Everything posted by JacquesCousteau
The build is looking great! I'd be very interested in reading a full review of the monograph, it looks like it makes a very nice model but a few people have mentioned issues with it. Given that many (though not all) of its issues seem to stem from the rigging/mast/yard being more appropriate for a larger vessel, I'd be curious to know if the Ancre monographs on the Felucca N.S. del Rosario or the Leudo are any better.
- 61 replies
- ancre
- Santa Caterina
Brief update tonight. I've begun planning out the foredeck and the rancho (the palapa-like structure aft that gives the Canoa de Rancho its name). I decided to use card to figure out the correct sizes. The rancho needs to be tall enough for an adult to stand up under it in the center, and the scale figure I drew was very helpful for this. Note that the card stock will provide a rough template for the frames, with the thatching over the top. As for the foredeck, there seems to have been a wide variety of lengths on the real vessels, so I'm deciding between a shorter one and a longer one. The longer one looks best, I think, balancing the rancho, and the extended platform would probably be useful for fishing, although it does cover up quite a bit of the bow floor planking which I quite liked the look of. (As an aside: from what I see on other build logs, what I've been calling flooring or floor planking may actually be called the ceiling? I'm not really sure what the correct terminology is.) Shorter foredeck: And longer foredeck: Plank widths shown on the card templates are approximations as I was testing some different widths. As much as I'm enjoying this build, it's likely that I'll be making very little progress on it until January. Things have gotten pretty busy with work, and in mid-December I'll be traveling again, this time leaving Mexico for the time being. So, I'll have to pack up the Canoa de Rancho to continue the build from the US. The hull itself is pretty sturdy right now and could be easily packed, but I'm concerned that the rancho would be pretty fragile if attached. While I may do the foredeck before traveling, my main building goal right now is to finish the Cargo Canoa, which I'm planning on leaving in Mexico for now, and if I still have time, to do a few small, simple, and greatly simplified builds designed to be used as Christmas ornaments that I'd like to give as presents. All of which is to say, I'll probably be posting some more on the Cargo Canoa, but I'm not going to work on the Canoa de Rancho for a bit.
- 286 replies
Welcome, and nice job on the dory and pram!
I decided to add the keelson in order to help strengthen the hull. This required a bit of internal fairing down the center, although more serious fairing on the internal side of the frames will have to wait until the supports come off. I continued fairing the exterior. Ultimately, I decided that leaving the iffy starboard side unplanked would be unsatisfactory, as the fairing issues would still be visible. Instead, after a lot of fairing, I got it as close as I can get it, and I decided to plank it. There will still be some small gaps at the bottom of some of the middle planks, due to the issues I mentioned above, but they are quite small and will be largely covered by the flooring. After cutting the sheer planks to the right width, I lightly moistened them and bobby-pinned them in place to dry. I then glued them and the plank below in place. The bottom of this plank will have a rub rail, and below that, I'll have to do some light spiling on the planks. While those were drying, I also added the garboard planks. The rabbet didn't really work very well for these, both because it was a little too small and because of the issues I noted earlier with getting the frames to a consistent depth on the keel. But, the rabbet will be covered up, so my error shouldn't show when I'm finished. Finally, due again to my problems with attaching the frames to the keel, the tops of the frames didn't line up well. However, as can be seen in the plans' cross-section, the tops of the frames will be fully covered by the gunwale and cap rail. So, I simply made sure that the foremost and aftmost frames were at the correct heights, and made the sheer planks line up with those. The uneven frame tops will be entirely covered in the finished build. Although I've made a lot of problems for myself with this build, it's a lot of fun, and I'm learning a lot that will be useful for future builds. It's also made me appreciate even more the incredible POF builds that others have done. As I mentioned, this will be a very portable model:
Thanks! It's a very fun little build, and given that the whole thing fits in the palm of my hand with room to spare, I shouldn't have any problem with transporting it and finding a space for it on a shelf. I'm also learning a lot about POF construction, especially what not to do when attaching frames! In other news, I've decided that I'll build the cross-section as the plans have it, as a masted, decked, windlass-equipped clamming boat, rather than as the undecked rowboat the Juana y José actually was. If I eventually do a full hull build, which I would like to do, I'll be doing it as it as the actual vessel, but for the cross-section, the extra details will add visual interest and make for a more interesting build. Also, I realized that I haven't included yet any of the photos of the actual Juana y José, so here are some screenshots from the defunct Modelismo Naval site (source: https://web.archive.org/web/20160902024136/http://www.modelismonaval.com/magazine/almejera/juanayjose.html). By the time the photos were taken in the early 2000s, the boat had clearly seen better days. I'm thinking I may come up with my own paint scheme, I can't say I'm crazy about the blue interior....
