druxey
Posts posted by druxey
  1. Well, that looks more plausible, but are the lengths 24' 0" ? They look a bit short. The other little item to observe is the lowest plank aft in the lower strake. It is a short piece (if you've arranged everything else correctly) as it was cut to shape and fitted rather than bent. The piece curls as well as curves around to the outer end of the wing transom.
    Check the RMG web site and search 'planking expansion' for examples.
  2. If you are trying to put a burr on a scraper, hold the scraper in a vise. Run the burnisher along at a slight angle, pressing hard, to turn the burr edge. Takes a few tries to master this, but you will get it!
    I've only just found this thread and you are doing a great job, Jacques. It's too bad that the plan set lacks some important detail, but you seem to be overcoming the problems well.
  3. If I understand your problem correctly, I would use a sanding surface. Rubber cement the paper to a flat surface. You can then gently sand the plank edge, holding it at a slight angle to produce a subtle wedge-like cross section. Test fit until the plank almost seats all the way into the space it needs to occupy. Then  you can glue and press it all the way home for a tight fit.
