flyer
Everything posted by flyer
  1. The next step was installing the various deck fittings. First was the main winch and bitt assembly which worked well Then came the forward companionway which presented the first problem. The parts of the coaming didn’t fit the grating and had to be shortened/adapted. Speaking of the grating: those wooden, laser cut gratings which come with the second edition of the kit are superb. The jeer bitts assembly went like a dream while the main hatch did ask for minor adjustments. The pumps got a small upgrade with iron hoops made of cartridge paper and discharge ports made of reworked cable-end sleeves. The aft companionway was a bit changed to imitate the sliding runners. The coaming of the skylight was completely changed to let the grating into the coaming. That grating was also filed thinner to make room for a ‘glass’ pane underneath. Two short pieces of wire imitate the hinges. The bread hatch assembly was then straightforward again. Finally, the stove flue was taken in hand. Fortunately, I was initially unable to locate the flue (part 108 - found it later). With some stripes of cartridge paper, I folded and glued a square tube (or to be precise, about 5 of them until I had an acceptable result), painted it black and glued it into its base. Now the serial production of the guns has started. main winch forward hatch, stove flue and jeer bitts pumps and aft companionway skylight and bread hatch
  2. Thank you for enriching our hobby and I really admire the work you do for those figurines and make use of them as much as possible. On my models I try to present everyday figures and preferably in a posture they could hold comfortably for a few minutes. (In railroad modelling I learned to place figures and cars in an unspectacular position, so that you wouldn’t be surprised to see them in just the same way a few minutes later. It adds reality. So only ballerinas standing on tiptoe and never somebody running or fighting; but people talking, standing or sitting.) Therefore, I humbly suggest figures of sailors doing quietly usual tasks: E.g. A lieutenant (could be Babbington) being skipper on a cutter or standing watch with telescope under his arm . A seaman (Barret Bonden?) serving as lookout or looking for albatrosses on the horizon. An able seaman climbing slowly the shrouds. A marine standing guard. Somebody scrubbing the deck. An able seaman steering. … But of course, only if you are no more than ankle deep in work. And the Aubrey/Maturin pair will be a must for my future Surprise - they could be scratching away on their fiddles for hours. Regards Peter
  3. The next bit was finishing the bow. Sometime during that process, I decided to leave the stem in natural wood instead of painting it black. It is simpler and with the equally natural stern post it looks symmetrical and pleases me. The rest was pretty straightforward according to the instructions. The shot racks are installed as well, as are the entry steps. The openings in the shot racks were opened up a bit on top to give a better support to the shots in rough sea. the mizzen mast steps are in place as well a really nicely looking vessel
  4. Adventurous? Perhaps, sometimes, but not crazy enough to try that project. Your very well-done Alert would make a much better canvas for such a painting than my poor one. It’s also a question of resources – timewise, I think. Being over 70 now, I might only have some 30 useful years more left in ship modelling. Therefore, I should better concentrate on projects which I might possibly finish in my time. 😉 In the meantime, I will try to fix the worst shortcomings those merciless pictures did uncover. As always.
  5. Building the stern really was a puzzle. More than once, I was properly puzzled how to make the parts fit while trying to adhere to the kit’s manual and Peter Goodwin’s book. The kit’s upper transom part leaves an open space at the lower end when properly brought to the height of the platform deck. Others had the same problem before – so it seems that not only unprecise building on my part is the problem here. A sidewise bent 1 x 3mm strip was glued on below the lower end of part 49 and adjusted. Next problem was the side counter timber which is one massive timber on the prototype, including the boom cradles on top, but here consist of several parts (part 76 and the outer edges of part 49 and somehow the parts 75). After due consideration I didn’t fix the cradles on the side of the transom but glued it onto its forward side, trying to create the impression of one continuous counter timber. Above the stern chase ports should be a rail, the upper counter rail. To simulate it I added a 1mm x 1mm strip on the inside on the same height as part 52 on the outside to create the impression of a 3mm wide rail. Building up the rough tree rails needed a lot of adjustments but was more or less straightforward. One still open question is the painting of the counter. Goodwin shows it in black while the kit’s manual leaves it open. To leave it in wood and varnish would still be an option, especially as I don’t intend to add the decorations. They would certainly look nice but also a little bit pretentious for a mere cutter. The blue colour band in itself is probably already rather more than an ordinary cutter would get from the admiralty. Additional strip below the transom Building up the upper counter rail Approximation of the side counter timber All painted and testing the tiller – so far, so good
  6. Thank you and I will do my very best. A visit to your Alert showed me what could be possible. Presently I do not plan to attach the friezes but will try to achieve the impression on the cover of AOTS Alert instead. Making my own sails and adding a boat should nevertheless create a sufficiently sophisticated result.
