlays. I'm not there yet so I will see later. NOTE: don't hesitate to comment. Will take suggestions and critics alike. That's the only way to learn. The dry fit was excellent. Frames 1-4 were a little loose, so I use the inserts 17, 18, 19 as spacer as well as the decks to glue everything together.
Louie... thanks a lot for the comments. I really appreciate it. I will look at the tutorial on planking and read more on rigging. However, you make excellent points... truly worth following up on for my next build. thanks --Loracs
- 18 replies
- Amati
I hope you enjoy it... I had a lot of fun building it. My next one is in the house already, the HMS Revenge from Amati. Don't hesitate to comment...
- 18 replies
- Amati
