Everything posted by pete48
Well, I procrastinated long enough, I knew that installing the Keel would be difficult, and it lived up to the billing. I started by lining up the Keel on the overturned hull, and marking the Hull as per plan. I used West System G-flex epoxy with 406 filler.( That went smoothly ) The tricky Part was Installing the Deadwood. ( this took a few attempts and burned thru a bunch of wood ) Once the Deadwood was set, I epoxied them in and filled the seams. I will let her stand for a day or 2 and fair the Keel. Here are the results
Beautiful, Nils She is looking Amazing Best Regards, Pete
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
Thank You, Elijah, I will be installing the Keel on the Haven, hopefully, this week weather permitting ( it snowed here today I need it to be a bit warmer for the epoxy Best Regards, Pete
- 258 replies
- buzzards bay
- herreshoff
Thank You, Patrick, She is one of my fav's as well Thank You, Piet, She was an absolute pleasure to build Thank You, Keith, I would have liked to set up molds like I did on the Haven 12 1/2, I may still do that at some point Thank You, Michael, I hope this trend continues Thank You, Tom. I am without words Best Regards, Pete
- 258 replies
- buzzards bay
- herreshoff
- 258 replies
- buzzards bay
- herreshoff
Thank You, Mark, I am pleased with how she turned out Thank You, Jack, I had hoped to capture that essence that the Herreshoff boats have Thank You, Elijah, The next thing will be to finish the Haven 12 1/2 Best Regards, Pete
- 258 replies
- buzzards bay
- herreshoff
I would like to first thank everyone for the likes and comments, Today, I completed the Tiller the running rigging and raising the Sails, I will not be adding any new postings to this log I will respond to Comments. Here are the results
- 258 replies
- buzzards bay
- herreshoff
- 258 replies
- buzzards bay
- herreshoff
Today, I started by making the Tiller, I almost had the first one complete when the Egg on the tip broke off, I then had to make a second one, it is nearly complete and then need to be finished. I then Made the Boom Vang and installed it to the Mast and Boom. Next will still be to make the cleats and raise the Sails. Here are the results
- 258 replies
- buzzards bay
- herreshoff
Thank you, Keith, I appreciate it. I look forward to your build Best Regards, Pete
- 258 replies
- buzzards bay
- herreshoff
Hello, Piet, I used balsa on the first one because it was built to be Static. The Basswood works well with West System epoxy and will make the Hull strong. I am hoping to have the Herreshoff finished this weekend Best Regards, Pete
- 258 replies
- buzzards bay
- herreshoff
Today, I started by making the remaining blocks. Next I secured the Standing rigging by attaching them to the Turnbuckles. I then ran the running rigging. Next will be to make the Cleats, Tiller and raise the Sails. Here are the results
- 258 replies
- buzzards bay
- herreshoff
Thank you, Patrick, The grey Hull was nearly complete when I finished the first one, It took about a week to get to the point where the one on the jig is ( it does not seem that quick to me ) Best Regards, Pete
- 258 replies
- buzzards bay
- herreshoff
I am hoping to get some work done on the Herreshoff today ( I will post pics later ) I have been doing Pre- work for the 1/2" scale Volvo pond Yacht with the Volvo that I started, I then ( after planking with Balsa ) Realised that I wanted to do some water testing at the smaller scale to help with rudder and keel configurations, So I started another and will be using Basswood for the planking, Here is where I am at with that project
- 258 replies
- buzzards bay
- herreshoff
Nice work on the Wheelhouse Bob, Looks good Best Regards, Pete
- 348 replies
- pequot
- cable ship
Hi Mark, I have been using Epifanes varnish with good success ( it does take about 10 hours in between coats ) Best Regards, Pete
Thank You, Piet, I have a few more to make, I am thinking of adding a boom vang. I can see the committee boat, so the end of this build is getting close Best Regards, Pete
- 258 replies
- buzzards bay
- herreshoff
Thank You, Elijah, I spent a lot of time pondering, and making ( lots of trial and error ) more up to date looking blocks, I am pleased with how these look Best Regards, Pete
- 258 replies
- buzzards bay
- herreshoff