  7. Next step was installing the deck and planking the inner side of the bulwark. Below the two 4mm planks I added an additional 1mm strip. This gives the bulwark a bit more height and could be an approximation of the waterways. Then I marked the positions of the gunport openings with the help of the provisionally installed drift rail. The openings were the filed down to 5mm above deck level. After some final trimming of the bulwark top, the rails were glued on, the required slots cut out and the gun ports trimmed. During that process I noted that the foremost gunports (which are covered by the drift rail) don’t work because the drift rail conflicts with the cannon. After rechecking the instructions as well as the size of the gun I decided to let that stand but would grant the skipper the use of a saw when he sees the need arise to use that ports in earnest. Now the strips marking the sheer rails and finally the main wales were glued on in the appropriate height. For better definition of the colour, I tried to paint all parts as far as possible before glueing on. This is helpful when installing the inner bulwark planking but worked as well on the wales. Now I did place the draught marks and horseshoe and fish plates on the keel. With a mixture of whitewash, dull white and about 5% dull black I painted the lower hull and the lower part of the rudder. The rudder fittings were blackened and glued onto rudder and hull. The rudder is only provisionally fixed. I deliberately painted over the keel plates and the lower drought marks as I consider them part of the construction and they may benefit from the protective cover with white lead paint. On the other hand, I left the rudder gear blank as it is part of a mechanical device which should move freely and may need to be occasionally checked for wear and tear. Trimming the rails Hull almost finished rudder Seems one of the carpenters was a bit careless with his axe 6 pounder gun looking elegant
  8. The second planking is now finished. It took rather long due to being a bit fiddly (and my sometimes lacking motivation). The outcome is unfortunately to my liking. Unfortunately, because I intended to paint the lower hull with an off-white paint. Now with the quite acceptable planking I’m having second thoughts about covering my woodwork… Next the wales and different wooden strips will be placed ‘from inside to outside’. The height of the bulwark was set somewhat by eyeballing and is now too high. I will install the deck, mark the height of the bulwark on the inside, sand it down and measure the position of wales and decorative strips on the outside from the top down. Nex time I build this kit I will take care to correct the upper edge of the first planking to the correct height above deck BEFORE starting the second layer!
  9. The shipwrights in my wharf worked rather slowly lately. After Bellerophon any project seemed a bit trivial. A longer inactive period has now ended and they are set to proper work again. I used the beautifully laser engraved lower deck to try different methods to caulk the seams. But neither following the seams with a sharp pencil or fine marker nor filling the seams with black paint and scratching the deck clean again produced acceptable results. Finally, I decided to use the main deck just as it is, with a layer of clear varnish. Now I glued, filled and sanded the first planking layer. During that task I found that my worry about perhaps building a too simple kit was rather invalid and the task was as demanding as ever but fortunately included a much smaller hull than the last one. I love the elegant lines of Alert’s hull
  10. Hi Techtonic Thanks for the hint and congratulations for finishing that monster. And what a lovely result you got and in such a short time! Did you ever sleep? About using others’ ideas in one’s own build: I’d rather call it borrowing because I don’t keep them but preferentially pass them on. Some details you found in my log were other’s brainchild. And anyway, I’m rather flattered that you found my example helpful. Cheerio Peter
  11. A smaller boat is very high up on my wish list too. Logic dictates that any ship definitely needs at least one boat to communicate with the shore and for various other tasks. In ‘The Naval Cutter Alert’ Peter Goodwin writes about boats: “… For conveying stores, dispatches and officers and crew, the Alert carried a single boat. (…) In all probability, 6- or 8- oared cutters varying between 12ft and 18ft in length were employed. Alternatively, a long boat either 14ft or16ft in length may have been used. (…) In December 1763 one such (Admiralty) order decreed that during winter only one small 4- oared boat should be allocated and that it should be carried rather than towed to avoid being lost. An order of June 1779 mentions 16ft boats for cutters while another of July 1783 recommends the addition of a second boat. (…) When not in use the boat was stowed on the upper deck between the main jeer and topsail bitts and the two elm tree pumps abaft. (…) When required the boat was either swung out or hoisted inboard from tackle suspended from the boom. Should the vessel encounter action the boat was towed astern… The ships boat also served to convey boarding parties onto vessels ordered to be searched; and for laying out the kedge anchor for warping the ship; or for towing the ship when becalmed. ” A contemporary model of the naval cutter Hawke kept at NMM shows a small boat stowed on deck. I guess that all this information is also valid for any other ship or smaller vessel. So, each vessel must have had at least one boat. It may not always be shown on contemporary models because smaller vessels may have towed it quite often but for heavy weather there must have a been a possibility to take it aboard. I really would appreciate a model of a small 12ft or 14ft boat which would also fit all your small models. With a small stand to place it on deck included, you should be able to sell at least one model to every serious model builder who bought one of your smaller kits 😉. Peter
