flyer
Everything posted by flyer
  1. Great details, as always. Just a little remark: Those openings are actually sweep ports. It's hard to imagine what a nightmare it must have been to move such a ship by sweeps, especially with hardly enough room on the deck to operate them. But even HMS Pandora 1779 had sweep ports. And she had about 524 tons to move against the Swan class' 300. The bomb vessel Granado 1742 measured about 270 tons and (according to the respective AOTS book) stowed 18 sweeps (plus 6 spare), each with a length of about 10m or 33ft. Good luck for finding a place to store them!
  2. bobstays Following a discussion about bobstays on Alan O'Neill's (AON) log for his fantastic Bellerophon I found that the bobstays were lashed together in front of the beakhead and ran in parallel. When I tried it, I found, that not only the bobstays now clear the figureheads arm, but the new arrangement looks much tidier and shipshape. Thanks for all the inputs! bobstays lashed - Bellerophon's left arm is now free looking better
  3. Following that great shared information here, I checked Lees again. On several illustrations, especially on nr 73, the lashed bobstays can be seen. After trying lashings on my Bellerophon the conflict between the bobstays and the figurehead could be solved without any bloodletting. And it looks much tidier now. Thanks all.
  4. Worried. Sure. Looking at your build I just can't imagine you not carving an outstanding figurehead (without any parts standing out to much). Checking the book The Billy Ruffian I found not much information on the effigy of our hero but I somehow doubt they carved any figurehead with such protruding parts much likely to brake of. I'm eagerly looking forward to see your solution. Anyway, until you reach that stage you still have a few months to consider how to depict our hero.
  5. Foremast and bowsprit The standing rigging was set up mostly according to the kits plans. Again the futtock shrouds have a strength of 1mm. A small problem showed up, when setting up the bobstays. They conflict with Bellerophon's outstretched arm. Just a few days before putting the stays in place an accident involving a lamp and gravity had broken of the said arm. After fixing it meticulously with epoxy glue I was only slightly annoyed to find it being in the way of the bobstays. Braking it again was no option - I mean he is a hero, no less! Now I hope, that one doesn't notice that the hero's arm pushes the stays a bit. Anyway it's nearly impossible to avoid a conflict. Perhaps this figurehead should be constructed differently, e.g. he could lift his left arm to face level. lower foremast and bowsprit standing rigging set up fore stays, bowsprit shrouds and bobstays attached the hero's arm got entangled in the bobstays foretop
  6. Hi Bug Welcome to the club. A few weeks ago a halogen lamp, provisionally fixed at a shelf, wanted to brake free and fell onto my build. Bellerophon himself had his arm broken and a cathead was dislocated. Fortunately all could be fixed with a few harsh words and some epoxy glue. Replacing a whole wheel however seems much worse. Gravity sucks. Truly great swivel guns, btw! Cheers Peter
  7. Hi Andy Nice to hear from you again. The Confederacy really looks a beautiful subject and your work looks fine (as usual). One question remains: Every time I see that kit I wonder about those large holes in the hull between the great cabin and the quarter galleries. This is hardly according to the original plans. Doesn't it distort the look of the finished model or don't you ever notice it when looking in, through the windows? Anyway, keep up the good work! Peter
  8. Hi Bug Your quarter galleries could evoke envy among us poor out-of-the-box builders. Wonderful detail. About the copper: That shiny nice state is beautiful but rather unnatural as copper oxidizes quite easily. My solution is to polish it to remove all fingerprints and stains of glue. Then I let it age just naturally without any protective layer. In a few years it will get that dark, coppery-brown colour which is generally known. Cheers Peter
  9. Hi Bug You have been busy. Fantastic work. Regarding the keel I thought it a good idea to have the keel protected by copper also on the underside. The false keel probably wasn't made from very high quality wood and after losing a part in an accidentally ground contact they would first have had to find a wharf to replace it. So that additional protection by copper would perhaps have paid off. Being lazy however I usually copper only the underside which is not covered by the false keel. Cheers Peter
  10. Hi Bug Your Pegasus is coming along real fine. I especially admire the extra details you add - and their quality. (I'm a fan of including the scuppers too, but I never had the guts to drill them through from the inside - I just show the outer opening.) However I hope you permit a remark to your gratings. As far as I understand the gratings were removable while their frames were fixed to the deck. For stability therefore the removable lighter coloured insets should end on a frame and not on stubbles. You could check on the example in this article: Sorry for nagging but to me this detail sticks out like a sore thumb. Keep up the great work. Cheers Peter
  11. Hi Alan Yes, diameter. Perhaps an accidental slip into a too verbatim translation. In German technical texts you use sometimes 'Stärke' as diameter. Be aware that I don't check all rigging diameters against the tables in Lees - only when I see some strange proportions or if it seems illogical from a technical point of view I do a crosscheck. According to Lees the futtock shrouds should have the same diameter as the corresponding topmast shrouds - which is logical. They have to transfer the pull from the topmast shrouds to the anchoring point on the lower shrouds. Peter
