Desertanimal
Everything posted by Desertanimal
  1. With that much difference it almost sounds like you are measuring with calipers off some sort first. Giving you a shorter distance. Obviously only guessing though. Chris
  2. That sounds like pretty good news! Good to hear. Sending you lots of good thoughts! Chris
  3. Hi everyone following along! I’m still here. Things got a little side tracked with a big welding project that made a mess of the garage. Well that meant I need to clean up where I’m trying to work. Well, that turned into “this garage really needs a good clean out”. Then I said “hey I have room for a new welder”, then I needed to run a 240v circuit for the new welder…So I’ve been busy. Now that you are caught up on my goings on, let’s get caught up on the build. Its time to work on the shrouds. We are in brand new territory for me with all this rigging. As I’ve stated previously I’m just going to go slow and try to follow some other builds. I believe I pointed this out earlier, but it begs to be said again. Don’t complete the top of the mast before putting the shrouds on. It will make your life much easier. At least this part of it. As my mast was complete I had to serve the shrouds in place. I leaned my vice way over and had the mast mostly horizontal in order to do this. Here are some photos of the serving of the ends of the shrouds. This is how I spliced the ends of the thread in. I would pull the thread through twice. Then a dab of medium ca and a quick rub with my fingers. Here is some of the manual serving done around the mast. A little explanation about the white pendants. They were my practice pieces for both serving the length on the machine and serving around the mast while in place. They are not the best work, and they historically probably wouldn’t have looked like that. But they were my first tries and I want to always know that. So that is why they are there. It was quite interesting to see the progression of the “quality” of the serving after only this many. I would sometimes try something a little different, like change the angle of the needle or such. Some things helped either in quality or being able to do it faster. Others not so much. LOL Finally, here is a glamour shot of her so far. I am quite happy with how she’s looking. She lives in an Ikea cabinet to keep dust at bay, once the bowsprit is on I don’t think she’s going to fit. Thank you all for checking in!
  4. I certainly can’t help with your questions. However I have to comment that your joints are very impressive. That truly is cutting close to the line straight from the saw! Nice work! Chris
  5. That size might be tough. You are probably looking at making them yourself. You can do it individually or wrap a rod with wire and then cut lengthwise along the rod with a dremel or such. Chris
  6. That is an excellent idea that I completely missed out on! The funniest part is I have a desk like that in my office! That will definitely be added to the room. That makes a lot of sense as assembly, light woodworking table. Chris
  7. So time to learn to serve! I decided I’d set up the machine and try it. It worked really well, not a surprise. I served up what could be a pendant if it’s usable. After playing around I watched a video and learned I should have done it left to right, while I did it right to left. The mast is together but not secured in the deck. I needed to come up with a plan to serve the shrouds on the ship. I again tried with the same pendant. I looks ok to me. We’ll revisit those later. I next wanted to make a band with the rings on the tip of the bowsprit. I used some brass tubing that happed to be a perfect fit and some photo etch eye bolts. I also made the bracket for the bowsprit from scratch. I can never get over how brutal close up photos are! Now I was faced with a dilemma. I didn’t add any sheeves to the catheads and I am pretty sure I want one of the anchors hanging as in other build logs. So I simply decided to get going on them. Mask the rest of the ship and see what happens. I drilled them and then used a scroll saw blade held in my fingers. I pretty much used that to shape the slots and then used a strip of 220 sandpaper to clean them up. I used some round plastic stock and after drilling I sliced off several discs until I got 4 I could work with. Squared them up but sanding under my fingertip. I inserted them and pinned them in place. Then some Vallejo flat black paint. I am pretty happy how these turned out. I will find out how they work when I get to the anchors. So that’s it for now. A lot more serving in my future! Chris
  8. Those are some great points. Thanks! The room also abuts the garage so I will probably be based on that wall. That will allow me to put dust collection and run air for the airbrush from outside the room. I am really liking the idea you guys have brought up about mobile tables. 👍 Chris
