Bill Hudson
About Bill Hudson
  • Birthday 01/21/1932
  • Gender
1,690 profile views
  1. I have revived this build. Now being 93 years old I am not liking not doing building. I find my dexterity is failing but I'm not giving up. I have started adding the deck furniture. This is where I am at this point.
  2. Kind of got ahead of myself. Yes I should put together pictures of the kits guns and poor instructions. Thanks all Bill Hudson
  3. I have a La Toulonnaise Artesania Latina kit setting in my closet for quite long time. I have questions on how the cannons are supposed to be built.
  4. I am thinking blue with white below the water line. I like the look of copper but I'm not sure if copper was used back then. Quite possibly lead (pewter) though. Lead would oxidize to off white or light gray; still in the thinking box with colors. I feel I need to have the hull painted before I go to above the deck work.
  5. Back in the world again. Back on the mini cutter. The clamps I was using to clamp on the keel to hold the boat while I was working on it were causing damage to the keel wood. I drilled the keel to accept two heavy wires to use as standoffs. I will probably keep them on the boat to mount it to a simple stand. I have spread a coat of white primer. Tomorrow I milk sand it out, repair the flaws and apply a second coat. I'n not sure what color I will paint the main hull. Black seems too blah. I think I read somewhere blue was used for hull colors. Maybe I will use a very dark blue.
  6. A break away from the ship momently. Trying to airbrush has been a problem. Only had a very noisy compressor out in the garage. It is not at all compatible in my little shop off the dining room. I looked on the internet and found several about 4"x4"I was reluctant to order from the unknown source but discovered a similar on in the Micro-Mark catalog that is rated at 25psi. . I ordered it but the hose connections do not fit my Passche airbrush. I contacted the MM tech department and got Dave. He sent me an adapter free of charge which works. Has a nice flow of air although I haven't tried any paint through it.
  7. I decided it would be bestt to remove the bad gunnel and bend a new one.
  8. When I installed the walnut trim for the gunnel I came up a tiny bit short at the fantail. I thought I could fake it but as the little sign says….
  9. Still at it. Progress slow yet. This time I added walnut gunnel trim. Nothing like photos to show the screwups. Eventually it will clean up nicely. Looking ahead; what do I do for blocks? I have not calculated it out but at best guess 1/16" diameter on average. Same for cannon balls. Probably next stepwise to primer the hull to protect it from damage. Bill
  10. I use >020 brass wire in a spool. Unwind the length you need and clamp one end in a vise and pull the pull the other end with pliers stretching it out some. It will straighten and harden the wire at the same time. Bill
  11. Still going. Thank you all for the feedback and suggestions for hull and painting. Despite the setbacks of age and tremors I have decided not to give up just because my work now is not any near what it used to be. Ths model keeps my active an d helps me mentally. I have built a hatch. I used fine strips painted black on sides as I would for decking. Nothing like photograph to shoe you al the flaws however I think that once i finish with ll the deck furniture I can give it final primer and fine sanding. Thank you ll for your indulgence and good feed back. Bill
  12. Thanks Phil, No gun ports just one swivel gun in center of deck. Will probably do black hull, white gun'l. Not sure what for copper. I may be able to find some copper leaf. Bill
  13. I turned 92 last month and My hands are quite shaky but I have not given up, it is still on my workbench. I have done some minor work recently. Am fitting the rudder next. Question: would the cutter have copper on hull back then? What might have been an upper hull color?
