BrochBoating
Everything posted by BrochBoating
  1. Wasn’t sure how far I’d get today but has gone well. Except for two of my new drill bits breaking. Shame as the smaller ones have been really good. Both on the topmast so just bad karma All gone together nicely and a couple of coats of black. I’ll varnish once dry and that should do for now.
  2. Turning to the masts etc. What's a good method to square off the top section of the main mast? Does something as simple as a file work?
  3. Looks very nice. Much 'sleeker' hull than before. What length hull is this roughly? Around 700mm? Thanks
  4. Thats what I'd think of as an English Wheel. As you say often as an automotive tool for panel shaping. A friend did his apprenticeship at Aston Martin and was a wizard with one of these. I tried. I was not. If you are thinking of one to shape sheets for a model I'd imagine a former of the hull in question and an assortment of hammers would work better with less practice.
  5. My problem was how to attach them as the hooks I have for the eyelets are too small for that rope.
  6. This blocks were far too big and ugly so I’ve removed them and tried to approximate rigging in the hope that they’ll look better not seeing them there than being so big they draw attention to them being wrong.
  7. Huge thanks to @chris watton for the eyelets, currently primed and painted. Used the last of mine to start getting them attached to the gun ports. I try and use CA gel by putting an amount on a piece of paper that I can dip the piece into before holding in place. Usually makes for more accurate placement with less excess. Then start attempting to make the guns looked rigged. They aren't accurate but I wanted the practice. The blocks are far too big but are what I had to hand, next time I'll order extra nice blocks so this works out better. One of each in place. Sure the rest will gradually improve.
  8. Only invented this morning lol. To be honest was despairing how to do it but happy with the result for first go
  9. As this is my first military vessel can anyone advise if any of these configurations are vaguely accurate for Trial? If so then I can try and work out which to try and approximate once I get some more eyelets.
  10. Snap. I try and never use power tools in woodwork. Largest thing I managed without power was my last full size bench with a six inch thick top. That was slow to trim!
  11. Just a little progress. Not absolutely perfect but happy with these as they're so delicate. Worked from the top down and used a little flexible masking tape between parts to try and keep things even. A tiny dab of gel CA on each piece so there's a little bit of working time to nudge into place. Then once dried a coat of varnish to hopefully make things secure.
  12. I use Gorilla white wood glue and find it dissolves nicely when needed. Their gel CA is good too if sometimes hard work to start a new bottle. Very good for second planking as spreads evenly with a bit of scrap to make a nice bond. For a low viscosity CA I use the cheap stuff from Tesco with a tube dispenser to get some control. The dispensers are about £6 for a bag of 50 ish from Amazon. Just trim the end if it drys, I’m still on the first one after several months of it open.
  13. You couldn't choose a better brand of kits to learn with. Start a build log, plenty of us will follow though many are finer than I!
  14. Thanks. Very enjoyable kit, learning a lot. I think Sherbourne is next for my stash.
  15. I think that's the deck nearly done! Just anchors to do before it's time for masts and rigging. Gulp. Will have to scope round and see how everyone has done rigging the cannon to the deck. Need to get more eyelets.
  16. Working my way through the deck furniture. Very little work for the drop keels. Just a little filing at the deck and the keel then all was well. I put that all together then wound the keels back and applied some dilute PVA to the cord on the drums as suggested. Clips to hold it in place till dry. Superb piece of Vanguard attention to detail, the PE winch handles have a prefab crease in them so they fold at exactly the right place! Hand pumps fiddly to put together but good. It seems something below was misaligned as the 30mm dowel was far too long and despite using a round file I couldn't get the height right so removed and trimmed about 12mm. Rest of the afternoon painting and putting Cannon together, ran out of time for Caronnades today. Little bit of paint touchup to be done later.
  17. Terrible pics but experimented with Vallejo wood colours and pleased with the results from prime, colour, dry brush second colour. Will do a proper update asap.
  18. Looking forward to seeing your build. Don't think it's impossible that its contemporaries landed on 'our' coast?