  9. Thanks for the ideas! How large are the various tables?
  10. Good point! Basically 10 feet by 12 feet. It’s a bedroom in the house so no heavy machines.
  11. So I’m going to be able to build a personal shipyard from the ground up. So I’d like some opinions on what you would do. Here’s the scenario, East wall has a window two other walls clear. I don’t generally work in the mornings so sun coming in the window isn’t a big concern. However, I’m thinking about backlighting while working on a model being a problem. I’ve got nice windows that are supposed to stop UV and such but who knows. I could also put the worktop on either of the other walls. What do you think? While I have always liked the idea (maybe the look also) of a countertop sort of work top with lower cabinets to either side of me. However lately I’m thinking of a peninsula work area so that I can get around to other sides if needed. Then when sitting at this desktop, that would put tool storage 90 degrees to my right in some sort of cabinets, maybe upper and lower kitchen cabinet style. I don’t know if that is optimal though. I like to have current tools I’m using laid out in front of me. I suppose that doesn’t really prevent that. Just sort of spitballing now, if you couldn’t tell. Lol I’m pretty sure I’d like drawers or doors in the cabinets instead of open shelves. This would be to keep dust off of things. Flooring- Wood, light color, not too much color variation. No seams to swallow tiny parts. Any ideas you’ve got to add? What sort of things do you wish your shipyard had? Thanks for reading if you made it this far! Chris
  12. Congratulations on her completion! She’s a beauty for sure. Chris
  13. OK it’s time to make some more fiddly things. I made a stove chimney, it turned out shorter than I had wanted but I kept it. I later painted it. Then I started on the topgallant staff. First I marked it off then I just started sanding to the lines. That made it square. In the photos it looks like I turned the step at the top after squaring, but I did that before hand in a drill. And then I painstakingly squared the hole in this piece so it was an excellent fit. (Does anyone see what’s coming?) Then I realized that’s not where it goes…. It looks fine after painting and such. I need to keep closer watch on these things. This is my first ship with a real mast and it has got me scratching my head a lot. I completed the trestle trees and cut out the flat areas for the cheeks and even tree nailed them in with some toothpicks. You can’t really see the treenails after painting, I wish they showed up better. Any tips on that? **Note to future builders. Don’t put this all together until after you have done the shrouds. I shaped all the yards with a variable speed drill and some sandpaper. After marking them out from the plans I would make some notes on various dimensions along the length, then I would roughly followed that. I would grab my calipers and sit on the porch and make sawdust. Thank goodness for Arizona weather. I would start with 100 grit and get the rough taper then 180 would shape it quite closely and 220 to fine tune the taper. I have to say it was pretty simple to get a nice taper on them. Easier than expected so that’s always nice. I thought I had a genius idea for mast rings once while perusing the hardware store. These small rocket engines seemed to have about a 10mm id turns out the end is kind of crushed to the clean part of the tube was too large. I did use the paper and CA and make some rings from that. I sliced some rings off then used rubber cement to glue them to the board and then sanded it face down until they were about 2.5mm thick. I then painted them but later remove it and sanded the outside flatter than I originally had it. These photos show most of the progession. Now a couple of glamor shots of how she was sitting at that point. Now has the swivel guns, stanchions (sp?) and the tiller. The tiller was epoxied and pinned. That is such a long moment arm with so little surface area, I was concerned about that joint ever giving up. Thank you for stopping by. Next up I start some prepping for the rigging. We’re pretty close to real time now as the rigging has really slowed me down. Chris
  14. It looks to me like the rope is too large. Pretty sure i used .2mm rope. Rope adds a lot of bulk fast. 2 mm blocks are probably about as small as you want to try to work with. Chris
  15. Thank you all for visiting and welcome back! Now it’s time to start the cannon tackles. If I am ever using incorrect terminology on any item. Please kindly correct me. First I rigged up the mock up in order to measure the distance between the hooks. I don’t have all the fancy books that many others have so I just have to use their information. So I weigh the instructions and build logs together, plus what I think looks pleasing. From the mock up I made a marking jig, it is asymmetrical to make way for the racks of cannonballs. I just had to mention terminology so the the name for those would fly out of my head… *Hint drill these holes wayyy before to permanently glue the deck furniture down. Just saying. (Especially the ladders) Drilling the racks is probably way easier before they are installed also….just a thought. I started to rig up the tackles on a jig to hold it still. The shorter one is for the shorter tackles. And the coils. I used watered down matt varnish on the rope after using CA to get it in place. And here we are in place. I used medium CA to hold things down. Later it will get sprayed with Vajello acrylic matt varnish to get rid of any shiny spots. Thanks for looking! In the next post are the boom, gaff and spars. And I scratch build some mast rings! Well, I try…. a few times. Chris