Not to overload you with recommendations, but this site may also have something: https://indigenousboats.blogspot.com/?m=1
- 174 replies
- Waa Kaulua
- bottle
Sanding down the rails on the Canoa de Rancho was a slow process. The fore port rail was a bit too oversized, as can be seen below (at which point I had only sanded the starboard rails): I also don't think I quite got the rail shape right. It was very hard to tell while just dry-fitting, especially because the fore rails had to be held in place due to the curve, but there seems to be a slight pinch where the fore and aft rails meet amidships. If I were redoing this, or to make rails in the future, I would probably make card templates at the start. Further sanding: After getting the rails to an acceptable thickness, I repainted the edge and other locations that needed touching up. After a few alternating layers of paint and light sanding, I finished the rail with a light, even black wash. Next step will be the foredeck. But, this seems like a good break point. For those who celebrate, have a Happy Thanksgiving!
- 286 replies
Great job, that looks fantastic!
- 217 replies
- medway longboat
- Syren Ship Model Company
After the rails were painted, I glued them to the hull of the Canoa de Rancho. As can be seen below, this entailed scraping off the paint at the points of contact in order to get a better joint. I glued the aft rails in place first, as these need to be lined up with the most care--I have more wiggle roon toward the bow, where the foredeck will cover things if the rail isn't perfectly aligned with the wale. The starboard aft rail went on very easily, but the port rail was harder to hold down against the wale. Given the lack of clamping points around the middle, and that a rubber band would have pushed the rail inward and thrown off alignment, I had to just hold the rail in place by hand for a while. The fore rails are trickier, as they follow a curve upward, but with all the crossbeams there are many more clamping locations. I left the fore rails slightly wide, as I'll be sanding the exterior of the edge into a smooth line once the glue has fully dried. There will then have to be a bit of paint touch-up, and I'll be able to move on to the foredeck. As for the Cargo Canoa, the watermelons' paint dried and I was able to remove them from the toothpicks. The resulting cut does a pretty good job of representing the stem. I was inspired by the very common market crates (guacales) used for fruit and vegetables to make my own, although I made it rather larger than the standard crate so it could carry more than a single one of these fairly large watermelons. Guacales are typically made of very rough wood, so I used some slightly irregular scraps leftover from when I was thinning down the frames, and applied a black wash. It adds a nice touch, a splash of color, to the canoa. That said, I couldn't help but think that the squared-off guacal was a poor fit for the spherical watermelons (a note: maybe I should have sanded some into more of an oval shape for variety, but the beads are made of a very hard wood and I gave up pretty quickly). I went looking for photos of how they transported watermelons, and found the photo below from the early 1900s (correct time period, although it's from Mexico City and not Chapala) of a watermelon vendor. As can be seen, he's carrying his load in a net bag. Source: https://mediateca.inah.gob.mx/islandora_74/islandora/object/fotografia%3A434539 I may have to try making a similar net bag, although I would want to get a different sized net fabric than I'm planning on using for the fishing nets.
- 286 replies
Looks like a very cool project, I'm looking forward to following along!
- 174 replies
- Waa Kaulua
- bottle
Although the kit doesn't include full plans, all the parts are already cut to size, and the plans include numerous drawings as well as measuring strips to ensure proper placement of the thwarts etc. While full plans would certainly be nice, the kit is intended for beginners who are building following the instructions rather than from plans, and the instructions are certainly very detailed. Given the large number of successful build logs, it seems like the kit still builds into a nice model without plans.
I finished the lap joints on the Canoa de Rancho's rails. I'm much happier with how they turned out, especially around the stern, than I was with the Cargo Canoa. It pays to figure these things out off the whole model. As can be seen, the stained rails kinda blend into the rest of the wood, so I decided to paint them. While working on that, I've made some progress on the Cargo Canoa. First, I shortened the mast and shaped the top of it--the backstays will tie off around the ledge. I then used drill bits, a file, and a dot of pencil lead to simulate a sheave at the mast top. Finally, I decided that it was about time to make a cargo for the Cargo Canoa. Eduardo Gibbon mentions that the canoa he rode on previously unloaded a shipment of watermelons, so I decided to make a few. First, I glued a toothpick into the hole in some wooden beads, both to help fill the hole and to provide a handle while painting. Then I filled in the remaining gaps with sawdust and glue, and sanded once it was dry. I painted a light green base coat. As can be seen, I didn't fully mix my yellow and dark green paint, so as to be able to pick and blend different hues. I then painted some darker lines, experimenting with line thickness and waviness. Not all of them turned out great, but my plan is to put them in a crate or two, which can partly cover the worst of them. (Plus, it's not like every watermelon is exactly alike...) Finally, I should note that these are, at scale, definitely on the large side, with a diameter of over a foot. The next size of bead down that I could find would have been a good bit smaller. But I think they'll still work--maybe it was a good year at the farm that produced them. Now I just need a crate or two for them.
