jud
Posts posted by jud
  1. Using a file card will help keep the teeth clean, can keep them even cleaner by rubbing chalk on the teeth. Work it in to the bottom of the grooves, then wipe the file clean with a rag, leaving the chalk in the grooves. Always lifting the file on the back stroke, is probably a habit you already have. The chalk will keep the filings from building up and sticking at the bottom of the grooves and make the file easier to clean. There is a method using an overnight soak in acid that restores a file, never tried it myself but a friend was bragging about the results he got by doing that. He has a rotary table of mine, when I go get it I will sneak a look at his files.
    jud
  2. Not just oily rags will self combust, damp anything and compressed or in a space where the water can't evaporate will do it also. Grandad lost a barn when he got a pocket of damp hay in the loft. That barn had buckboards and other wheeled small carts and wagons and lots of harness and saddles. There was enough harness to equip and use 20 horse teams, he used mules to farm with. Spontaneous combustion was something I was told about, at a very young age.
    jud
  3. Deck beams do more than keeping the deck up, posts can do that, When a ships bow hits the next swell with the bow canted down from the swell she is riding, the upper ends of the ribs, because the planking is in compression, will want to move out because of those forces. When she crests a swell, both ends are not supported as well as amidships so the planking goes into tension and tries to push the ribs together. Without those deck beams the ship would tear its self apart. All of the structural members of a floating ship are constantly changing from tension to compression and all beams have dual rolls, one to keep the ship together and placed so the crew can live aboard. Because of the constant changing of the forces working on a ship, joints are well thought out.
    jud
  4. Is that a representation of the difference in elevation similar with contour lines, the reference plane being C/L with that plane being horizontal in both ways. Never have seen anything quite like this, it just looks like a way to graphically show the rate of change along the hull, Anyone have a definition of what a "Zebra View image" is? The Z component of a XYZ coordinate?
    jud
  5. Perhaps to make boarding more difficult. Without the dead eyes and lanyards available, boarding at the shrouds would be difficult, especially with  weapon in your hand. Sometimes loose netting was used for that purpose.
    jud
  6. Try holding your steel wire in a vice or vice grips that you don't mind getting black and heat the upper end which is close to the holder with your torch, when a yellow-oringe color tap the end with a small hammer, it's called upsetting in blacksmith language, ( Upsetting is the process of making metal thicker in one dimension through shortening in the other. One form is to heat the end of a rod and then hammer on it as one would drive a nail: the rod gets shorter, and the hot part widens. An alternative to hammering on the hot end is to place the hot end on the anvil and hammer on the cold end.). You can find a lot about it on line. The blacksmith neither burns or melt the material he is working with.
    jud
  7. Nice work on your shackle, tricky way using heat to form a ball to upset the ends of the body creating more material where needed on the ends..
    I have seen shackles made using flat iron. Made by heating one end in the forge and driving a hole through it with a hole punch, then heating the proper place again on the forge and driving the same hole punch through, then after reheating, bending it to the u shape they usually are, all are not u shaped. I have seen  some that were reheated after forming and hole alignment adjustments done go back into the forge and having the bottom of the u rolled outward. A bunch of them around here, some made using the forge and anvil and others that came with early equipment and wagons that were punched out of sheet. Throw this out, not as criticism but maybe someone can use for their project. Most shackles pins are usually not much smaller in diameter than the body of the shackle, the flat type seem to use smaller pins, some with collars. Nice work on your shackle.
    jud
  8. Having chased 8" projectiles around a turret shell deck and the truck running on a track between the barbettes, Also with a few others trying to catch, stop and secure a fork lift in the tank deck of an LST as well as my meal tray and various other things, I have many doubts that all is told about handling those guns on a rolling deck.There must be some equipment missing, tackles are slow, especially the tail tackle, it must be removed from the gun during firing to keep the trucks from running over parts of it. While it is being hooked and the slack is taken out of that tackle, the gun is free to move ahead. Keeping it from moving is much easier than stopping it once in motion, there must be some wheel chocks or some other missing tool lost in history to protect the gun and crew from a run away while the tackle comes into full play, especially on a rolling deck.
    jud
  9. My drafting table is made from a surplus hospital solid core door that weights about 120 pounds, one edge attached to the desk using a large piano hinge. I envisioned building a tilting mechanism using slack adjusters from truck air brakes. It has been tilted using various thickness boards shifted between the door and desk top for years now but mostly the top has just rested on a 2 X 4, if I need to change it I can. Slack Adjusters never purchased although I had a good solid design using a hand wheel to tilt the thing.
    jud
  10. When the guns were ready to fire the tackles were flaked down so they could run without tangle. If the guns were secured for sea, they were secured in various ways and all tackle was off of the deck. Ropes coiled in a flat coil on deck was ornamental only, when the occasion was over the tackle was hung off of the deck, who needs a bunch of line underfoot, holding water and rotting.
    jud
  11. Get a new thin blade for your table saw, make a new insert and cut the blade slot with your new blade after you check for everything being square. Make some jigs and saw your wood. Takes a very good band saw to re cut limber with a close tolerance and those small cheap saws are not the tool to do so, even if the advertizing would lead you to believe it would do so well. I have one of those cheap tabletop band saws, boy was I disappointed, haven't used it for years and I have a bunch of new blades for it. I think that if I would machine new adjustable guide supports both top and bottom then use bearings instead of the blocks it came with to guide the blade the quality of the cuts would improve but it's way down on the list of things to do. Others may have had better luck, I hope more will tell their experience..
    jud
  12. Think I would seal them in an air tight container with a damp sponge for a few days, sponge not in contact with the folded plans. Might allow the plans to be opened without damage. If not, let the moisture stabilize back to normal and try something else. Might be some product out there intended for that use other than water.
    jud