  16. Didn’t realize it was so much larger. I’ve seen other build logs and it never clicked that they can get more detail on them. Chris
  17. Thank you Daniel. I appreciate it. Thanks Jacques! I don’t know if you’re planning on rigging the tackles also, but I’ll be posting my process on them today or tmro. Of course it’s pretty much the same as Thukydides and Blue Ensign. Keep at it! Chris
  18. Thank you all for the likes and such! So now we’re working on some more details, first up is the rudder and the pintals/gudgeons. I cut them out sanded any rough edges and blackened them. Attached with epoxy. Next I wanted to try to make some ladders as Blue Ensign did. Lined up some basswood after making some guesses at the angle and went to town with a #11 blade. I think they turned out ok. One thing I did experience that I had to fix later was the different color they turned out because of the lighter base wood. Now on to cannon production. I was both looking forward and dreading these because I was worried about the tediousness of it all. It was actually fine. I airbrushed the cannon flat black and then dry brushed them with a couple colors of gray. Thanks Thukydides for the idea! I decided I would be fully rigging them so I drilled and installed the appropriate rings and eyes. I guess this picture is missing a couple. I made a mock up as I’ve seen done on here to facilitate the rigging. These seizings are really large. I don’t think this was the final design, but it’s the picture I’ve got handy. For the main breech rope I think I went with 100 mm length. All the rope is from Ropes of Scale. After getting the length decided I went into production. Here you can see the much smaller seizings. It’s really interesting to see how the later ones look so much better than the first few. Let’s just say a few at the beginning of the batch got recycled. Here is what it ended up looking like before the tackle. Even though I was only using three strand rope I decided I would spit the rope over the cascabel because it’s really difficult to see there is only one strand below. In the absence of available hooks, decided to make my own. Since I was worried they would not be small enough and be too long overall I decided to insert the hooks into the blocks and wrap the base with thread to make the seizing. First I drilled all the blocks on one end then inserted a wire to ensure I didn’t fill the cross holes with glue. Glued the hook with CA. These are 3mm blocks. I did these in two batches, the first batch I didn’t blacken first. That was a mistake. But I learned. **BTW** Chuck @ Syren now has 3d printed hooks available again! I got some but they will have to be for the next one… I think it was on Blue Ensign’s build log where he mentioned to try to keep them under 6mm overall. This is what I ended up with. I’ll leave it there for now. Let me know any thoughts you have. Next up are the cannon tackles. Chris
  19. The little hinges are just pieces of brass tubing that I filed a little notch into for some visual interest. I later gave them a blackening treatment. A fixed them with a tiny dab of epoxy. Thanks for checking in! Chris
  20. I was able to grab my copy before they went out of stock again! HAHAHAHA Thank you Mary for all you do! Chris
  21. Congratulations on her completion! She is beautiful. You’ve done a wonderful job! That’s a very impressive display case! Chris
  22. OK it’s time we get some details worked on. I worked on the catheads, they took a little shaping so that they were sitting flat and square. I painted and added the PE to them. I opted not to cut sheaves into them. A price I’m currently paying and deciding if I want to add them at this stage. I most likely will, but we’ll get to that when the log catches up. I decided it was time to install the cannon ball racks. I decided I would paint them red. I copied a little jig I saw here in order to keep them at a consistent height of 3mm above the deck. I worked on the rails and pinned them like the instructions said. I don’t remember seeing too many details about this part. Here are the results. At this point I did not check that the shrouds would interfere with the gun ports. I read that I should have done that, but it was after the fact. I located them purely based on the instruction book. Later on I did check them for interference and I was happy there was none. I took a little artistic license with the other deck fittings. I don’t know if the one is supposed to be a hatch, but mine is. I also made an additional one as I saw in the other builds mentioned. I blackened the hinges later. I made pumps from scratch and used the PE from the kit. I added shrink tubing for the bands. The metal parts were quite enjoyable to make. The pins holding them together are peened. The winch was fun to make, several pieces that need to fit together nicely. I had a good time getting these together then adding the PE iron bands to it. (As B.E. did, I have since added nails (?) going down into the deck. I think those were a good addition that you will see in later photos.) I will leave you there for now. I hope you enjoy the photos. More to come! Chris