- 286 replies
I didn't include photos above because I needed both hands to hold the planks to the frames--for a small cross-section, the hull curves a decent amount. But then I realized that I have bobby pins that would work perfectly for clamping! So here's the even framing on the port side (still needs a bit of fairing, but nearly there): And here's the much worse starboard side, with some serious gaps readily apparent: I'll still be fairing both sides some more, but by now I've decided to leave the starboard side unplanked. Except for the uppermost wale and cap rail, which will provide a bit of stability.
Fairing the hull has been difficult. Right off the bat, two of the crossbeams came loose and needed to be reglued. More seriously, undoubtedly due to carelessness on my part, the frames don't line up quite like they should. I think I didn't get a perfectly consistent slot carved in the bottom of each frame, so they don't all sit at perfectly equal heights. The difference is tiny, but on a model this small, it matters. Moreover, while the starboard side is pretty fair and should take the planking without a problem, a frame or two on the port side are a bit off. Even with aggressive fairing, they are still far from being in a place where they would work for planking. And given the small size of the parts, I can't really sand any further without making some frames notably thinner than others. Shimming could work, but would be very visible on a small cross-section like this. It's worth noting that the irregularities on the port side are not especially visible to the naked eye if the hull isn't planked. So, I'm thinking of leaving the port side unplanked as a skeletal framework, and only fully constructing the starboard side. Overall, I think this is a lesson in the need for greater precision when making a pof model. It also is further evidence to me that, if I do a full build of this vessel or similar ones in the future, I should definitely go with a larger scale--just having slightly thicker frames would give me more room for fairing, for example.
Thanks, Paul, that's a great idea for the hinge! Thanks! That's also very interesting about the mango wood. It's been nice enough to work with that it makes me wish I had access to milling equipment and a thickness sander. As for balancing precision and real-life roughness, it's definitely a tricky balancing act, and I've had to learn quite a few things along the way--I'm glad I can use the Cargo Canoa as a test bed, although it does mean it isn't turning out quite as nice as I'd like. For instance, I'm reconsidering how I'll do the rudder hinges on the Canoa de Rancho, as the Cargo Canoa's hinges are still too large/out of scale. I may be forced to learn how to do metal work, after all...
- 286 replies
The Canoa de Rancho's rails have been a bit slow to make. They need to follow the curve of the hull very precisely, so as to extend outward from the rails without extending into the hull at all. Somewhere I read that you should approach each piece when you're planking a hull like its own separate model, so I'm approaching the rails with that mindset. Following the example of a lot of photos, I decided to make each side's rail out of two parts, with lap joints connecting them and connecting the aft rail. To mark out the interior line of the rails, I placed a bit of tape, drew along the line, and then transferred it to the basswood sheet to cut out. This was followed by a lot of shaping and sanding to get a precise fit. I also decided I like the look of slightly thinner rails (starboard side in the photo below, at which point there was still a lot of shaping to go), although I'll have to sand a bit off some of the supports that ended up a bit long. I soaked and heated the fore rails, and clamped them in place to follow the hull's upward curve at the bow. Cutting out the lap joints is tricky work, given all the curves. I ultimately decided to do the aft rails first, as they need to be the most precisely lined up with the wales--further forward, the foredeck will cover it up if I'm slightly less precise. As can be seen, I stained the rails like I did the crossbeams and other parts. However, I'm now having some doubts. As can be seen below, the wood grain runs at different angles at the midship joint, which is accentuated by using stain. I'm now wondering if I should just paint the rails brown, as seen with the small test piece, below. It would also add a bit more contrast with the other stained parts on the top of the hull. Let me know if you have any thoughts!
- 286 replies
Welcome! If you post a build log, I'll definitely follow it. The bateau de lanveoc looks like a fascinating build, and I don't think there are any logs for it.
No worries! I don't have access to much modeling wood here, so while visiting my in-laws, I stripped the bark from some dead wood that had fallen from their mango tree. I had read good things about fruit woods. Given that I don't really have many tools, my ability to use the wood I collected is very limited, but I can at least make a mast out of it.
- 286 replies
