druxey
Posts posted by druxey
  1. I think you are on track with your keel/false keel joints, except you might wish to shift the joints of the false keel aft. The first section likely to touch would be aft, so that might be shorter. As the false keel joints do not contribute to the structural integrity of the ship, it's not critical to stagger them exactly half-way between the keel joints. I'd keep any keel taper to the cant frame areas as well. Good stuff, Joss
    P.S. Some of us like history: those that don't will skip it anyway!
  2. Thanks, Gary. I'm sure that there were variations on the theme as you describe. I suspect that the upper deck, exposed to weather, wore more quickly than the lower gun deck. This might explain the layout on Tremendous.
    ZAZ7908 shows long planks in an undated 74, obviously earlier than 1800.
    On a related note, Montague, 1779 has wonderful drawings of part of her side planking that needed replacement. These drawings were obviously done as a record in the shipyard at the time. Go to the NMM site: 'Collections'>'Search'>'Montague 1779'.
  3. While I've had proportional dividers in my kit for years, I confess that I've very rarely used them. I use a drawn proportional radiating scale on paper. Much cheaper! Just find the spot along the converging outer lines that equals the space you want to divide up - in regular or irregular fashion - and mark off the divisions on a strip of paper at right angles to the radiating lines. The marks are then transferred to wherever you want them. (The example shown is for dividing a square into an octagon.)
  4. Good question, Sherry. I would finish your (very nicely!) carved figure so that it visually blends with the rest of your model. Basswood will darken a little with time, so it will not look quite as white as it does right now. It really depends on your personal taste. There are no wrongs or rights, really. If you are unsure, look at photos of other models and see what look appeals to you.