  12. The Naval Cutter Alert by flyer - Vanguard Models - scale 1:64 The next project is another step ahead in kit quality – a Vanguard Models kit. The HMS Vanguard kit itself was also a Chris Watton construction, however with his own line of products I believe he took quality one or several steps further. Although the kit looks great, there are – fortunately - still possibilities to change it to my liking or even to improve it a bit. For additional information I will count on Peter Goodwin’s ‘The Naval Cutter Alert 1777’, a book of the AOTS series. My first thoughts are: The cutter must have a boat. With the kit I ordered Vanguard Model’s 18ft cutter with the intention to shorten it to 14 or 16ft to easier find room on deck. In the meantime, Chris Watton announced that he will soon offer a printed 14ft cutter. I will consider this or – if it is still too large – perhaps commission Caldercraft’s 14ft jolly boat. Sails will be hoisted. But I will make my own as the kit’s ones are not to my liking. The rigging layout could be changed to an improved and standardised cutter rigging without spread yard and with spreaders for the shrouds. However, right now, I think the kit’s rigging scheme has its very own charm and is not only confirmed by the contemporary model of the cutter Hawke but also by contemporary paintings of Charles Brooking. Decision to be taken later. Shipping in Light Airs in the Thames Estuary by Charles Brooking 1723 – 56
  13. Very nice! This seems to be a 18ft cutter. Do you also plan to offer a smaller 12ft or 14ft boat, suitable for your smaller vessels, such as Alert?
  14. Hi Nils As we would say in Swinglish: I pull my hat before you (ich ziehe meinen Hut vor dir). Not only have you built another unique, detailed, outstanding gem but you also finished it in about 8 months! From scratch! Without plans! Wonderful! Cheers Peter
  15. Hi Allan, And a happy new year to you too! Yes, Lees mentions '...through blocks under the fore top...' several times and the drawings show those blocks fixed at the extremes of the trestle trees - except on page 102 where a 'double block is seized to the crosstree'. I wonder if regulations in those times really went as far as to specify the exact locations of those blocks. Lees, in his introduction, mentions that his written sources mainly deal with size and dimensions. I guess that the actual run of the lines of the running rigging he shows is an average of the many but still limited number of models he studied. I'm always tempted to follow kit instructions if they are not directly contradicted by e.g. Lees. Respectable kit designers may use Lees or their own research for the rigging plans and certainly try to be as historically accurate as possible. But even somebody like Chris Watton may have to use approximations sometimes to construct a practicable and sellable kit. And then sometimes I'm just lazy and tempted to take the easy way out. Cheers Peter
  16. The question I tried to answer was about the green circled blocks in the 2nd picture of #1: I took those as indication of having two identical rows of blocks on the forward and aft crosstree. The lines then are going through the identical blocks on each crosstree thus leading free of and above the fore yard, perhaps to give some space to brace the yard. In Lees' book you find on page 73 top right an illustration for the buntlines, installed that way. (BTW on Bellerophon I used a similar arrangement also for the main yard.) The two outboard single block pairs were thus used for the buntlines and the inboard double block pairs I used for spritsail and sprit topsail braces. This is confirmed by Lees again on page 101 respective page 105.
  17. conclusion After more than 6 years, I'd say it was a rather longish journey but I really had a lot of fun along the way and it was definitely worth the effort. The outstanding quality of the kit and the possibility to build 3 different ships makes it easy to overlook a few shortcomings, such as questionable details in the rigging plan or the very questionable gun carriages. On the plus side are also things like the very detailed plans such as the sail plans, the boats or the many fine details to build bulkheads or stern and side galleries. A perfect kit where you may build just out of the box without research or rounding out with additions might be just a bit dull - I will probably find out more about that with my next project. In any case this kit enables you to build a wonderful model of a 74, the backbone of the wooden walls protecting Great Britain during the Napoleonic wars. Finding a good enough place to present the rather large end result is another story... a few final pictures.