  12. Main mast The lower main shrouds were set up in a similar manner as those of the mizzen. The futtock shrouds have a strength of 1 mm. Some alterations to the main stay and its preventer stay were necessary. The kit's plans are a bit ambiguous as how to fix the forward ends to the bow. After some searching in web and books, I decided to follow Lees and set the collar of the main stay up the way the preventer stay is shown on the plans: It leads below the forecastle rails and the collar goes through the hole in the beak below the bowsprit. The preventer stay leads over the rail, it's collar over a pair of new stop cleats on the bowsprit and through an additional hole in the beak. It runs a bit close to the seats of ease and may irritate the seamen there but nobody said that the life of a seaman is a bed of roses. The snaking of both stays was continued past the foremast. On the plan it ends there but probably this is because the preventer stay up to 1793 only went to the foremast and only later to the bowsprit. As I try to show my Bellerophon the way Napoleon might have seen her, I set the preventer stay up in the later fashion. The lashing of the stowed boats seemed inadequate. I cut the spliced eyes from the ringbolts and threaded the lines through it and set them up double. That will look better in some lively weather. Main shrouds and stays mast top with crowsfeet stays on the starboard side of the foremast stay collars better lashed boats
  13. Hi Walrus Pickle is my favourite build. But I never really liked the look of the 'out of the box' builds. The sources of the kit's planes seemed doubtful to me and I took an RMG plan of an Adonis class schooner as main reference. The result still pleases me very much and has a prominent place in my house. Regards Peter
  14. Hi Robert Your Victory really is an outstanding model. Comparing my Bellerophon with your build I can hardly believe that they are in the same scale. Being at exactly the same stage as you I will visit your log occasionally and hope to shamelessly profit by your example. I Love the quality of your pictures as well. Regards Peter
  15. Standing rigging Mizzen mast Again I started low and aft at the mizzen mast with the standing rigging. First I prepared the tackles and shrouds around the masthead. Then, after putting up the first three shroud pairs, I installed the respective stay and tried to balance the forces on those lines, while keeping the mast upright. Several deadeyes had to be reset to get an more or less even distance from the deadeyes on the channels. Then the remaining shrouds were set up. First priority always has an equal pull on all the shrouds and the deadeyes forming nice parallel lines only second. In fact I think that on real ships all those ropes constantly worked and resetting of the shroud lanyards probably was an constant process, keeping an even pull on all that shrouds during hot, cold, dry and humid weather. I doubt that every time the deadeyes were newly aligned as well. At least this is my excuse for the uneven line of my deadeyes. To set up the ratlines (yay!) I used cow hitches at the ends and clove hitches between. Finally the crowfoot was set up. A first few corrections to the strength of some lines in the plans were necessary: - the strength of the futtock shrouds on all masts is of course the same as that of the associated topmast shrouds. - the catharpins in the plans are to fat. According to Lees they should be 25% of the main shrouds which are 1,3mm - I took 0,25mm line for the catharpins. one seaman to set up the ratlines and two to supervise him - efficient would be different...
  16. The spritsail yard was made with some changes to the kits plan. The centre part is only 8- instead of 16-sided. in Lees I found no information which showed it 16-sided - the crossjack seems to be the only one with this feature. Also the holes in the yardarm of the spritsail yard - supposed to take the sprit topsail sheet - were replaced by blocks at the yardarms. Lees doesn't mention any sheaves in those yards but leads the sheet through blocks. The boomkins were also made but only provisionally fixed. Putting them in too early would be just another disaster waiting to happen. They are a bit sturdier than the kits sketch. Again I tried to follow Lees. While working on this I thought about how to fix the boats on the beams. As I know Murphy, he would like to have all kind of things falling into to waist, out of reach as soon as the boats were fixed. So the lashing of the boats will have to be easily releasable. The first solution was to splice a line to an eyebolt on one side and the lead the line alternately over a boat and trough an eyebolt on the beam until fixing it to the eyebolt on the other side. While working on the rigging I may come up with a better solution. I think the boats were lashed individually and I should try to imitate this better. Spritsail yard and sprit topsail yard boomkins boats lashed on the beams false splice Somewhere in those pages I found a 'false splice' which I would like to share here. I use it often, find it helpful and it's easily done. The example is the lashing line for the boats, spliced to the first eye bolt. 1: thread the line through itself 2: ...and back again, marking the length of the splice. 3. pull taught and fix with diluted glue 4. cut the free end to length. Voila!
