druxey
Posts posted by druxey
  1. Without seeing what your model actually looks like, i can only offer a general suggestion. Measure and mark out the hole first. Now check it again!  Drill an undersized hole slowly, backing up with a pad of scrap wood. Holding the pad tightly against the inside of the hull will prevent tearing out when the drill bit breaks through. Slowly enlarge the hole to the size and shape you want using Swiss files. That way you maintain good control over the operation.
  2. Mark: after your investment of time and money, that is a brave decision you'll not regret.
    My first serious scratch build, many years ago, ran into many of exactly the same problems as you describe. I, too, decided to junk her. On my next model I was able to avoid all the pitfalls I'd fallen into the first time around. I ended up - some years later - with an award-winning model. May this be your experience also!
  3. The original draughts of the Sherbourne (CHN1012 or CHN0224), unfortunately not available on the NMM 'Collections' site, show a sweep port between each gun port and aft of the aftermost one. Also indicated are port lids. These are two-part lids, hinged at the sides.
    If you are interested in extreme detail, you might wish to invest in one of those two drawings (the other is a copy of the same drawing). Both plans also include all the spar dimensions. The deck plans for Sherbourne are on sheet ZAZ6382.