  18. Thank you all for the compliments as well as for all the support carrying me through this build. And a very happy New Year to all of you! Peter
  19. changes, amendments and mistakes The biggest changes were the dummy gun carriages on the gun deck and the cast gun carriages, the stern decoration as well as leaving of the spritsail topsail and its yard. The most rewarding improvement, in my opinion, were the dummy carriages. Thank you, Michael (md1400cs). On any kit which includes such dummy guns, installation of a sort of dummy carriage should be tried. Minor amendments were the changed curve of the stern, the scuppers, the sails fabricated my way, the flag, shot garlands, the captains skylight, the taffrail, the rudder chains, the anchor bolsters below the fore channels, the traveler on the bowsprit, anchor buoys and several minor changes. The biggest, uncorrected mistake is probably that I did set up the preventer stays above the stays, thus having to hang the staysails onto the stays themselves. slightly reworked gun carriage for the upper gun deck and dummy carriage for the lower gun port with dummy-carriage and -gun / carriage and no gun / gun and no carriage the elephant was scratched away and replaced by a epoxy-cast of Bellerophon finished transom with new rail on top spritsail without topsail and traveller on the bowsprit, holding the jib stay
  20. Thank you, Nils. When I see what quality you achieve, scratch building your Ergenstrasse, I appreciate your compliment even more. Oh, and a very happy new year! Peter
  21. empty belaying pins and ringbolts, loose ends Despite having to overcome a shortage of usable belaying points on the forecastle there were still a few unused pin positions on the poop deck. Also unused ring or eye bolt positions around main and mizzen mast had to be filled. The kit instructions put eye bolts into those locations. However I think that ringbolts, allowed to lie flat when unused, would be more sensible when mounted on the deck. I didn't find much about that in the web but thought it would be easier to run about on deck if you wouldn't have to fear to catch your bare feet in a ring, take a tumble and break your ankle. To imitate a ringbolt with a small fixed ring which encloses the movable one tightly, I bent an eye bolt 90° and put a drop of glue onto it to simulate the fixed ring. After fixing all loose ends I could find, finally...finished! the way I fabricated the imitated ringbolts unused ringbolts around the mizzen mast foot fore mast foot with eyebolt(with tackle) to the left and one of the empty ringbolts lying flat on the deck moderately busy scene on the finished forecastle the skipper seems quite fond of his ship - and so am I...
  22. anchors A suitable stream anchor was added to the 5 anchors from the kit, all completed and stored. A conflict for space occurred between the sheet and bower anchors and the lower stun sail booms. The only way I could think of, was to place the anchors on top of the booms. Thus, to set booms you have to move them from under the anchors. Anchor buoys were formed with some 2-component putty and hung into the shrouds. As I understand anchors were buoyed and buoys should therefore be shown whenever a cable was bent to the anchor making it ready for use. For size I used information from John Harland who writes that '... the anchor buoy was in length one-quarter the length of the anchor shank, in diameter, one-eight...'. port side with sheet and bower anchors and the extra stream anchor lashed to sheet anchor stream anchor the cable is attached to the bower anchor and the cat block with tackle is hooked into the ring starboard with sheet and bower anchors and the kedge anchor lashed to the sheet anchor kedge anchor anchor buoy stowed in the fore shrouds the buoy rope lashed to the anchor
  23. jib sail Several tries were necessary to find an adequate size for the jib sail. To me it was clear, that the kit's plan for the sail was grossly unfitting. Trying to draw one following the description in James Lees in 'Masting and Rigging of English Ships of War' was more difficult than expected. Several attempts were tested with paper templates just to prove unsatisfactory. Finally I tried to use the same proportions in regard to rigging and the other sails as Pandora's jib in the ATOS series has. Judging by eye it looked about right. To bend the jib to its stay I used again figure-of-eight robands. The tack was hooked into the traveler and the rigging set up with help of the kit plans and instructions and some clarification by Lees. Now I only have to install the anchors, to check the natural hang of all lines and to clean up everything... Oh yes, and to find a suitable berth for a rather big model... trying to find the right size - the smaller blue outline is the final one detail of the peak all sails are now installed
  24. Brian Lavery in 'The Arming and Fitting of English Ships of War' also writes of using cuprous alloys. He doesn't say what kind of alloy exactly but he writes about the problems with the strength of bolts made from pure copper and the search for a suitable alloy almost as strong as iron. Comparing different copper alloys I think the solution probably was some bronze - copper and tin - as it is the strongest. What the cost of such fittings was, is another question but losing a ship because of the decay of iron bolts was certainly costlier. Peter
  25. Hallo Franz Your Barbara plan seems to me a really valuable discovery. Building her with the Pickle kit seems an excellent idea. If you like you could still name her Pickle and be probably closer to the real boat as Caldercraft or me. By the way - I didn't suggest that Calcercraft was using the Adonis class plans but that I would use them to overwork their Pickle. You could further consider a contemporary painting by Robert Dodd which probably depicts Pickle in the foreground on the right. There you see a vertically stepped foremast. https://www.meisterdrucke.ie/fine-art-prints/Robert-Dodd/99918/The-Defeat-of-the-Combined-Forces-of-France-and-Spain-at-the-Battle-of-Trafalgar-in-1805-(colour-engraving).html Looking forward to your build log! Herzliche Grüsse Peter