  17. Rudder improvement AON showed in his wonderful Bellerophon build, how to improve the look of pintles and gudgeons on the rudder. They are etched brass with a row of holes. Using those holes to nail the parts on would have given a too coarse impression. I just glued all on and left the holes open. Now using a drop of glue, applied twice into the hole and painted black or copper simulates an acceptable bolt head. the rudder before reworking with holes instead of bolts glue drops applied reworked rudder hanged again Bowsprit and jib boom The bowsprit was quite an interesting spar to build. To facilitate the adjustments according to the angle of bowsprit, I set my vice to the same angle for most of the construction. While handling the jib boom I decided not to fix neither jib boom nor the dolphin striker yet (more to that part later) but wait until the rigging process would need it. This will reduce the risk of damage especially while frequently turning Bellerophon. Below the bees I fixed some simplified bee blocks and the allocation of the caps eye bolts differs slightly from the instructions to leave room for manropes and jib boom horses. Not all went smoothly: The end of the bowsprit is round instead of square due me to overlooking wrong kit instructions - but that mistake should be covered by the cap. And the making of the stay collars was such a delightful task that I made 5 of them: no serving, wrong rope strength, wrong method of attachment. But for now I'm happy with the result and working on the yards. bowsprit end with simplified bee blocks bee blocks and cap lavishly glued on (to cover the snags) collars in place but main fore stay collar not served and the bobstay deadeyes collars wrongly spliced approximately 4th attempt for stay collar final arrangement of collars with jib boom provisionally in place bees and cap now only the two spritsail yards remain and then finally I may start rigging - yay! Dolphin striker and martingale stay The 1786 Belerophon most probably didn't have a dolphin striker. According to Lees they were first introduced in 1794. However I think it possible that one was added later on, to support the jib boom. The piece provided with the kit resembles a dolphin striker of the very first generation, nailed onto the front of the cap, with just a score cut into its end for the martingale stay. This striker was in use up to 1800 - still according to Lees. Up to about 1805 martingale stay and martingale back stay were combined and led from the end of the jib boom to the notch in the end of the striker (this part was the martingale stay) and then further on to an eyebolt in the head (martingale back stay) to be set up with a fall. Now the kits plans had me pondering. It showed such an early variant however with the backstay part set up with a fall just behind the bees. Nowhere in all my books I could confirm such an arrangement. Finally I found in Zu Mondfeld's book a sketch where the backstay part is led through a block near the collar of the fore preventer stay towards the head. Assuming that the designer of the kits rigging perhaps took a kind of a shortcut, but was close to the correct appearance, I think that this version would be a valuable solution. Where in the head the eyebolt for the fall should be placed, I wouldn't know. Lees states that it was set up on the bow, port side of the bowsprit. So, I think the lower part of the port knighthead might be a suitable place to put that eye bolt.
  18. Hi Mitsuaki Wonderful deck planking, really well done. Btw. I came to the same conclusion regarding the gangway planking. Cheers Peter
  19. Hi Alan Thank you for sharing that great idea. I had to try it out on my Bellerophon's rudder and it definitely looks better than a line of holes. As always your ship and her details are outstanding. Cheers Peter
  20. Hi Mark As always very clean fine work. Just for your information: I had the same problem with the mizzen channel supports missing in the plan. However I didn't trust the stability without knees or something and placed 3 supports below the mizzen channel and one below the mizzen backstay stool. My carpenter and the bosun agree with me. one support below the middle of each of the two aft most and one below the fore most pair of dead eyes, one below the centre of the stool Cheers Peter
  21. Hi Michael Do you mean the decorative strip? No big deal. The profile came right out of the box. Similar profiles would e.g. be available here: https://www.cornwallmodelboats.co.uk/acatalog/Walnut-profiles.html Cheers Peter
  22. 28 foot pinnace The assembly of the last of the boats followed the example of the others. The equipment includes rudder and tiller in addition to the kits oars, boathook and kedge anchor. Only the rowlocks hat to be made separately of 0,5mm wire as thole pins. They are not just notches in the capping as for the other boats. I had the bosun try to rearrange all the boats on the beams and to fit them better between the rails guarding the waist. No success - he ended up the same way as before with the starboard rail only partly in place. The hammock cranes along the waist on the starboard side were put in place and hammock nettings installed. finished pinnace all boats on the beams starboard hammock cranes finished
  23. Hi Mobbsie Long time no see - welcome back! Surprise was always on my wish list however I've given up on JoTiKa's to be ever on the market. But - have you seen the Sphinx kit Chris Watton is working on? https://modelshipworld.com/topic/20737-chris-watton-and-vanguard-models-news-and-updates/page/43/ She was even a bit smaller than Surprise. With her 20 guns just large enough to be rated at all. But she looks a beauty, wouldn't use to much space and I'm sure Jack Aubrey met her once or twice during his career. Take care Peter
  24. Hi B.E. This solution of yours is very clever and looks really good. Presenting the model in a tangible situation with the details such as masts, sails, boats arranged accordingly ads plausibility. I prefer this to a somehow artificially admiralty model. Those are truly great as well, but also exceed my skill level. Might I ask about how many ship models make your house filled up? Bellerophon is my 8th, but one was given away. Cheers Peter
  25. Hi Meriadoc Brandybuck Thank you. Yes, however I think that generally space in Japan is much more limited than here. Despite that, my admiralty would object to fill all available space with ship models. Again, I guess, a known problem. Anyhow Bellerophon will remain in the wharf for at least two more years... Sayonara Hi B.E Thank you for the compliment but frankly one of my fixed lamps broke down and I had to improvise with a handheld one. So the result is just coincidence. And thanks for the suggestion. Your Victory (Heller?) looks great. Did she just come back from cape Trafalgar? I like your way to present her much better than those sawed off mast stumps or nearly bare lower masts you occasionally see. It is an option but still I would like to set at least a few sails and I already laboured on those upper masts and yards... Cheers Peter
